Question about Dishwashers
Where is the water heater and thermostas situated
    President:
  • 1,891 Answers
Water heater an all models you will find in the bottom of tank . it looks like the bake element in your oven ... the thermostats are locatedon the under side of the tank . and look like dime size disc with two wires to them and some times 3 . easy to find .. mm hope this helps .. ****
Posted on Oct 07, 2010
My 2000 Acura TL 3.2 had no heat. It's flowing all cold air when i turned the temperature to 90 degree. Is it my thermosta had a problems? How to fix this?
Never seen one of these cars but if in doubt ask a local mechanic to have a look for you ,in the heater hose feed to the heater could be a electric solonoid type switch that opens the valve inside the water pipe housing that the solonoid sits on and it could somehting wrong here like either the solonoid isnt operating or no power being sent to it from the climatic control computer or the plunger inside the housing is stuck ,use a mechanic recomended by a friend or relative to check the type of system ,The parts are or can be expensive and i have removed the automatic valve and fitted a tap with a manual cable from a bicycle gear change before now but i cannot recommend this as although it works other people who answer questions on here are altogether happy with some of my cowboy jobs ,but i used to be a fleet fitter with lots of own company vehicles not a dealer fitter and the owner was a refugee from a concentration camp in poland and he didnt like spending money ,an under statement to say the least
Dec 01, 2011 | 2000 Acura TL
My 2000 ford f250 v-10 heater does not work why?
Have you checked the water on the radiator? The water may be low. This will stop the heater. If the water is ok lokk for a value in the heater hoses check and see the it is opening and closing when you turn on the A/C or the heater. Check the thermosta and see if it may be stuck open.
Nov 06, 2011 | 2000 Ford F250 Super Duty Crew Cabs
Just installed a honeywell thermostat, but I can't get the clock to set or the temperature to change on it. How do I get the clock to set?
May be your thermosta setting under locked. By seeing your thermostat manual release lock and then you can satrt changing temp setting or clock setting.
Dec 02, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
Cozy wall furnace (propane) does not respond to thermostat. The pilot is lit. Furnace is 3 yrs. old and rarely works. The wire to thermostat is 20 feet.
Try jumping the two thermostat wires together to see if the heater starts. If so, replace your thermostat. If not, jump the two terminals where the thermosta twires attach to the furnace. If it starts, you have a bad thermostat wire or connection.
Jan 30, 2010 | Cozy (W352E) Heater
Changed the thermosta on my renault megan and still have no hot air in the car so could you please give me some advise please
I WOULD MAKE SURE THE WATER IS CIRCULATING, IS THE HEATER CORE BLOCKED? THE HEATER HOSES GO FROM THE ENGINE COMPARTMENT TO THE IN SIDE OF THE CAR AT SOME POINT, THRU THE FIRE WALL, TURN HEATER ON, THERE IS A SUPPLY LINE GOING IN AND A RETURN LINE COMING OUT, MAY TRY TO FLUSH THE SYSTEM OUT, GOOD LUCK
Jan 24, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
I put a new radaitor and thermosta in my 2004
Check the coolant level one more time, sounds like it could still be low.
Nov 16, 2009 | 2004 Nissan Titan
Fischer Paykel fridge freezes then stops
sounds more like a defrost problem, check your defrost timer, defrost heaters.
Feb 21, 2009 | Amana ABB1927DE Bottom Freezer...
2005 Buick Allure heat problem
well if u changed thermosta did u noticed if both were same & had little hole on top of the old 1 lot of times aftermarket dont have them & u need to drill 1 urself same spot....or could b heater core going out
Dec 12, 2008 | 2003 Buick LeSabre
Gas Boiler will supply /fire up to supply Central heating When Room thermastat turned up and switched to Heating and Hot water. When on Hot water Only will not fire up even though thermostat on hot water...
most likly or a shorted wire unhook the wire from the boiler see if it stops then if it's still is on it's in the boiler if off try unhooking it at the t-stat on the heater this should narrow it down for you dan
Jul 19, 2008 | Heating & Cooling
Frigidaire p/n 154457601
could be a heater, or a bad thermosta stalling your timer, check heater for continuity
Feb 10, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
