Question about Dell Dimension 3000 PC Desktop
Hard drive/Dell Dimension
That's the problem, I don't think there are any srivers loaded and there is no "drivers and utilities" CD with my restoration cd's
  • 47 Answers
Just go to Dell website and put in make and model of computer.
download driver's to desktop and copy setup to a cd.
You can use any computer to do this, just DON'T open till cd in your computer.
Posted on Jun 11, 2008
Blue screen Dell Dimension 0x0000007B
plug the HD in other PC and execute Scandisk Complete
Jul 18, 2012 | Dell Dimension E520 PC Desktop
Good video, no sound with my dell dimension 9150
You can try to get the drivers off of your CD or you can download the drivers from here:
http://www.dell.com/support/drivers/us/en/19
1. Just choose "Select A Different Product"
2. Then choose "No, Choose from a list of all Dell products" and
select "continue"
3. Then select "Desktops"
4. Then select "Dimension"
5. Then select "Dimension 9150/XPS 400"
6. Now just scroll down and pick the drivers you need.
Don't forget to install your chipset and network drivers as well.
Jun 04, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I was just given a Dell Dimension 3000 by my daughter, who said there was no problems with it. It has a CD-Rom drive and a DVD-RW drive. When I power it up and click on MyComputer, neither of these drives...
They probably can't load because they are loading at the same time and XP can't sort it out.
Remove the cable from the CD ROM and re boot but enter the BIOS and make sure it is no loonger there.
The nachine should load the DVD rom.
You can try adding the CD rom now, it may work but being XP it may grab the wrong driver again and hang up.
Download new drivers from Dell.com
Hope this helps.
Jan 02, 2011 | Dell Dimension 3000 PC Desktop
Dell 5150 won't load drivers
Hi try going to control panel, system, hard ware and then device manager. If you have any driver issues, your device will be highlighted by a yellow ? With your driver CD in drive, click the + sign and right click the device with the problem, select update driver, follow instructions and select install driver from disk. Hope this helps
Jul 16, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
Ethernet Controller is missing
You are unable to use the Ethernet, VGA etc. because you have not installed the drivers for the same.
You might have received a Drivers CD(it will read "Drivers and Utilities") which will be in blue color, when you got the computer from Dell.
In case if you haven't received it you can contact Dell on 1-800-624-9897 and request for a Driver CD. I guess this Dimension model is @ End of Life (I mean no more produced by dell) you might have to download the drivers from Dell's support site (www.support.dell.com) you will have to get it downloaded on a different computer and copy on a CD or a Flash drive.
Once you got all the drivers. First extract them in a separate folder
Go to Device manager
Right click on the Ethernet controller (where you see a yellow exclamation)
Click update drivers
Show the path where you have the driver files
Sep 20, 2009 | Dell Dimension 3000 PC Desktop
Cannot install spund srivers on dell dememsion 8300
use msconfig ,run startup disable all apply close
Jun 25, 2009 | Dell Dimension 8300 PC Desktop
My computer won't start up or get passed the boot up stage
If its the screen I am thinking, it may be because it cannot detect the Hard Driive, so no windows files to load.
- Reboot
- Enter the BIOS menu (usually F1, but think F2 on Dell;s)
- Click on the summary page, under IDE or HD can you see a label with a size e.g. HD1 800000 or does it say none - you can also see other devices from the suammry such as CD ROM ..etc Can you see all thse correctly?
- If not seeing the Hard drive you will need to remove the PC cover and check the IDE/SATA connectors are firmly in, in your harddrive and the other end to the mother board (could of come loose). If they are, there are still more things that can be don - but let us know if this is what you are experiencing first.
Mar 18, 2009 | Dell Dimension 4300 PC Desktop
No boot device available
Make sure all the connections to the Hard Drive are tight and secure. Then see if it will boot. If not then try loading a windows cd and see if it detects the Hard drive. If it does not the hard drive is no good if it does try running the automated system recovery you may have a corrupt MBR file.
Dec 22, 2008 | Dell Dimension 4400 PC Desktop
Hard drive replacement w/system restore disc
After installing the new hard drive, you'll need to boot the computer from the recovery disk and follow the instructions to format the drive and install windows. You'll also need to install drivers from the driver disk after Windows is up and running. If the computer won't boot from the recovery disk, you'll need to access the "setup" utility and set the CDROM drive as the first boot device. To access the setup utility, press the Delete key after turning on the power. I hope this helps!
Mar 11, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 3000 PC Desktop Logo
Alun Cox
