I have a 1979 echo 87g1.. Gets spark..gets fuel...just wondering if needle valves need set
5 Suggested Answers
emissionwiz
  • 76649 Answers
SOURCE: 2001 Toyota Echo Fuel consumption
EPA mileage figures are estimates, and seldom does it have anything to do with the real world, My new car is rated at 19 city and 28 hiway, it gets 22 MPG max. The only thing you can do is make sure the pressure in the tires is correct and run the recommened oil, keep the car in good running order.
Posted on Oct 01, 2008
SOURCE: parts for Yamaha Passola SA50 (11/1979)
i have a Passola SA50 but i can't start it because gear kick start was loosed....can you solve my problem??
Posted on Jul 18, 2010
2strokeJim
  • 577 Answers
SOURCE: will not start, has new
normally 1-1/2 turns on both jets should get you running, I would make sure your muffler screen is not plugged with carbon and also look at inside of cylinder while muffler is off and use flashlite and check you cylinder for up/down scratches/scores, does saw have compression ? also if you are getting gas,make sure it is fresh gas ...no older than 4 wks, and if that does'nt do it you are probably looking at bad crank seals........Good Luck
Posted on Sep 16, 2011
ZJLimited
  • 17970 Answers
SOURCE: spark plugs gap in a 1979 305 camaro and set up valve lifters
Hi there:
Note:
0.035" ("35 mils") 0.889 mm
Other sites says 1973-84 must be 1.1mm
Confirm HERE (PDF file)
Hope this helps.
Posted on Oct 22, 2012
How to check fuel needle setting in Echo 2100 weed eater
Jack, Check the attached links for trimmer carb. tuning,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Tune Up an Echo Trimmer
http://www.echo-usa.com/getattachment/e8f287f6-0f5c-4f36-b0fa-ea8fa4a550b9/SRM2400241025012501S2510es_120194
echo srm 2100 weed eater
May 07, 2016 | Echo Garden
Echo trimmer , new carb , good spark, cleand fuel filter, new fuel, new fuel lines, cleaned spark arrestor,primed and pull , no gas getting to the plug.compression test? What pulls the fuel? Intake?
Hi Ralph, Seems like the problem is where the float and needle meet, The float, needle and seat let the gas into the bottom of the carby and as the gas rises the float rises as well pushing the needle up into the seat slowing the gas flow into the bottom of the carby.... As the motor's using the gas in the bottom of the carby the float's lowering and the needle lowers as well allowing gas into the
carby, If the needle is stuck inside the seat then NO gas will be let into the bottom of the carby so check that by pushing up and down the float to see if the needle moves up and down if not just pull the needle down with your fingers.... OH AND YOU MIGHT NEED
TO CHECK THE PART OF THE FLOAT THAT TOUCHES THE NEEDLE.... I hope you know what I mean....CHEERS..
Apr 22, 2016 | Echo Garden
Yamaha 1979 GT 80 won't stay running set float cleaned carb new needle and seat bogs at top end
Hi, Anonymous and the usual suspects are:
1. Inlet system air leak.
2. Enrichener valve not seated or leaking.
3. Damaged or restricted fuel tank vent system.
4. Restricted fuel supply tract.
5. Dirty or damaged air cleaner element.
6. Plugged bowl vent or overflow.
7. Worn or damaged needle or needle jet.
8. Vacuum piston assembly malfunction.
9. Loose or plugged main jets or passages.
10. Improper float level.
11. Accelerator pumps inoperative.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
https://yamahaclub.com/forums/topic/16021-1979-yamaha-gt80-wierd-problem
Yamaha GT 80 Problems
DOWNLOAD NOW Yamaha GT80 DT100 GT 80 DT 100 77 82 Service Repair Workshop...
OEM parts for Yamaha
ges freshblood co
Aug 28, 2013 | 1972 Yamaha XS2
1979 honda cx 500 will not start
check valve clearances
Mar 03, 2013 | Motorcycles
When take choke off stalls xs1100 1979
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
http://www.xs11.com/forum/showthread.php?t=39523
Bike starts up idles on choke dies with choke off our when warm
Yamaha XS1100SH Service Manual
Yamaha 1979 XS1100E Owner Manual
Feb 16, 2012 | Yamaha Motorcycles
Have an Echo backpack blower that has been difficult to start and found that the air filter is soaked with gasoline. Just letting the blower sit it is actually leaking gasoline from the air filter. What...
hi there
pauly 46 here sounds like tank breather and carby problems ?
have you checked that the muffler and ex port are not blocked ?
have you checked that the tank breather is working, and that the fuel pump diaphram is ok - no holes or damaged / stiff , and also that the metering diaphram and needle valve are ok and are not sticking open, or the lever setting is too high or the diaphram is just too stiff and holding the needle open
either way check tank breather and carby diaphrams , and needle valve and lever and the muffler and ex port for blockage
i assume compression and spark and timming and induction system are all ok
if its still hard to start and everything checks out as good might have a air leak
only way to know is to pressure and vac test crankcases
might pay to let your local shop do this because you need some special tools
but cover the basics 1st
cheers pauly46 hope it helps
May 14, 2011 | Echo Gas Blower 204 MPH765 CFM Blower...
SRM 2000a echo whipper snipper Not starting tried new spark plug and fuel.
Small engines have three systems. 1-ignition 2-compression 3-fuel
if you have spark at the plug and fuel gets to the engine the issue is in the engine compression system. I recommend pulling off the muffler and looking for scratches or scoring.
If you need to replace parts find a dealer like www.arcolawn.com to assist.
Feb 11, 2011 | Echo Garden
Echo leaf blower will not start....leaks fuel from exhaust after attempting to start. Have replaced Air Filter, Spark Plug, Fuel Filter, Fresh Fuel, Cleaned Spark Arrester.....I could use some advice, this...
sounds like u have a carb problem,ether theres debris stuck in needle valve needle is stuck open or the check valve diaphram is bad.take carb off on one side there is a plate with 4 screws remove then agasket and diaphram remove them some times they stick to carb so use a razor blade to go underneth diaphram all around from center youll see a metal see saw with a pin going through if u push on center it will lift needle valve on other side make sure it goes all the way down or remove by removing screw that holds pin in and blow out with air lightly may blow seat out after that on other side of carb take other plate off by center screw that diaphram has 2 little flaps check valves make sure they are limber and not wrinkled or bent if so u can get new ones at good mower shop or parts supply hope this helps
Aug 07, 2010 | Echo Garden
1979 Yamaha TT500 old and rusty
-Take the spark plug out of it and squirt some oil down into the piston and let it sit for a week or so.
-Lubricate rusty components with wd-40.
-Take the carb off and clean well , buy a carb kit and replace the seals and gaskets as well as the needle and seat valve, this all come with the kit.
-Clean the fuel tank and check all lines for cracks.
-Check all the vacuum lines for cracks or collapsed line, replace if necessary.
-Clean all wiring connections throughly.
-Replace the spark plug with a new one, and change the oil in the crank.
This should give you a good indication if it will run or not.
Good luck.
Sep 18, 2009 | Yamaha SR 125 Motorcycles
Parts for Yamaha Passola SA50 (11/1979)
im looking for a plastic speedometer drive gear for a yamaha passola which is located in the front wheels hub.
Feb 16, 2008 | Baby Gear
Computers & Internet Logo
172 people viewed this question
David Payne
David Payne
