Question about Compaq Presario 5005 (470014-507) PC Desktop
How to remove front cover of compaq 5320
Any ideas?? I don't have a manual
    Genius:
  • 1,226 Answers
You can find usermanual here:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=compaq+5320&submit.x=2&submit.y=6
Find any push lock at the bottom of the case or in the side then you can open it.
may this help,
melnavz
PS:
Pls do not rate me if the solution cannot resolve the problem, but if it is invaluable the rate me fixya. thanks.
Posted on May 29, 2008
How do you remove a hard-drive on a Compaq Presario SR2050NX
Attached is the link to the service manual for your desktop. It gives complete instructions on how to open the tower and remove the drive.
Service Manual
Go to page 4 of the manual in case you have opened the chassis and removed the front cover.
Note: You would need a philips head screw driver for the job. Do name the screws from place you took them out. otherwise it would be confusing.
Thanks for using Fixya
Proton
Jul 07, 2012 | HP Compaq Presario SR2050NX PC Desktop
How do I replace a power supply in a hp compaq d530 desktop? From the front, behind, top, or bottom?
the top cover should slide off from the back end remove any swrews at back before sliding cover
Mar 05, 2011 | HP Compaq d530 SFF PC Desktop
How to remove HDD in compaq presario sr2030nx
After removing the side cover, you will notice 4 black tabs behind the front bezel under the hard drive, bend these back just enough to let the front cover release at the bottom, then press the green square at the top to release the front plastic bezel. After you carefully pull the front off, you will need to remove the cables [power and IDE] pull up on the green tab that locks the guide screw on the hard drive and push it forward out of the case
Dec 11, 2009 | HP Compaq Presario SR2030NX PC Desktop
Front plate removal
You should find screws clips, or both on the back side of the front section. Sometimes you need to push it off from the back. HP can be complicated sometimes.
May 29, 2008 | Compaq Presario 5005 (470014-507) PC...
Keyboard
unscrew the screws at the back o f the laptop..Now you can remove the keyboard with the help of a FLAT screw driver..
Cheers...
Jan 08, 2008 | Averatec 5500 Notebook
Sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Jan 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
GArmin c340
Facing the GPS system, remove the front cover with your nail or something sharp and under it you will find a reset button. If needed, refer to page 30 in this manual (different model but same principle, see website below) for pictures:
www.tramsoft.ch/downloads/garmin/streetpilot-c550_owners-manual.pdf
Please don’t forget to rate my answer.
Oct 11, 2007 | Garmin StreetPilot c340 GPS Receiver
Computer face removal
Hi, In order to be able to remove the front panel cover, you must remove both side cover of the computer (remove rear screw and slide back). To remove the front panel: 1. Depress and hold the top square button (left side, top front) of the panel cover; 2. Depress the lower left tab; 3. Press on the right tab; 4. Front panel may then be removed. This is better explained in the service manual. It is available on line from the Compaq site/Product Information/Manual file name c00311113.pdf All other information and manuals on the same page with no charge. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | Panasonic RR-US360 Digital Voice Recorder
Adding a network card in compaq ML530
If you have the tower model. Swing open the front bezel left to right. Then lift up to remove it. Chap 3 of your manual. Using a #15 Torqx allen wrench provided on the back of the unit remove the cover plate screws to gain access (Chap 2 of your manual). The rest should be simple.
Sep 15, 2007 | HP Compaq ProLiant ML530 Server
Compaq Presario 5005 (470014-507) PC Desktop Logo
574 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
