Power light on my printer wont stop flashing, causing it not to print
Is it possible that it's out of ink or has a paper jam? On certain printers, the power light blinking is an indicator of a problem - no ink, low ink or paper jam. What kind of printer is it?
Posted on Oct 07, 2010
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Lp2844 wont print, just added a new roll and continusly feeds through without stopping till i disconnect the power?
  • Turn the printer off.
  • Remove the roll and re-fix it.
  • Press and hold the green power button.
  • Turn the printer on and release button after the first flash of LED light.
  • The printer runs a self test print.
  • Turn it off and then on again.
  • Now you can print.
Thanks!
Oct 04, 2011 | Zebra LP 2844 Thermal Printer
How to stop printer from printing an extra sticker when it prints?
Hi
  • Press and hold the green power button and turn on the printer.
  • Release after first flash of led light.The printer will run a test print.
  • Now print!
Hope it helps.Thanks!
Oct 03, 2011 | Zebra LP 2844 Thermal Printer
C45 how to clean nozzels
You can print the print head using the Control Panel buttons;
1. Make sure that the fontp.gif power light is on and that the font28.gif error light is off. 2. Hold down the font28.gif maintenance button for three seconds. The printer starts cleaning the print head and the fontp.gif power light begins flashing. Important - Never turn off the printer while the fontp.gif power light is flashing. Doing so may damage the printer. 3. When the fontp.gif power light stops flashing, print a nozzle check pattern to confirm that the head is clean.
Mar 06, 2011 | Epson Stylus C46 InkJet Printer
The arrow light wont stop flashing
this is common issue when paper jam or errors in printing queue,, check for any paper stuck inside (open up the back bay) delete the printing queue, power off printer restart the computer ! you should get solid green light
Dec 15, 2010 | HP Deskjet D4260 Printer
Maintenance warning/technical issue message stops printing
You just need to reset your printer. Google search a resetter program for your printer model.
Jan 10, 2010 | Epson Office Equipment & Supplies
ALARM light flashing, wont let me print.
hold down stop/reset button for 7 sec. If that doesn't work try holding it down for 14 sec.
Dec 10, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
hello!
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
May 06, 2008 | HP DeskJet 940c InkJet Printer
Alarm light wont stop flashing
How old is your printer? Maybe a part in your printer has reached its service life and has to be replaced. Please indicate error messages if there are any.
Mar 31, 2008 | Canon i860 InkJet Photo Printer
215 people viewed this question
k24674
