Question about Whirlpool Refrigerators
Fridge seems to run for ever without chipping out
  • Whirlpool Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
Fridge seems to run too frequently
How old is the fridge? Newer units will run more frequently and make "running" noises.
Apr 30, 2012 | Kenmore Refrigerators
My dometic fridge, (3 Way) for the past couple years takes quite a while to reach it's normal operating temp. I'm talking anywhere from 10 to 15 hours. Once it reaches it normal temp it stays cold until we...
Have you tried running it without the fan? I know it sounds funny but it has to get hot (outside the fridge) to get cold inside. Shut fan off and see what happens. Also, keep in mind the more items you put in it that are already cold, or frozen, the faster it will cool inside the fridge. Also take a look up the back of the fridge, with outside cover off to make sure no big wasp nests or similar up there. May need to remove cover at roof and look down if you can't see too good from back of fridge vent.
Jun 21, 2010 | Dometic RM2652 Refrigerator
Honeywell 88031 fridge not working
Just in conversation, what you are referring to is the Peltier heating/cooling components. They are wired in parallel and require a power supply to activate them. These elements have 2 junctions, a hot side and a cold side. Depending on what temperature you you require, the polarities are reversed.Very possible,some of the junctions are faulty assuming you have checked the power supply. Best to replace all the peltier modules.
Oct 03, 2009 | U-Line 15R Compact Refrigerator
Underneath the freezer drawer builds up with ice (have to chip it off a (makes opening the freezer difficult) and sometimes when I open one of the fridge doors (does not matter which door) water pools...
it seem that you have a clogged freezer drain. you can fix this by first turn off the unit leve all door and let it thaw about 4 to 6 hours or longer. if this doesnt cure the problem then repeat above procedure but this time open the plastic cover on the freezer and clean out the drain make sure all drain are unclogged also while your at it check the operation of the drain heater pan underneath the unit. and lso check the operation of the defrost timer. hope it help you.
Sep 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Maytag MSD2356AEW Side by Side Fridge not Cooling enough
Deforster not kicking in. There is a chip that is supposoed to kick in thte Auto Deforst on the frezzer side. It fails and the system freezes up and can not circulate cold air form the freezer side to the Fridge side. Simple repair, but yo will needed a service tech for this.
Jul 20, 2008 | Refrigerators
My Whirlpool ARC7472 fridge freezer has stopped cooling both feezer and fridge. Removal of the cover in the freezer shows no ice build up, the fan runs, but no cooling effect in the chiller pipework to the...
it is low on refrigerant and has a sealed system leak without the proper leak detection equiptment and charging tools best left to the local ref tech
Apr 28, 2008 | Refrigerators
My amana scd23vbw
first do you have any heat from the compressor ? ( back bottom of the fridge) is the evaporator fan running. let me know and I can help..
Sep 05, 2007 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
