Question about Lexmark X7350 All-In-One InkJet Printer
Printer not in use for 5 months. Can't get it to print. It says it is ready but when I print and message come up that my ubc is not correct. Have only two at the back of thecomputer and it is in one. What is going on???
Is this printer driver still installed on the computer? Maybe try plugging it into the other USB - I had a computer that would only detect a certain printer if it was plugged into a certain USB port - is weird, but it's true!
Posted on Oct 07, 2010
I Purchased NEW THIS PRODUCT HP LASER JET PRO 400
default must be no password , here are the steps to reset the printer
NVRAM reset for the HP LaserJet 400 colorMFP M475dn (Confirmed functional) 1: Print configuration page before beginning reset
2: Disconnect all cables except for power
3: While printer is in ready state, note the position of "Ready" message on the screen (Probably bottom right)
4: Power off the printer via power button
5: Touch the location on the screen where "Ready" message appeared.
6: while touching the screen, power on the printer. Continue to hold the screen.
7: When "Memory Limit Reached" message appears, release the screen.
8: Printer will reboot, clean and calibrate
9: Return cables to their appropriate ports
10: Print configuration page to confirm settings are cleared. Restore settings desired manually.
Finally have access back!
Mar 08, 2017 | HP Computers & Internet
I received an EIO error message and looked it up online. The answer said to move the EIO from one slot to another, which I did. The error message is gone, but I can't get the printer back online.
Do you mean the printer won't come READY?
Or do you mean that you can't get the printer on the network?
Print out the CONFIGURATION Pages. The last sheet should be the network info.
The top left should have a statement "I/O READY".
If you get NOT READY, you probably have a bad JetDirect.
If it is ready, check the IP address on the right side, make sure that it is correct.
Try reseating the Jet Direct (with power off).
Jan 20, 2011 | HP LaserJet 4250dtn Printer
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
We have a 9855 Monarch barcode Printer. We are
If the printer display just shows Ready, but doesn't print, there could be a few things wrong.
1 - no data is going to the printer
2 - data is going to the printer, but it is not the printer's native language
3 - cable connectivity issues
4 - wrong cable is being used
5 - if wireless, data is not going to the correct IP
If using a 3rd party application, make sure that you've chosen the correct Monarch printer, as well as printing to the correct port. Sometime people print to LPT instead of Serial, as an example.
If using 3rd party drivers, make sure of the same thing.
To see if the printer actually works, press both of the arrows on the display, at the same time, after the printer is at the ready screen. As long as have the printer configured correctly (ribbon, supply type, etc.), the printer should print out a couple of labels.
Oct 26, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Document failed to print" message
Hi go into settings on you're printer & clear the pending queue it will not print till u delete them ..cheers
Jan 18, 2018 | Dell 1600n All-In-One Laser Printer
When I try to print with the C7180 printer highlighted, it says "error" under the printer name, and it won't print. If I scroll down to 7100 printer, it says "ready" and the item prints. Then the 7180 is...
Please perform the steps below to set the printer as default if you are using Windows XP Operating System:
1. Open the printers folder:
a. On the Windows taskbar, click Start , and then click Control Panel .
b. Click Printers and Other Hardware .
NOTE: This step is not necessary in XP Classic View.
c. Click Printers and Faxes .
2. Find the printer icon for your product and then look for a black checkmark to indicate that it is the default printer ( ).
If the product is not the default printer, right-click the correct printer icon, and then click Set as Default Printer .
3. Right-click the name of the product and click Properties .
4. Make sure that the product uses the correct port and driver:
a. Click the Ports tab.
b. Make sure that the USB00X or DOT4_00X check box is selected next to the name of the product, where X is the port number.
c. Click the Advanced tab.
d. In the Driver drop-down list, select the correct model number.
5. Make sure that the program from which you are printing is sending the print job to the correct product:
i. Open the program from which you are printing.
ii. Click File , and then click Print .
If the correct product displays in the Name drop-down list, proceed to the next step.
If the correct product does not display in the Name drop-down list, select the correct product, and then click OK to print.
Oct 02, 2009 | HP Photosmart C7180 All-In-One InkJet...
Purchased a Canon i950 for years ago... printing beautifully... did not use for the last two months and now has just stopped printing... reinstalled driver, still same problem - does not print a test page...
Check if the printer status is ready under Control Panel- Printers.
Make sure that correct port is used (Printer properties- Ports tab).
Also, check if the printer is online. Control Panel-Right click printer and choose Use Printer Online.
Hope this helps.
Jul 30, 2009 | Canon i950 InkJet Photo Printer
Error Message: No Paper, Load Organizer....................
Opened "Control panel>printers/faxes>Printing preferences>Basic>Paper source, and selected Tray 1 for all pages. Then went into the print menu in Adobe Reader, wich is where I was trying to print from originally, and deselected "choose paper source by PDF page size. It seemed to work.
Jul 18, 2009 | Brother HL-4070CDW Printer
Can't print from Vista to networked printer
the software that u are using is not copatible with the prenter. try to set up a pier to pier conection by using other ip address. use MSHOME in your work group then try to put 10.0.0.01 then put 10.0.0.2 as DNS ang default gateway. then do it to the vista notebook just change the ip address by using 10.0.0.3. let me knoew if its ok
Nov 28, 2008 | Konica Minolta magicolor 5430 DL Laser...
Massage unsupport ink on lexmark X4270
Sadly, not all inks are created equal, and even inks that are claimed "compatable" are not allways safe. My HP photo printer worked great for 2 years, then I put in a "will fit" from a name brand office supply store, the printer nozzles plugged on the second print, never to print correctly again. My replacement printer is a Kodak 5300 all in one, chosen for low ink costs/ hi-output, and I get photo-lab quality, borderless prints day after day. (I'm a photographer/artist) I have run 6 color and 5 blacks for thousands of graphics, in a period of 2 months getting ready for a showing, with maybe 1 or 2 misprints.
Nov 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X7350 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
