Question about Refrigerators
We have Westinghouse Virtuoso 500L, Model BJ503T-R*14, Serial 42152967. Dont have manual, freezes food in fridge, turn knob to less cold still doesn't adjust temp. Please help Cheers Myrna
xalint1
  • 152 Answers
SOURCE: fridge not cold freezer ok
More then likely your problem is that its not defrosting correctly in the freezer and the ice has built up behind the panel and not allowing the cold air down into your refrigerator.
Posted on Aug 22, 2008
erpaalai
  • 999 Answers
SOURCE: my rv fridge will build up ice and freeze food too cold
The thermister for the temp control is a likely culprit. Eric
Posted on Jul 07, 2009
  • 5 Answers
SOURCE: Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Posted on Nov 15, 2009
  • 2468 Answers
SOURCE: My westinghouse sid-by-side fridge is freezing
the mother board located inside the lower rear portion of the unit is bad,if you have recently had lights blow out this can cause a surge and ruin the mother board,also if there are relays clicking and lights are blinking dimly this is a good sign the board is bad
Posted on Jan 17, 2010
miket756
  • 2702 Answers
SOURCE: Westinghouse WSE6100SA fridge in side by side fridge freezer free
the thermostat has broken down and needs to be replaced,, normaly when they brake down they just stay in the closed poshion so the fridge freezes up get a new one fitted and all will be well
Posted on Feb 19, 2010
Testimonial: "Thanks for you fast response, very helpful. I thought this may be the problem but wasnt sure. Are the thermostats easy to replace? Could I DIY, How?"
Westinghouse virtuoso fridge- my top panel has gone blank - and everything in my fridge is now freezing - is there an easy solution to fix this ??
Sounds like the thermostat has failed to on and the machine just keeps freezing. Before replacing the panel try turning the power off to the fridge at the wall for 2 minuites and then return the power.
Apr 05, 2014 | Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
I hope someone can help me. I have a Whirlpool Fridge Model Number WRN52HWG6 and we bought it from Fridge and Freezer City O'Connor Perth about 6 months ago and I don't have the owners manual for it...
If you turn the dial clockwise this will make it colder anticlock less cooler...Start by switching off for a few Hours leave door open to allow defrost...Turn the stat fully anticlockwise to almost off then put it to say 2 o clock position assumming that it will go from 12 to 10,this should allow food to remain cold without freezing.you are looking for about 3/8 Degrees c.....Buy a cheap thermometer this will help to keep you on the right track..Good luck
Mar 07, 2011 | Whirlpool Microwave Ovens
I have a westinghouse 2 door fridge that is not getting cold enough, 7 degrees in the fridge, freezer seems ok. not sure where to set the controls as i have no manual. its a 2 door,freeze at the top and...
i think your ref working normal try to adjust thermostat setting on the fridge if you want to cool lower than 7 degrees but this temp. allready can chill the food. then you said that freezer ok.
Feb 12, 2011 | Westinghouse Refrigerators
Fridge Too Cold
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jul 31, 2010 | Frigidaire 16.5 Cu. Ft. Top-Mount...
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
236 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
