Question about Yard Machines 24A452G700 205cc Briggs Stratton 800 Series Gas Powered Chipper Shredder ()
The machine has stood for 2 years - I can get it to run but not on full throtthle and then it will cut out. The fuel system most probably needs a complete clean. How best would I tackle cleaning the system?
    Scholar:
  • 150 Answers
More than likely will have to clean carb. But give this a try first. Run your carb adjustment screws all the way in and then back them out 1 and a quarter turn you may avoid cleaning its worth a shot. good luck.
Posted on Oct 07, 2010
Testimonial: "thanks i will give that a try and report back."
2012 kx450f bikes cut out when accelorating
Check your fuel/air filter These will usually last about 2 years, but this will depend on how the machine is used. If you use the machine a lot off road you should be doing a yearly service approx every six months. Also make sure your fuel pump is running.
Apr 21, 2013 | Motorcycles
Thundercat won't run without full choke
is airbox and filter all good no leaks, could be blocked small jet in carb, will it run ok higher in rev range
Mar 09, 2013 | 1995 Yamaha FZR 600
When the car has been stood still for several hours the engine will fire up with the first turn of the key , after 5 - 10 secs the engine cuts out as if starved of fuel , then it takes several attempts of...
may need a new glowplug timer trie leaving the ingnition in on position a few seconds b4 cranking also u need 2 check ur not getting fuel flow back and loseing pressure at pump
Sep 06, 2011 | Nissan Pathfinder Cars & Trucks
Ive got a ryobi 33cc 14inch bar chainsaw has been sitting around for about a year ive put fresh fuel in it. it starts but doesnt like running .
If its been stood for that long with fuel in it, the fuel will have gone stale, it will now need a full fuel system and carb clean, stale fuel leaves a smelly black residue in the carb and jets.
Aug 02, 2011 | Garden
Jaguar s type 3 litre 1999 running badly, has been stood for 2 years, was running lumpy when stood up, hence why I bought it so cheap! have changed spark plugs, air filter and one coil pack and 1 lambda...
did you drain the gas old fuel turn into like gel and can clog injectors and run rough it may take a while and some fuel flush to have it running good again
Sep 17, 2009 | 2000 Jaguar S-Type
Ryobi straight gas trimmer, runs rough at idle and up to 1/2 speed, but great at full speed. Bought a reconditioned one.
Here was my solution:
I was having problems with my ryobi cs30 weedeater also. It would start up fine on full choke, but i could not give it more than half throttle or ever take the choke off or it would stall out. I replaced fuel mixture, spark plug, spark arrestor/exhaust, fuel lines, cleaned carb, and still nothing! I was considering getting a better machine. Then i decided to play with the carb adjustments.(on my cs-30, they are two screws on the carb that have a "L" and "H" next to them) I dont think you can get the specialty tool for adjusting the carb unless you are a repair tech, so i just took a Dremmel tool with the circular cut-off wheel to the head of the specialty screws and made them into "flat-head" screws so i could adjust them with a regular screwdriver (if you dont have a dremmel, get one!) (As i was cutting into the head of the screws, i also cut into the casing protecting the head of the screws that was in the way, this does not cause any damage to the unit, that casing is only there to keep "un-certified" people from adjusting it for themselves.)
Now to the easy part: The "L" screw adjusts the idle fuel mixture and the "H" screw adjusts the full throttle fuel mixture. turning the screws clockwise make the machine run leaner (less fuel) and counter clockwise makes it run richer (more fuel).
-I started out by turning each screw 1/2 turn counter clockwise and started it up, then as it was idling, i started adjusting the "L" screw as i was moving the choke position to run, after a few full turns counter clockwise of the "L" screw, it was idling perfectly in the run position, then i did the same thing the the "H" screw while holding down the throttle and i got it to run perfectly in the run position. Now it is running way better than it ever has. I hope this helps everyone.
Good Luck!
* For this specific problem, i would say you should probably just adjust the "L" screw and hopefully that will help
Apr 11, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Yard Machines 24A452G700 205cc Briggs  Stratton 800 Series Gas Powered Chipper Shredder () Logo
193 people viewed this question
Top Yard Machines Heavy Machinery Experts
Roland W VanLue
Roland W VanLue
rjivaro
donald boissonneault
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
