Question about Sony DVP-NS51P DVD Player
Television displays NO SIGNAL when trying to play a DVD.al
  • 10,594 Answers
Hi.
We here at FixYa hope that our esteemed colleague could completely satisfy your current inquiry.
If your issue has not yet been rectified, I will be glad to assist you further.
Should you desire any assistance, please reply to this message and Thanks for choosing FixYa.
Posted on Oct 08, 2010
Have a element tv some of the stations now are either all jumping squiggly or just outright blank, no sound either, whats wrong? Its only 3 months old.
Can you play a DVD ok in it? If that displays ok, then the problem is whichever way you get your television signal, cable, satellite, to air etc. Bad connections is the main culprit of a weak or confused signal.
If the picture is bad on DVD, take the set back.
Feb 02, 2016 | Element Televison & Video
What does DTA mean on my tv/dvd 22" tv
DTA is a Digital Television Adapter (digital-to-analog converter box) It is a television tuner that receives a digital television transmission and converts the digital signal into an analog signal that can be received and displayed on a older analog tv.
Jun 06, 2013 | Televison & Video
Vizio E370lv television saysno signal but plays dvds
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 25, 2012 | Vizio GV42L 42 in. LCD Television
Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
May 05, 2010 | Toshiba SDV395 DVD Player/VCR
Will not play movie - continually displays "Copyrighted Movie HDMI HDCP frail with TV "
There are several reasons for this but exactly knowing which is one isn't possible without first knowing what products you are using such as your connector, player and television.
HDCP is the acronym for high definition content protection. It is a digital signature embedded into the disc software designed to prevent copying of the disc. On certain occasions due to the hardware such as the HDMI port on the television, or the connection type, the signal will not be allowed to pass through. The HDMI port on the television may not be HDCP compliant for example. In this case if possible you can try a different HDMI input on the TV if available or use the component video input instead.
Jan 09, 2010 | LG DR787T DVD Recorder
Wave in my LCD Flat Screen
try a dvd on your tv.sounds like a signal source problem.if you see the wave playing a dvd then you have a defective digital main pcb or the panel is going bad.
Jul 17, 2009 | Toshiba 42HP66 42 in. LCD Television
No signal
Try this.
1. Take note of what input you are using to your television. AV1 or AV2 or Component 1 Component 2.
2. On the remote, toggle the input selection to corresponding input for your DVD.
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
Can't display Pal on My Sony 57" KP-57WS520
There are probably a few problems here. What are you using to play the disc? Some NTSC players will "play" a PAL disc but interpret it as NTSC with the symptom you are describing. You need a DVD player that will play PAL. Many of those will output NTSC directly when set up to do so. The other alternative is to have a PAL compatible player that will output PAL into the converter. To narrow this down specifically, please post the model numbers and the connection scheme for your equipment. Once I understand your current setup, I should be able to describe a method to get this to work for you.
Dan
Dec 16, 2008 | Sony KP-57WS520 57" Rear Projection...
Hitachi 26LD6600 no signal coming up
You have to switch the Television to the correct input line. This can be done by pressing an Input, or AV of function button on the television remote control.
Nov 08, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Sony DVP-NS51P DVD Player Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
