Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Cant unlock self clean oven door
Unable to unlock oven door after self clean
  • 4 more comments
  • Anonymous Nov 25, 2008
    I ran a clean oven on my over and now the door is locked and won't open.
    What can I do to get the door open?
  • Anonymous Dec 23, 2008
    can't unlock self clean oven door problem
  • Anonymous Jan 01, 2009
    I don't see that you answered the question of "how do I get the door to open"?
  • Anonymous Feb 27, 2009
    I cleaned my oven on Sat. 2/21/09 & i have unpluged it & pluged it back in even tried pulling it open I have opened the stove top still cant get it to open some1 please help.
  • Anonymous Mar 19, 2014
    self cleaning oven cleaned and now eror and door won't unlock
  • Anonymous Mar 29, 2014
    model ples399ecd
  • 413 Answers
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
Posted on May 29, 2008
Had cleaned GE oven yesterday using SELF CLEAN and today my oven will not work as it keeps flashing UNLOCK DOOR when the door is already open. Cant use the oven
There is a sensor/switch that sends a signal that the oven door is locked and that it is unlocked, it must be defective.
Jan 11, 2017 | GE Ovens
Self cleaning oven
Pheo,
Turn Breaker/Fuse for the stove, your electrical panel, “OFF” and then “ON”, wait 20 - 30 seconds and the door should unlock.
It may be that the temp sensor is going out and you'll need to have that looked at soon.
Bill
Nov 21, 2007 | Whirlpool GBD307PDS Electric Double Oven
Oven was clean self cant seem to unlock door and stop it
Have you turned the selector know off of self clean setting. Usually this will unlock the door. Good luck.
Sep 14, 2011 | Kenmore Ovens
I have the self clean model & the wife slide the hadle on the door to use the self clean now we cant get the oven door to open
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker
Jan 09, 2011 | Hotpoint Ovens
Cant unlock oven door
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Dec 18, 2010 | Frigidaire 30 in. Electric Gallery Pro...
Unable to unlock door after a self-cleaning operation
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 20, 2010 | Ovens
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My self cleaning oven will not unlock
i would try to set fro a clen clycle again, it should try to relock the door and then simply cancel cycle and should reset. or try turning off breaker, upon restoring power it should check the door latch mechinism and unlock
May 11, 2008 | Whirlpool RBS275PD Electric Single Oven
How to user self cleanning feature for oven
my oven is on f 9 cant turn off and get oven door to unlock
Feb 17, 2008 | Maytag CWG3100A Gas Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
622 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
