Question about Roper RS25AEXLQ Side by Side Refrigerator
Water Doesn't get in
Being helpful my son cleaned the Refrigerator with one side open for about 20 to 30 minutes. Refrigerator started sweating afterwards. Went to Riverfest about 6hrs. came back home Refrigerator sweating and Ice tray filled with frozen solid ice. the water will not go into the ice tray.
Water won't go into ice maker but will run out water side
Posted on Jun 02, 2008
    Problem Solver:
  • 14 Answers
Once you get the ice maker solid block cleaned out, you need to re-prime it by pouring in fresh water using a cup to just below the blades. It will not kick out ice and refill until the temperature sensor senses the frozen ice. With no water in the tray, it can't sense. It must dump to trigger the refill.
Posted on May 29, 2008
Icemaker doesn't work....It doesn't fill with water???
Check your water supply ,make sure valves are open. make sure ice maker arm is in down position
Jun 22, 2011 | KitchenAid Architect 25.3 Cu. Ft....
We have a 5 yo Maytag side-by-side frig. A few days ago the frig started making a buzzing sound that happens every so many minutes and lasts a couple of min. Today it started dripping water from the port...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Maytag Refrigerators
Side wall of fridge hot to touch
This is due to the condenser overheating. Follow this link for instructions on repairing.
http://www.fixya.com/support/r4694132-hot_door_seal_rail_divider_strip_between
May 11, 2010 | Whirlpool ED5FTGX Side by Side...
Cleaning the water dispenser from old mold and etc.it is all black inside where the tube for the water comes out and all up above inside
Very common issue with all dispenser models. Can be caused by many things, depending on the make and model. Basic issues are due to warm ambiant air mixing with cooled air at the dispenser flap area...Failure of the low wattage heater that controls the Dew Point temperature (prevents sweating). This sweating can cause the mechnical and electrical parts to rust and or fail. Without a model #, can't advise on access...as some can be difficult.
Ric
Mar 08, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Inside sweating and turning to ice
sounds like condensation. place a film of vasoline on mating surface of gasket and make sure door is shutting good.
Jan 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer door frame is extremely hot
The frame should be warm but not excessively hot. This is called an anti sweat heater. It's purpose is simply to keep the door from sweating under normal operation. It sounds as though this heater is going out. You may want to have it replaced very soon. Once it completely fails the freezer door will start to sweat and cause water to pool on your floor. Hope this helps, good luck!
Nov 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
GE refrigerator model GSH25KGRB # HG256690 NO WATER OUT DOOR.
I use a hair dryer to defraust the door. This refrigerator is very sensitive to tempature change. When it gets cold out and you have the tempature on high, the water freezes in the door.
I cover the opening of the freezor with a piece of plastic cut to fit. I tape it in place with blue tape. I tape the door switch down so the you can test the water to see when it is running again. I use the hair dryer With the door open I concentrate the heat on the right side center section. It usually takes about thirty minutes. I put a glass in the water compartment and I try the water every few minutes until it flows. Finally, I run the water for two or three minutes after it starts to flow to make sure all of the frozen water is clear. Thom
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Why is the high side pressure so high?
clean the condenser .or you have managed to put in a lot I mean a lot of noncondenseables (AIR) in the system you need a contractor with recovery equipment and to follow proper evacuation and recharging procedures.. if ya run like this for long you will be buying new equipment.. good luck Tom
Jun 19, 2009 | Heating & Cooling
Water leaking at bottom of freezer side
that is not a leakage it might be sweating of the chilled line. and to collect this water there will be a tray fixed below the freeser or refrigerator exactly on the condensor so check this tray is in its place.
May 28, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Roper RS25AEXLQ Side by Side Refrigerator Logo
192 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
