Question about Dell E197FP LCD Monitor
My Dell LCD E196FPf turns on and stays on, but the screen is so dark I barely make out the little box that comes up when no VGA is plugged in. The screen is about 4 years old and saw constant use. How can I fix this "black screen"?
    Master:
  • 645 Answers
U will have to take it for repair.
The backlight might have gone out.
Posted on Oct 07, 2010
  • claughhunn Oct 07, 2010
    How do I fix the baklight then?
  • Mohammed Ebrahim M
    Mohammed Ebrahim M Oct 07, 2010
    There is a backlight board on the monitor.
    Try replacing it.
    There are a lot of help files on the internet regarding that.
Dark sgreen
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 25, 2012 | Dell Latitude C610 Notebook
No screen
May 13, 2012 | Dell Computers & Internet
Laptop starts up then the screen stays black
Apr 08, 2012 | Computers & Internet
The screen will not come on when the computer comes on on my dell xps notebook. The laptop comes on but the screen stays black when turned on.
I had a similar problem with a one year old Dell laptop, and it turned out that the screen was OK on battery power, but when you plugged it in to the AC charger the screen went very dark. It turned out to be the LCD backlight inverter, which I purchased from a fellow in Florida for about $16 and installed by following the instructions at http://www.insidemylaptop.com/remove-replace-lcd-screen-video-cable-inverter-on-dell-laptops/ . Hope this helps you out a bit...
Mar 29, 2010 | Dell Studio XPS 16 Notebook
I have a Dell D600. It starts up to boot page and after 3-5 seconds the picture disappears but the laptop is still running. The indicator light near the power button with a 9 on it stays lit.
I have a similar problem currently. Boot and try pressing Fn+Up arrow repeatedly to raise brightness. Then flick the little button right above your volume control that tells the laptop youve closed it. If you see the screen flicker on/off then its the button. Otherwise reboot and try shining a light at the screen from different angles and see if you can see dark images. If you can see windows boot up but dark, then it is almost certainly your LCDs backlight. If you can't see dark images, next try using the VGA output plug at the back of your laptop to connect to a different monitor. Within less than 1 minute you should see the image on the external screen. If not, try pressing Fn+F8 a few times to toggle the output. If still no picture on the external screen your video card might be fried. If you do get a picture on the external with or without seeing dark images on the laptop, then it is a problem with either the LCD screen, it's inverter, or the screens flex cable. Check Dell support for your systems original parts list HERE. You will need your laptops Service Tag number, which is on a sticker on the bottom of your laptop.
Hope this helps, Good luck.
Mar 06, 2010 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
Dell monitor E196FPF when computor turns off monitor stays on screen keeps changing colours,have to turn main power supply any ideas please.regards phil
This sounds like a "Screen Saver" in the monitor ... go in to the monitor's Setup and disable the screen saver.
Dec 10, 2009 | Computers & Internet
Screen is coming on and immediately turns dark -
i had the same problem. i had it plugged into my mac book pro. i used the "detect displays" and it fixed the problem. switching b/n dvi & vga seems to require the use of detect displays.
Aug 22, 2009 | Computers & Internet
My dell E196FPF 19'' lcd screen acting strange!
Are You using a extention cord or a ups that is not funtioning properly....?? if yes try connecting the power for the monitor seperately or directly to a plug base...
this mi8 solve ur problem
Apr 10, 2009 | Dell E177FP LCD Monitor
Screen went dark (almost completely)
check your power cord and make sure it's plugged in all the way, and if it is, check your brightness setting.
Usually it's the Fn key + an arrow key. Make sure the brightness is up all the way
Dec 12, 2007 | Dell Inspiron 6000 Notebook
Dell E197FP LCD Monitor Logo
316 people viewed this question
Alun Cox
