Question about Orion GoScope 70 (140 x 70mm) Telescope
When I look thru my new goscope 70 I see a straight vertical line Down the middle?
  • 3,186 Answers
Did you put the eyepiece into the scope? and the diagonal?
Posted on Oct 07, 2010
  • 1 more comment
  • jjurikiv Oct 08, 2010
    yes Orion says it's because I have correct image diagonal?
  • Joe Lalumia aka TelescopeMan
    A correct image diagonal should not have a LINE through the middle of it. It's simply a glass prism inside.
We get sound but just a bright line across the middle. Tv is probably a 1994 model
there is a problem with the vertical section its either defective ic, defective capacitors no supply or just loss contact.Try to check all of these and its probably help your problem.
Mar 06, 2015 | Sylvania Televison & Video
Lexmark 5075 - vertical line on copies or scans only
Clean all glass with 70% isopropal alcohol on the scanner. If the line is perfectly straight and crisp. There a spec on the glass probally causing the line.
Feb 21, 2010 | Lexmark X9575 InkJet Printer
Hi weve just bought the tv ,its a LG ,its a clear pic but has a very fine vertical line down the middle ,its like a yellow line
Vertical IC is bad or capacitor 100uf 35v in front or behind vertical IC. Call Mats for Parts 1-800-628-1118 But to make sure is Line up and down or straight across TV?
Nov 14, 2009 | RCA HD52W56 52" Rear Projection HDTV
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
What would cause a straight line threw tho middle of my tv monitor. I have a zenith model number z27h96r8.
If this is a straight white line you may have a vertical collapse. You need to either solder bad connections at Vertical IC or change the vertical IC
Apr 23, 2009 | Zenith Z27H96R 27" TV
A very thin vertical brun line in the middle
If it's a straight vertical or horizontal line always in the same place it's a panel issue which the average user even with repairing skills will not be able to reliably repair ,Sorry.
Samir
Feb 25, 2008 | Dell UltraSharp 1905FP LCD Monitor
Vertical Line in center of screen
never heard of so called card myself but ,is the line your talking about from top to bottom or from side to side in the middle?straight across middle is called horizional which means vertical problem so you have either bad capacitors 35uf 100v ,1uf 50v, or bad vertical output ic.
Dec 26, 2007 | Curtis-Mathis CM32010 TV
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Orion GoScope 70 (140 x 70mm) Telescope Logo
Top Orion Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
deton8 von Splosion
Tony Parsons
Tony Parsons
Are you an Orion Optic Expert? Answer questions, earn points and help others
