Question about Nintendo Wii Console
I insert wii resort disc and before even reaching the wii menu screen, an error screen appears instructing me to remove disc, turn off wii and to consult the wii manual
    Problem Solver:
  • 12 Answers
Your lcd is dirty go on youtube and type how to clean a lcd for wii
Posted on Oct 07, 2010
System settings were lost
System settings were lost:
You need to reset the time and date from the Nintendo GameCube Main Menu. To access the Main Menu, turn the power ON while holding down the A button on the controller. Follow these steps to reset the time and date:
From the Main Menu Screen, go to the Calendar Screen by pushing RIGHT on the Control Stick.
Press the A Button to display Calendar Menu choices of Date or Time.
Use the Control Stick (UP or DOWN) to highlight your menu item and press the A Button to select your choice.
Use the Control Stick (LEFT or RIGHT) to highlight the number you want to change, then (UP or DOWN) to adjust the value.
Press the A Button to accept your choice.
Press the B Button to return to the Calendar Menu or the Main Menu.
Pressing the B Button before accepting your choice with the A Button will return you to the Calendar Menu without changing the settings.
If the same error continues to happen, you will need to have your system repaired as it is likely you have an internal battery malfunction. Please use our convenient repair options.
Wrong Game Disc:
This message happens when a Game Disc has been removed while the system is on, and a different Game Disc is inserted. Re-insert the original Game Disc.
No Game Disc:
This error can occur when the Game Disc has been removed while the system is on and then the Disc Cover is closed. Follow these troubleshooting steps:
Ensure the game is inserted correctly. With the power turned off on the system, replace the Game Disc in the system, printed side up. Press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
Determine if this happens with more than one game by inserting a different game into the system.
If the error occurs with all games, follow the Multiple Game Disc troubleshooting.
If the error occurs with only one game, follow the individual game disc troubleshooting.
Nov 17, 2012 | Nintendo Wii Console
Tip
Common Fixes for Wii
Almost every Wii problem can be solved with a few troubleshooting techniques. The first of which is to unplug the power cord from both the power outlet and your Wii console. This is a particularly useful fix when the following error message appears on-screen: 'Error Occurred. Press the Eject button and remove the disc. Turn the power off and follow the instructions in the console manual' Also, check the disc to see if it is dirty or scratched. Even if it isn't, clean it with a warm, damp rag. If you are having trouble with your Wii remote, check the battery level by pressing the 'home' key on the front of the Wii remote. The 'home' key has a symbol of a small house and brings up a menu that shows the battery level of your Wii remotes. If the battery level on your Wii remote is fine, hold down the sync buttons on both the Wii console and Wii remote. The sync button on the Wii console is located underneath the plastic flap on the front (just below the power button) and the sync button on the Wii remote is located under the battery cover (just above the batteries.) Both buttons are red and have the word 'sync' on them, so they should be fairly easy to find. Hold both buttons for about five seconds or until the 4 lights on the Wii remote flash. Wait a couple seconds and your Wii remote should be re-synced.
on Dec 15, 2009 | Nintendo Wii Console
My wii just stops to blank screen wit white writing and says, error and to remove disc and turn console off which wont turn off by button so has to be plugged out and to go to owner manual which i cant...
Situation:
The Error Message: Error Has Occurred appears when loading or playing a game disc.
Applies To: All Games
What To Do:
There is likely a problem with the Wii console. Click here to begin the repair process.
Nov 15, 2012 | Nintendo Wii Console
Keep getting error message,remove disc and turn power off
Error Occurred. Press the Eject button and remove the disc. Turn the power off and follow the instructions in the console manual.
First turn the Wii console power OFF, and remove the AC adapter's AC plug from the power socket. Next, check whether the disc is dirty or scratched. If it is dirty, gently wipe with a soft cloth from the center to the outside. Wait about 5 minutes. Then plug the AC adapter's AC plug back into the power socket and turn the console power on. If the same message still appears, the Wii console may be damaged. Turn the Wii console off immediately.
Remove the AC adapter's AC plug from the plug, and visit support.nintendo.com for additional troubleshooting or call 1-800-255-3700.
Click here to download Ninento wii repair guide
Jan 04, 2011 | Nintendo Wii Console
Wii frezees after inserting Wii Fit Disc!!
You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Dec 06, 2008 | Nintendo Wii Console
Error message when disc inserted into Wii
it migth be upside down game broke or it is a burned disk and it can not be used anymore can u help me with my wii promlem too here is my problems link
Aug 22, 2008 | Nintendo Wii Console
Freeloader
The latest Wii firmwares does not allow the Freeloader disk to boot in the console. If the games start just right, then that's the only problem.
Jul 31, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
67 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
