Question about Insignia IS-LCDTV32 32 in. Television
I have an Insignia NS-46E560A11 LED-LCD TV. I was watching it normally and it turned itself off. I cannot get any power to it or turn it back on (no lights on anywhere). Do you have any ideas? The TV is about 4 months old.
  • 11,361 Answers
Power supply went out, it is under warranty, get it fixed ASAP, this is not good sign taht it failed within 4 months.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Posted on Oct 07, 2010
Is modelns-46e560a11 a smart tv?
Nothing in the manual indicates that this is a smart tv.
Insignia NS 46E560A11 User Manual English
Feb 05, 2017 | Televison & Video
Ns LCD 26-09 TV not powering up
LCD TV repair - Samsung LW20M21CP not powering up ...
? 25:30
https://www.youtube.com/watch?v=zxqDLDNuCfw
Jul 8, 2013 - Uploaded by RetroGameModz
This is a documented repair of a Samsung LCD TV that I got for cheap. It was listed as not working, which is ...
Samsung LCD TV Repair - TV Won't Turn On - How to ...
? 8:23
https://www.youtube.com/watch?v=n54IurMvr6o
Apr 4, 2014 - Uploaded by ShopJimmy.com
Samsung LCD TV Repair - TV Won't Turn On - How to Replace ... or if you have standby and the TV will ...
MOST COMMON REPAIR FOR LCD - NO POWER - YouTube
Dec 02, 2015 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
I have a 55 Insignia tv it turned it self off and want come back on.i check the power and it want work either.
Won't not want.
Hi James,
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a
component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 13, 2015 | Insignia Televison & Video
I have an insignia NS-24E730A12 led tv. The bottom 1/3 of the screen has gone grey. How can I fix this? Would it be the power board, the other board, or the screen itself.
Its the board that controls the screen. It has a flat ribbon cable going to the bottom of the screen. You can find the parts you need at shopjimmy's web site.
Nov 19, 2014 | Insignia Ns-24e730a12 Rev. A Led-lcd Tv...
Insignia 22 stand mount
Keep checking Ebay. I hate that site, but sometimes they are a necessary evil.
Jun 21, 2012 | Videosecu TV Mount for Insignia...
Insignia NS-32E570A11 no picture or sound
Just FYI: I had a friend with an Insignia NS-32E570-A11 with a backlight problem, and it turned out to be one of the actual LEDs in the backlight array was burned out, causing some sort of over-voltage condition that made the backlight sometimes work, and sometimes just flicker for a moment at TV startup and then turn off. We took the panel apart and bypassed the one bad LED (it had a dark spot on it and failed continuity - you can test each LED with a continuity tester and see them light up!), and now the TV/backlight works! Be aware this is tricky bypassing the bad LED, as it is ultrasonically welded to the LED array strip (same technique used to make ICs), so you need to be a very good solderer to bypass it without it breaking the connection.
May 31, 2012 | Insignia Ns-32e570a11 32" Led Lcd...
I have a insignia ns lcd42hd 09 tv that on the left half of the screen has ghost images and sometimes vertical lines in it and i noticed when i shake it the screen goes back to normal but i have to do this...
I am also having a problem with my Insignia NS-LCD42HD-09. When I turn it on it is distorted and ghostly. It usually clears up within 10 minutes, but it can revert back at anytime. The television will be 3 year old this December. Does anyone have any advice (other than calling the Geek Squad)
Sep 07, 2011 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
I have an insignia ns-lcd37-07 giving to me, i replaced power supply board and i still don't get anything. what should be my next step?
Now the tv is turn on,tv have power LED light indicaton but no picture?Still have a clicking sound but no picture on the tv LCD screen panel?Yes,than the tv Tuner signal board that the other board 70% also might have the problems too.That the board where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 13, 2011 | Insignia NS-LCD37 37 in. LCD TV
Insignia NS-LTDVD26 won't turn on
It is always recommended to ensure that your TV is powered down before connecting or disconnecting cables. Unfortunately, it is likely that your TV requires service for the power issue.
Aug 06, 2009 | Insignia NSLTDVD26 LCD TV
Insignia IS-LCDTV32 32 in. Television Logo
343 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
