Question about Hisense LCD1504 15 in. Television
Hisense tl2020 will not power on
Hisense tl 2020 when power switch is turned on the power light goes red to blue screen flashes but never powers up. unplugging the tv overnight does no good and I have the remote which I tried to use to unlock
  • 4 more comments
  • lolitablunt Jun 30, 2008
    hisense will power up
  • slhb3 Jul 11, 2008
    my hisense tl 2020 will not power up, it goes from red to blue, red to blue, red to blue and will not power up
  • hennie4
    hennie4 Aug 22, 2008
    Power on/off light on front of TV goes from red to blue, red to blue. Screen flashes blue but does not turn on. I tried unplugging all night, pushed every button on the TV and remote trying to figure out what happened. All I know is that I was watching it with my daughter who turned the TV off with the button on the TV rather than the remote. A short time later it was noticed the red/blue lights were flashing. What happened and how can I fix this?
  • timoncapecod Dec 07, 2008
    I have the same problem.
  • holly2rhyme Dec 28, 2008
    my hisense tl 2020 has the same problem, it goes from red to blue, red to blue, red to blue.. it could power up after 5 minutes 2 days ago until it doesn't power up at all now.
  • dmathews Feb 01, 2009
    i have exact same problem. Last night worked fine, this morning it has same behavior as this problem.
SOURCE: HISENSE TL2020
is it in demo mode
Posted on Dec 29, 2007
SOURCE: My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON 2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
Posted on Jul 11, 2008
SOURCE: Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
Posted on Oct 12, 2008
  • 11 Answers
SOURCE: TV Sucks - Hisense TL2020
Your problem involves 4 electrolytics on the power supply board. There are (3) 1000 mfd @25 volts and (1)220 mfd @16 volts. The power supply board is situated in the middle of the set slightly off to the right. It is held in with 4 screws and has 2 small harnesses on it. The 3 1000 mfd in the set that I was repairing were all swollen at the top and when I ran them on an esr meter sure enough they were opened. The 220 actually tested ok but was a little swollen at the bottem so I changed it anyway. After replacing all caps, normal operation was restored. Thanks, Jack from Staten Island
Posted on Aug 08, 2009
  • 11 Answers
SOURCE: Hisense TL2020 - Won't come on.
Lay unit flat on table, remove stand and rear cover. When you remove back, you will see a power supply board in the middle of the set.There are (3)1000mfd @25 volt electroltics and (1)220mfd @16 volt electrltyic that have to be replaced to return to normal operation. This is not something to try if you are a novice as you must observe polarity when installing these caps. But this repair WILL return set to normal operation.
Screen pulses white. off and on, lite on front goes from green to red. model is Hisense TL2020
that problem is usually cause of shorted fly-back transformer that give a very high voltage you can find that by hanging all secondary connection of fly-back then power it again then use your multimeter and range it to dc then ground the black prove to the body of your unit test the b-plus voltage if the supply is flickering it means your fly-back is shorted and if the supply is stable it means you have a shorted diode in secondary thank you
Mar 05, 2011 | Hisense TL-3220 Television
Jul 30, 2009 | Hisense TL1700 17 in. LCD Television
Jul 23, 2009 | Hisense TL1700 17 in. LCD Television
I have a Hisense tl 2020 and last night when turned it on I had no sound
Try first leaving the unit unplugged from main for one hour.
This will drain power and reset circuits.
Check also eventual cable connections, receiver box or device connected.
If that does not solve the problem, then there is an internal fault, probably on audio circuits or I/O board.
May 21, 2009 | Televison & Video
power supply issue..may be some bad capacitors simply replace them....dada....your prob solved
happy to help
Aug 18, 2017 | Hisense TL1700 17 in. LCD Television
Hisense TL2020 It does not turned on.
check your power output if ok replace your mainboard
Sep 19, 2008 | Televison & Video
HISENSE TV MODEL TL 2020 IS NOT SHOWING ANY PICTURE THE INDICATOR LIGHT IS HUST BLINKING RED & BLUE PLEASE HELP
3 1000uf 16 volt power supply section output capacitor bad.
Solution: Remove and replace with a new caps.
Mar 25, 2008 | Televison & Video
Hisense TL2020 TV repairing
To unlock your Tl2020 with a universal remote just go into the menu and select V chip setting. The password from the factory is four zeros (0 0 0 0 ). Once you get in you will the letter "B" nect to everything. Set everything to the letter "U". Then, turn off the television. The set should be unlocked now. Good luck !
Frank
Sep 15, 2007 | Hisense TL1700 17 in. LCD Television
Hisense LCD1504 15 in. Television Logo
207 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
