Sansui TVS2746A no audio
My TV's audio is muted when its connected to cable. I can play movies on the VCR though with the audio.
Any help is appreciated,
Thanks,
Hemanth
Try getting a booster. They cost about 15 bucks at Radio Shack. Also, if you connect your cable TV through the VCR make sure it's on the right channel combo: some of them call for ch. 3 or 4 setting on the TV and the VCR set to 60 - there are a number of different combos, so can't tell unless you check your mfr specs.
You can also have your cable company come out and check their line: you'd be surprised how many problems are caused by the way they wired their line in.
Posted on Nov 14, 2008
Sounds not working on super nintendo
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.well I guess that you will have to hook it up to a DVD player or a VCR player to have it work on a digital tv
Note: pictured above is the original Super NES. The redesigned Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the VCR.
Place the yellow end of the Stereo AV Cable into the Video "in" on the back of the VCR.
Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono VCR with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV Cable into the "multi out" connector on the back of the Control Deck.
After system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Slide the Power Switch on (toward Game Pak).
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen. You are ready to play!
Recording Game Play
Set up the Super NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Jan 31, 2013 | Nintendo Super NES Console
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
I have a sansui vhf6010 vcr. i need to hook it up to my cable dvr to copy a recording. how do i do this? thanks!
connect the cable from the tv to the "IN" of the vcr. then connect the "OUT" of the vcr to the tv. play the program on your tv and push record on the vcr. you have to watch what you're recording, but at least it will record.
Dec 30, 2008 | Sansui VHF6010 VHS VCR
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Can only get DVD audio when hooking it up to Goldstar VCR...
The DVD must be connected with the RCA jacks-plugs [usually black & red] to the INPUT of the VCR, not to the RF connector. You must press the VCR\TV button to VCR so that the VCR takes control.When you place a DVD movie or AUDIO program it could be copied to the VCR. or played through the VCR.
Nov 11, 2008 | Televison & Video
No sound on PLTV 4250
Easy! If you have a VCR,put a VHS tape in the VCR,run the video cable behind the TV and the audio cable from the VCR to a hi fi receiver/speaker(cd input or tape input.)
If you have sound coming out from the HI FI,go ahead and plug the audio connection along with the video connection behind the tv.If there is no sound, it could be:
A. your TV speaker is completed its mission-;o)Blown speaker.
B. you are on TV MUTE!
C. your audio cable is defective(small chance,cause you have left and right!)
D. your connection was incorrect.
solutiondoct
Oct 13, 2008 | Protron PLTV-4250 42 in. LCD Television
Sansui vrdvd5000- need manual
Hi seemaile,
All my searches resulted to negative which leads me to believe that there no readily available user manual for the Sansui VR DVD5000.
Sorry.
May 26, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sanyo TV
If I understand your posting/description right, you have:
1, a Sanyo TV with only 1 video input;
2. you have a DVD player with only video output; and
3. you have a VCR (which I will assume to be with both video input and output).
Your query, if I may clarify, is how to hook them up so that you need not connect/disconnect any video cable when you want to switch video source from either DVD or VCR.
If that is what you want, then connect:
a. audio/video OUT of your DVD to audio/video IN of the VCR;
b. audio/video OUT of your VCR to audio/video IN of the TV.
The above described connection would allow you to:
i. watch DVD movies on your TV (your VCR must be powered ON and set to Video INput, your TV must be powered ON & set to Video INput);
ii. watch tape movies from your VCR without disconnecting/connecting cables.
Additionally, this arrangement would allow you to record DVD movies in your VCR. Further, connecting your cable/aerial to the RF INput of your VCR would allow you to do the same with a TV/Cable program.
Incidentally, if one of your units (TV, VCR, DVD) would only have a single audio input, it is still possible since some models uses the white audio RCA connector as either left or mono, the red is right. You can also use a 2 female RCA to 1 RCA male adapter as shown below to joint the red/white audio.
Hope this be of some idea/help. Pls post back how things turned out or should you require additional information.
Good luck and kind regards.
Nov 19, 2007 | Sanyo DS32224 TV
Using a VCR with it.
Hi, Based on your post/description, a common installation/connection would be: 1. Ant/Cable in to the RF INput of the VCR (this is assuming that your cable TV is cable/F output and not the audio/video RCA output); 2. A short RG59 cable with F connectors at both ends should connect RF OUT of VCR to ANT/CABLE IN of TV. 3. With the VCR off, the cable would connect automatically to the TV and channel selection is thru your TV. 4. With the VCR on, The TV must be set to either 3 or 4, channel selection may be done on the VCR, TV programs can be recorded, video tapes can be played. A variation: Another would be to use the Audio/Video OUTput of the VCR to the Audio/Video INput of the TV (assuming it's got one). The TV must be set to Video to watch cable, VCR. Channel selection would be thru the VCR. Hope this be of some idea/help. Post back should you need additional information. Good luck and kind regards.
Sep 09, 2007 | RCA F25216BC 25" TV
JVC Tv Constant Blue screen
if you have the remote control number RM-C203 with your tv than try noise muting in your menu settings mine did the same thing i just put noise muting off and it worked for me
Aug 06, 2007 | JVC AV-27530 27" TV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
