I have entered an incorrect fax number. How do I delete that number because the fax machine keeps on retrying it.
  • Jafta Oct 07, 2010
    Fax model and make? Check for something that says tx report normaly it can be delete there. Most fax machines only try the number 10 times and then discards it it self.
    Genius:
  • 1,218 Answers
You will have to specify make and model to get help.
Posted on Oct 07, 2010
A incorrect fax number got loaded into the memory by mistake. How do I delete it. It is a Pixma MX320 model
If you mean the fax number for your fax machine, you should be able to press the Fax button on the printer and then press the menu button, then go to settings. You should be able to change the original set-up information, including the fax number and other identifying features for your faxes.
If you mean for memory for other fax numbers, you should be able to to to the directory in the settings and edit or delete the memory settings much the same.
Sep 23, 2010 | Canon PIXMA MX310 All-In-One Printer
How to register number has been delete. How do you put them back in a Pansonic Panafax UF-55o machine. The fax machine work just the long distance number that was register are going. Need to know how to...
press
function 72
set
press 01 on the soft key pad enter fax number
set
enter name with the letters on the soft key pad
set
continue with 02 as above or press stop
press
function
62 set to print diectory
Mar 24, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
How do you set and delete speed dials on minolta 2800 fax
Speed Dial Keys
The fax number and other data for a particular destination can be programmed using a 3-
digit Speed Dial Number. This feature allows you to transmit a document to the
particular destination by pressing the Speed Dial Key, entering the 3-digit number and
pressing the START Key. You can program a fax number in any of the 100 Speed Dial
locations, number 001 to 100.
Entering
1 Press the PROGRAM Key and scroll through the
menus until you reach the DIAL REGISTRATION
Menu. Press YES to begin programming.
2 Press 2 or scroll down to the Speed Dial menu and
press YES.
3 Enter the number of the location you want to
program and press YES.
4 Enter the Telephone number you wish to transmit
to and press YES after checking to see its OK. If
you want to enter the sub-address, press the Down
Arrow Key.
5 You can press sub-address up to 10-digit.
REGISTERED! KEEP?
OK=YES (EDIT/DEL=NO)
EDIT *DELETE
-SELECT&PUSH”YES”-
DIAL REGISTRATION?
YES / or 1-6
2 SPEED DIAL?
OK=YES
SPEED DIAL =_
OK=YES
OK=YES (SUB= )
SUB=_
OK=YES
Edit/Deleting
1 If you wish to change any entry, a screen allows you to accept or change.
2 If you wish to change a Key that was previously
programmed, this message appears. Press YES to
keep this location as is, or NO if you wish to edit it.
3 If you choose NO, use the arrow keys to select
either EDIT or DELETE and then proceed with the
needed changes.
Group Dial Keys
Instead of their regular functions, any of the One-Touch Keys can be used as Group Dial
Keys. Destinations already stored for One-Touch, Speed Dial can be entered in a Group
Dial Key. Each Group can contain up to 50 locations.
Entering
2 Press 3 or scroll down to the Group Dial menu and
press YES.
3 Press the One-Touch Key you wish to use.
4 Press YES to accept your selection.
NAME=_
OK=YES
REGISTERED! KEEP?
EDIT *DELETE
-SELECT&PUSH”YES”-
Nov 28, 2009 | Minolta MF1600E Plain Paper Laser Fax
How do i delete a wrong phone number that i entered incorrectly
Press
Function 72
set
scroll to the bad number and press CLEAR twice.
Oct 23, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Speed dial
NEW Number
Function
72
set
press destination like 01 the yellow part of the keyboard
enter fax number
set
enter name
set
stop
Delete a number?
press as above like 02
press clear
set
press clear
press set
stop
Apr 30, 2009 | Panasonic PanaFax UF-8000 Laser Fax
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
Jan 11, 2009 | Brother IntelliFAX 4100 Laser Fax
GROUP DIALING - HOW DO I DELETE A NUMBER I ADDED INCORRECTLY
I think you have to delete the entire group. Then set up a new group. Usually they can't be edited.
Sep 24, 2008 | Office Equipment & Supplies
200 page fax sent to me incorrectly
turn the machine off, hold down the stop button and turn it back on, this will clear the memory
Jan 29, 2008 | Brother FAX-2920 Plain Paper Laser
How to clear the memory
Press FUNCTION key then 9 key. The display will ask you to ENTER FILE NO. OR ^. You want to enter ### as the file number and press SET to delete all files. (You cannot delete the file while it is being sent). The display will then show DELETE ALL FILES? 1:YES 2:NO. Press 1 to delete all files.
Jul 25, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
Cannot fax outbound but can receive
Recipient has an incompatible fax machine or is always busy
Jun 04, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
20 people viewed this question
jasbo
jasbo
