Question about Vacuums
Bissell Pro Heat Turbo 2X - Vacuums
  • 4 more comments
  • amandah0312 Jun 02, 2008
    It isn't spraying from the unit or from the hand tool. I have already turned it on/off, checked the rubber gasket on the bottom of the tank. Taken the handle completely off and back on. Held the spray button down for 30 seconds while unit is off. The model number is 9300.
  • VinceQ Jul 13, 2008
    I have long had the same trouble. Only the detergent comes out in the spray - the main tank (water) does not get used. Checked settings, seals, inspected tubing for clogs, tanks full. Seems to be a design flaw!? I have been using it on "heavy traffic" settings with a detergent water mix to get around the trouble, but it is most annoying.
  • Sadies Nana Aug 07, 2008
    Same problem, only I have only noticed it with the upholstry brush. It would start to sputter and then stop. Then it would start up again strong, only to sputter out. I haven't noticed a problem with the floor sprayers yet. I too to things apart and cleaned everything out. I noticed that when it was sputtering I could see bubbles in the hose and when it stopped the tube in the hose appeared dry also. One belt appears frayed but the other is fine. There is a mixture of water and soap in what was coming out.
  • chessvalley Nov 05, 2008
    Hi, I have a Bissell Pro Heat 2X and have used it maybe 3 times in 18 months. The fourth time I used it the water would not come out and the hand held pipe would not work properly, sputtering and stopping. This is a pain as it is out of warranty so I started unscrewing bits to see what I could is what I found.
    First take off the water tank and unscrew all the screws on top and at the sides. Then unscrew the 2 screws right at the back where the cleaning control is and lift off the plastic unit (after removing the solution tank). There is a polythene cover that has double sided sticky tape on the side. Carefully lift it up, not worrying about the tape as this will either stick to the machine or the polythene and it WILL stick back. You can now prise open the top carefully but not too much. The pipe that feeds the two front outlets will be exposed and carefully squeeze the red catches together and prise each outlet pipe off so they are free and move the whole pipe to the side, so that it is sticking out from under the top cover. I did not lift off the top cover that much as it was difficult to do and I could see something being snapped if I did it too much. If you push back the metal coil things that cover the plastic pipes you may notice that there are bits floating in the water pipe. If there are you will have a blockage at the point the water is supposed to spray out and you need to remove the middle-end white connector from the pipe that goes into the machine. To do this there is a metal spring thing that can be teased off be squeezing the two metal parts of the spring together and pushing back. Once you do one it is easy to do to the others. However for now you just need to twist the clear pipe so the white T connector comes off. If you do the same to the 2 end pipes you will be able to wash and get these bits out. I then put the pipe with the removed T section back as well as I could through the first hole, where the red clip clipped in and put the water tank and solution tank back on (dont bother putting screws in yet. I then flushed the pipes through by pressing the lever at the top over a bucket and nice hot water came out with some black and white bits that were blocking the outlets. Make sure the 2 smaller pipes are cleaned (try sucking the end of each pipe to make sure there are stuck 'bits') and put it all back together. It sounds difficult but take it steady and you will see it is not that hard. Just be careful that everything fits back together under the top plate and screw back. You may need to move a couple of pipes in the machine to make sure you can do the above.
    Now I have not tried it properly yet but I have flushed it so no more bits come out and I am sure it will be fine. If you really want to try but don't have a clue what I have been talking about above then i am happy to make a video on youtube just for you! Post a reply! Good luck and remember to clean the machine well and make sure the solution is removed and cleaned through as I am sure this is the issue that causes the clogging. Best wishes, Chessvalley
  • forrgiven777 May 05, 2009
    my bissell won't spray out water when I push the trigger then dumps water from bottom when it feels like it.  Also the spinning gauge is NOT spinning.  I took it completely apart and one tube was completely dry and filled with a chalky substance I followed the tube all the way to the heating devise.  The chalky substance is coming from inside that.  I cleaned it all up and put it back together and it's still doing the same thing.
  • Lauren Junge
    Lauren Junge May 11, 2010
    What is your problem and also need model number.
Bissell stamer model 9300.... I have been trying to figure out why I can not get any suction from the house.... I fiunally figured it out, there is a piece missing. It is the beace tyhat sits on the housing of the machine that when the handle is in the locking position it conects the handle and the tanktogether.Iget suction to the tools dial but the piece to connect the suction to the handle is missing.... It is not listed on the parts list but there is no other explanation that makes sence....
Posted on Dec 29, 2008
  • 1,673 Answers
Here are things to check when there is no spray from hose or nozzles.
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
Posted on Jun 03, 2008
5 Suggested Answers
  • 17 Answers
SOURCE: my bissell pro heat 2x will not spray water to
Here is the fix
Posted on Feb 08, 2010
SOURCE: Bissell Pro Heat 2x steam cleaner, problems!
I took the side plastic protectors off because my brushes stopped working. I found one belt almost broken (held together by the fiber to the interior) and when I moved the brush rollers, I found mucho dog hair on the ends. Your rollers might be removed and see if you have the same problem. IT just takes two screws on each end to do this, so if your belts are good, take a look at each end where the metal post goes into it. I have two dogs and their hair is just everywhere!
Posted on Jun 25, 2008
SOURCE: My Bissell Pro-Heat 2x 12
my bissell 9200 won't release water or solution when the trigger is pulled.
Posted on Nov 20, 2008
  • 20 Answers
SOURCE: My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Posted on Apr 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ... > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell proheat 2x troubleshooting
depends on the suction capability generally the are slower than the bottom as you don't have to go over this with as much power/force hopes this helps
Apr 15, 2014 | Vacuums
Lost instructions for bissell pro heat turbo 2x. I cannot get water to spray for carpet or upholstry. What shall I do ?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
Sep 16, 2010 | Bissell Vacuums
Brushes not spinning on my Bissell carpet shampooer (pro heat turbo 2X)
Dog hair may cause this, clean this unit, take sissors and cut hair.
Feb 14, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Want to use Bissell Pro Heat 2X Clean Shot. Have
You can download a user manual from the Bissell website
Sep 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I need instructions for bissell pro heat 2x cleaner
you can dawnload it from the manufacture,s should go to there and dawnload it.
Sep 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Jul 02, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Please email me at
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat turbo 2x
Just do a simple google search next time for stuff like this. I typed Bissell Proheat turbo 2x user manual. The link above was the first result.
Jul 04, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Vacuums Logo
797 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
