Question about Zoltrix Zling U2 MP3 Player
I have a Telefunken MP3 player - TEL 8350 - N126 but no operating instructions for recording, playback, select etc. Where can I get a copy of these instructions ? Thank you
Why doesn't my Telefunken 32 inch LED media player not supporting file formats for most movies when playing through USB input
Does not have all of the codecs needed to play videos. Common problem. Your Blu ray players are much more universal and give much better playback results.
Oct 11, 2016 | Audio Players & Recorders
How do i download music too my mp3 when i try it only shows me the record file
For an MP3 player the easiest way is to copy and paste. Open you music folder on you computer. Highlight the music you want on your MP3 player. Right click and select Copy. Open your MP3 player foler. Right click and select paste. All music you selected should transfer to the MP3 player quickly.
Aug 29, 2011 | Sylvania SMPK2062 MP3 Player
I downloaded a .msf file from a Sony audio recorder. Please advice how I could playback this audio .msf file.
Hi!
It seems like you've downloaded the wrong files...
As mentioned at Sony's FAQ:
MSGLIST.MSF is a file that contains information such as the order of folders, playback order of audio files and recording date and time. If user connects the recorder to the computer, the MSGLIST.MSF files are displayed but do not delete or change these files. If these files are operated, the saved files may be broken or the recorder may not work correctly.
The right way to copy your recordings is explained here...
If you are satisfied, rate my solution with 4 "thumbs" or (even better) add a testimonial.
Good luck and Best regards,
Pelu.
Apr 29, 2011 | Sony Audio Players & Recorders
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
How to record / how to avoid recording
search over web for instruction mannual. for best results use google search engine.
Jan 22, 2009 | Audio Players & Recorders
I am trying to record from my dvr to my magnavox 10d6 recorder
Connect the yellow/red/white out from the VCR to the same inputs on the 2160. Press setup. select general. select video select video input. select L1 or L2. press ok. select video or s-video.
press setup to exit.
select HDD or DVD (whichever you want to record to)
use source or channel to select L1 or L2
press rec mode to select sp/lp/ep/etc
press record to start recording
start playback on the input device
press stop to stop recording.
The manual is available as a PDF file on the web. It would save a lot of typing...
tom
Jan 20, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Lost instruction
ok lamar230990 to turn your mp3 player to msc mode disconnect it from the computer and turn it on. once it is on go to settings and scroll down to protocol and click on it with the play/pause button. this should turn it to msc mode then connect back in to the computer and go to this site to download the software www.rcaaudiovideo.com
Oct 22, 2008 | RCA M4204 MP3 Player
Telefunken MP3 Player Model No: TMP305 instructions
Thank you for your enquiry. Yes I have solved my problem with my Telefunken MP3 305,by ringing their
customer care centre on, 1300 366 155. and they were most obliging by way of emailing me the instructions and allowing me to download them. They are also sending me them by landmail in case I have any difficulty with the downloading.
I hope this information will be helpful to you in the future .
Your's respectfully jock 123.
Sep 22, 2008 | Audio Players & Recorders
Zoltrix Zling U2 MP3 Player Logo
207 people viewed this question
Top Zoltrix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Zoltrix Audio Player and Recorder Expert? Answer questions, earn points and help others
