Question about Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
How do i remove the cover to get at the belt chamber???
  • 377 Answers
I can not offer you specifics, but this URL will give you exploded views that should be of some assistance:
http://www.VacPartsWarehouse.com/Hoover-U8145-s/1571.htm
It appears that there are not belts, but gear drives for the brushes. I hope this helps you in some way.
Paul
Posted on Oct 07, 2010
  • pwillitz Oct 07, 2010
    I am sorry you did not find my solution to be of help to you.
How to replace belt on dirt ***** broomvac
Remove the cover over the Beater Bar
Aug 18, 2014 | Vacuums
There is a black residue coming from the motor in the scent chamber. what could cause that/
Amanda:
The black residue is probably coming from the drive belt that goes from the motor to the beater bar. Lay the machine on it's back, and remove the foot plate (or cover plate for the belt) and check the belt for wear.
Feb 02, 2014 | Filter Queen Canister Vacuum Model 112C...
How do I remove the bottom cover on powermate #26412690 to replace belt?
Squeeze in on each side of the cover with the headlight lense to remove it. There are two screws under the cover you will need to remove. Then flip the power nozzle over and insert a screwdriver between the base and top cover on the left and right sides to release the catch to remove the top cover to get to the belt.
Feb 10, 2018 | Kenmore Vacuums
The fan housing tube is cracked just below the bottom clamp. How to replace
Its not to difficult, its just requires some patience. The first thing Ill recommend is removing the handle from the fan chamber tube, it should come apart pretty easily simply by turning the flange that threads it together. Watch the video I've attached it explains the removal of the handle. The bottom of the bag has a small metal spring clip that holds it onto the handle, just lift that off. Set the whole thing to the side. The cord will still be attached to the base, which is fine, its just easier to work on it when all that's set aside. You'll want to flip it over like you're changing the belt, remove the baseplate screws and pull it off. That'll expose the motor, belt, brushroll, fan chamber and dirt intake tube. Remove the belt, set it and the brushroll aside. On the right hand side there's one screw that holds the dirt intake tube on and two screws on the other side that hold the motor in. Remove them all. The dirt intake tube should slide out, set it aside. You'll need to pull the motor off the other side by wiggling it back and forth until it pops free from the fan chamber. Its just a friction fit. The chamber should be free, you'll need to just rotate it around to remove it from the base and it should come out. To reinstall the new one you just put it back in the opening on the base, refit the fan and motor back into it, hold the dirt intake tube on the other side and fit it back in gently. Oreck's don't have a rats nest of wiring or moving parts so just keep an eye on the screws and be patient!
Dec 19, 2017 | Oreck XL21 Bagged Upright Vacuum
My progessive kenmore vac is having a buring smell coming from it. I read here on this website to check the belt but I cant even get to the belt without breaking the thing into peices. What if I break the...
Look under the bottom. Locate the Grill section covering the brushes. This will tilt down when opened. Try either side to see which part flips open. When open, pull the brush toward you. It will pop out in your direction. Lift out the brush along with the Belt. The belt sits in a groove and it may be soft by now. Remove it. Get a new Belt at WalMart. Slip the new belt end up and around the motor pulley and the other end around the brush pulley. The belt will tend to be very tight and need your muscles. It wont brake, so use some strength to get a good connection. When the belt is on both the motor pulley and the brush pulley, push the brush back into the chamber and lock in place. Your done.
Jan 22, 2012 | Kenmore 22812 Bagged Canister Vacuum
How do I replace the v-belt in my Hoover Multi Chamber Cyclonic vacuum
its not the v-belt its the idler pully, ours did the same thing, need to get it warrentied
Dec 23, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Belt squeels when the roller starts turning. only used about 10 times. Small belt under cover is very loose, but it shouldn't be worn out after only about 10 uses. does the small bell just rest on the belt...
Normally the belts should last longer than 10 uses, but if the roller brush catches something like a rug fringe it can cause the belt to slip off or even stretch to the point it won't turn the brush. In case you need a new belt here is a link and here is also a link to the manual. Hope it helps!
Hoover Mach5 Belt
Mach5 Manual
Dec 16, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Shark v1510 How do I replace the belt?
remove the outside sliding cover... remove 2 screw in from of housing, and also the screw holding the wheel on the brush head cap side of the housing. Once screws are rmoved, you can remove brush head cap and belt cover. Pull down on belt cover to remove. It is held by screw crossing the top of the cover from the side. Belts are hard to find, but can be ordered from shark web site (2) for 7.95 and shipping.
I had the same problem. Some one should stock these belts in the states, because Shark outsources thier call center to India, which sucks. It took 20 minutes on the phone to communicate through the noise and language barrier just to order a belt!
Oct 23, 2009 | Vacuums
Poor suction-need to know how to remove & clean filter under canister of Hoover Wind Tunnel Mach 4.7 Twin Chamber System.
I assume this is a Hoover Bagless, if poor suction, the hose or dirt inlet by the brush roll may have a clog. The filter inside the dirt container may need replacement. Some had a screw to take out to remove the cover for the filter, the one under where hte dirt container sits. Alos the belt may be stretch and won't turn the brush roll under load. Having the model number would help.
Apr 19, 2008 | Vacuums
Hoover u5227-930 Elite Upright
I figured it out! The key is removing the "head" that covers the headlight - use a flathead screwdriver to pop it off.....then the belt connects from the agitator to the motor pulley. Phew!
Jan 20, 2008 | Hoover U5227-930 Elite Upright Vacuum
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
