Question about Singer 5050 Mechanical Sewing Machine
Sewing machine does not sew. Finished sewing something, turned it off, then turned it on a few hours later and it will not work. Light is on but nothing happens when the foot pedal is pressed. Took apart the foot pedal and nothing seems to be burnt.
    Genius:
  • 1,788 Answers
Call Singer at 1-800-4singer and ask for their advice, you do not want to void your warranty with not going to an authorized repair service if it comes to that. Good luck
Posted on Oct 07, 2010
My husqvarna rose is sewing without me! I am doing something and suddenly it starts sewing straight and does not stop till i turn the power off
You probably need to have that checked. Until then, be sure to always unplug the machine when you are finished--don't want to start sewing while you are away from the house.
Mar 30, 2017 | Husqvarna Sewing Machines
Just turned machine on after being off and unpugged for a month or so and it is making a noise like a motor is running. any suggestions?
Question on sewing machine motors on vintage machines. - Sewing ...
artisanssquare.com > ... > Sewing Machines
Apr 28, 2010 - 20 posts - ‎4 authors
I've recently acquired 3 vintage machines a Singer 201 and 185 and a New ... When the motor is making some noise, but nothing is moving yet, that .... look - fragile, warped ? something like that anyway - in the first few turns.
How Do I Fix My Sewing Machine: Troubleshooting Your ...
www.craftsy.com > Blog Home > Sewing Blog
Nov 7, 2014 - Well, I've been teaching on Janome machines for about 6 years, and I ... Take the Trouble Out of Sewing Machine Troubleshooting! .... Problem #7: Themachine is trying to sew and making sewing-like sounds, but ..... My Brother sewing machine JX2517 just shut down while I was ... in or close to the motor.
Six Common Sewing Machine Problems Solved ' eBay
www.ebay.com > ... > Sewing Manuals & Instruction
Sewing machines sometimes seem to have a life of their own when it comes to working ... sewing problems can be fixed or prevented just by making sure themachine is... ... If the sewing machine is making uncommon noises, such as grinding or ... Do not use the machine when it is operating this way, and turn off power to ...
Let's Talk Sewing Machine Maintenance! ' LLADYBIRD
lladybird.com/2013/02/13/lets-talk-sewing-machine-maintenanc/
Feb 13, 2013 - At the risk of sounding like a big fat sewing machine snob, it makes me cringe ... I understand that it may not be common knowledge that sewing machinesneed regular ... If the idea of poking around in your machine just sounds too ...... now the tune up turn into oiling the most basic part of your machine, .
Jan 25, 2016 | Sewing Machines
I have a Singer Futura Quartet SEQS-6700 sewing machine. Keep getting error code 16, but there is no explanation in the product manual. Can you help?
Generally the error message is due to "some" electrical overload. It settles itself most times by turning off the sewing machine for a few seconds to allow complete shut-down and then turning it back on. It the error message returns, it is best to visit your qualified local technician.
Nov 07, 2014 | Sewing Machines
Sewing machine slows to a stop.
When was the last time you oiled it?
Sewing machines need regular oiling as you use them - it sounds like you have or are close to seizing the bearings.
In future, when you smell burning and a machine that should operate at full speed slows down - stop, don't persist in using it.
It clearly has something wrong with it.
Your users manual should cover oiling the machine - there are predetermined points at which you drop the sewing machine or 3-in-1 oil into. Only a few drops are necessary, but you should oil it every few hours of use.
Jan 11, 2014 | Omega 6147 Sewing Machine
Single 8280 sewing machine handwheel not turning
okay, i have never used a sewing machine except for once, but i do know quite a bit about them because my grandmother knows a lot to. so, here we go. take the spool of thread off of the machine now,locate the thing (i'm not sure what its called) that the spool rests on. now, push it in and turn it at the same time. test it out. keep doing that until it works. it might take as much as an hour, but at the same time it could just take a few simple seconds. good luck.
Aug 25, 2012 | Singer Sewing Machines
My Huskylock 936 won't sew. I was sewing yesterday, 4 thread overlock. I finished a seam, cut the thread, proceeded to sew another seam. I put my foot on the pedal..and nothing.If I turn the machi
Good evening madam
It sounds like there is something wrong with the electrical system in your sewing machine. You can check the power and connections.
good luck
Kolbrun
Feb 26, 2012 | Husqvarna Huskylock Computerized 936
Why does my new Singer cg-500 stop working, then start for a little bit and stop again?
Probably thread wrapped around something....takeup crank, motor pully...if you can get inside to have a look great, if not, find someone who can.
Oct 25, 2011 | Singer CG500 Mechanical Sewing Machine
My Janome sewing machine wont stop.
The only thing I can think of is that the foot pedal may be slightly stuck and not returning fully up after being depressed. Unplug the foot pedal and check for anything stuck there then give it a good wiggle up and down a few times.
Oct 19, 2011 | Janome Memory Craft 9000 Computerized...
Hot to stop a a previous transmition
If you don't have the transmission box up with the "Cancel" button up, then there's a few steps you have to take. First, close the software on your computer. Next, turn of the sewing machine. Unplug the USB cord both from the sewing machine and from the back of your PC. Now plug the USB back into the computer, then the sewing machine & turn the machine back on. Finally, reopen the software. This should clear the "buffer" between your computer and the machine of the pending transmission. I've had to do this every time I have a finished design before I can start a new one.
Feb 23, 2011 | Singer CE-100 Futura Computerized Sewing...
Singer 5050 Mechanical Sewing Machine Logo
185 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
