Question about Toshiba 50HX70 50" Rear Projection Television
50hx70 picture color stream hd1. when i go to the covergence it does not let me centralise the red color. what part do i need to purchase? for this problem to be resolved.
  • Toshiba Master
  • 8,617 Answers
You need to replace both the convergence ICs number STK392-110 you can get replacement ICs at the following link and they provide free instalation instructions with pics so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 29, 2008
Magic Focus button will not line up picture. Red and green colors shadow images.
The tv have a problems known as a convergence picture problems it is dead.The tv have any colors lines like R,G,B mis alignments,tv have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes of these problems.The tv convergence board must have to repair like replacing like 2 STk covergence ICS and some or all of it resistors too.To fixed the tv convegence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 02, 2011 | Hitachi 53SDX01B 53" Rear Projection...
My Mitsu rear-projection WS-B55 was purchased in '03 or so. Now the screen is sometimes turning red. I can do a system reset, and the color goes back to normal. Then it eventually (maybe days later)...
No,pictures go all red?Pictures have colors shaded shadows or 3D pictures look alike?Yes,than the tv it is developing a problem known as a convergence problems it dying.The tv convergence board have problems,must be resoldering those 2 or replaced 2 STK covergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the convergence picture problems.The shop,will cost u like $300-350 for diagnose the problems and do all the resoldering work or replaces those parts on the tv convergence board.
Apr 08, 2011 | Mitsubishi WS-55809 55" Rear Projection...
Tv just looks like i folded picture need help on configurance set
The tv have a problems known as a convergence problems,it dead.U have tools,soldering iron,solders.U know how to do solders?Try Ebay.com to buy a convergence Fuse(FL231).The big block of plastic call the FBT.Resolder the FBT.The 3 three fuses caps on (FL231) beside it.The covergence fuse cap in middle is dead,replaced the covergence fuse cap in the middle will solved ur convergence problems.
Jul 17, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Reddish colour (not proper white balanced)
wondreful to hear from you friend. i would like to know if you are having more problems besides the red color. i want to say you need to spruce up your convergence, but i could use more information. does the picture seemsomewhat blurry or does the images double some. if so then i would get me a covergence kit at tvrepairworld.com. if not then i would purchase a fluid change kit at tvrepairkits.com they will send you a kit with downloadable easy to follow instructions. i hope these instructions help. please rate my solution.
Nov 18, 2009 | Sony KP-53HS30 53" Rear Projection...
I CAN RECORD FROM MY TV BUT I CANT GET MY ARCHOS 5 TO SHOW ON THE TV ,WHEN I PLUG MY ARCHOS INTO THE DVR STATION THE OPTION TO SET IT UP FOR TV DOES NOT COME UP . I WOULD BE VERY GREAT FULL FOR ANY HELP,...
You should swtch your TV to the video mode on to the video output chosen for the device. Check the video connecion type by following the output cables from the DVR station or charging dock to to TV. it could be video 1, 2, 3 HDMI, Color stream HD1 , Color stream HD 2, by scrolling down on the video mode list you should get the picture on on of them with correct video mode. or like i was saying follow the output cable from dvr station to Tv to see which video mode it was connected.
Jul 30, 2009 | Archos 5 MP3 Player
Toshiba projection tv
check for solder bridging between the IC pins. also make sure the wire connections are back in the proper locations
Feb 14, 2008 | Toshiba 50HX70 50" Rear Projection...
Picture & Color Distorted
Convergance IC replace.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 50HX70 50" Rear Projection...
Hdtv/ direct tv service
more then likely you are using component input if you are check to make shore they are hooked up correctly red to red green to green and blue to blue if they are you might have a bad cable I have not seen a color stream board bad yet
Oct 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Toshiba 50HX70 convergence problem
replace convergence ic,s part # stk392-110, you will need two of them.
May 12, 2007 | Toshiba 50HX70 50" Rear Projection...
Toshiba 50HX70 50" Rear Projection Television Logo
176 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
