Question about Samsung SCX-4300 Monochrome Laser Multifunction Printer
Scanner Error displayed on screen - Samsung SCX-4300 Monochrome Laser Multifunction Printer
    Master:
  • 635 Answers
Try reinstalling the driver...
Posted on Oct 07, 2010
Scanner Error 22 Displayed on printer screen
Turn of the Printer, disconnect the power and data cabels and then uninstall the drivers on computer and reinstall afresh driver then reconnet the printer this might resolve your error.
Apr 03, 2014 | Office Equipment & Supplies
I have canon ir3750. When I switch on the machine it goes to the start screen , The screen displays wait message, for about 3 minutes and than nothing happens and then the error code message comes up...
This is an error in the communication with the scanner. Check or reseat the connectors from the scanner , check to see if the scanner even moves during initialization ( power supply for it may be bad ), check/replace reader controller, scanner board, or main controller of copier. I've not seen this error before. Good luck.
Jun 23, 2011 | Canon imageRUNNER 5000 Copier
Scanner error 12 on hp laserjet m1005
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
Apr 22, 2011 | HP LaserJet M1005 All-In-One Printer
Scanner does not work. 12 scanner error on the display
scanner does not work. 12 scanner error on the display
Jun 25, 2010 | HP LaserJet M1005 Printer
SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
SCANNER LOCKED IS ON THE DISPLAY SCREEN I HAVE CHECKED THE GREEN BUTTON UNDER THE PAPER TRAY AND THAT IS SET TO UNLOCK. WHEN I TRY TO PRINT THE DISPLAY SCREEN SAYS SCANNER ERROR AND THE SCANNER LOCKED
Hi, what you want to do is, first; (shutdown) your Scanner, next (shutdown) the computer. Disconnect the scanner, and unplug it from the outlet. Disconnect scanner cables from the computer; Note: do not change anything on the computer. Reconnect cables to the computer. Plug scanner back into the power outlet; turn on computer, turn scanner on. This may clear the (Freeze); but the (Error) might appear again. Thanks paul7of9
Jan 05, 2010 | Xerox Phaser 6110 Laser Printer
I have Canon IR-C5185i. Just assembled out of the box. Powered on. Message displays with error E0000732-8888 and I am instructed to "turn switch off and on". What could be wrong?
When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below.
- E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.)
- E732-8888 can be displayed when a different scanner is connected to this machine.
Nov 17, 2009 | Canon ImageRunner 2220N Copier
When I turn on a scanner it displays error
E34 refers to abnormalities in the Shading Solenoid Connection.(Lower side). If you open the scanner top cover and press the 'start' button, you will see two white strips (plastic) coming out. If it does not come out there is a problem. (This is used for Color balancing). Check if the connection to this are perfect. You may need to remove the plastic cover near ****** roller (The one which is in the bottom). Ensure that the plastic is not damaged.
S. Mohan Chennai, India
Oct 08, 2009 | Canon DR-9080C Path-Through Scanner
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Mar 19, 2009 | HP LaserJet M1005 All-In-One Printer
Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
53 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
