Question about The Simpsons Wos Military Antique Shop and Herman
Dave, Oct. 6, 2010 Anyone have any info on a scope that is marked, TELESCOPE,M33,NO.961 E.K.CO 1942 F.M. ,it doesn't have any windage or elevation adjustments, 9 inches long, 7/8 inch dia. one end and 1inch on the other end. also has a band with which appears to be a dove tail mount. May be old military.
  • thissideofth Oct 07, 2010
    What is a brass scope marked, Telescope,M33,NO. 961
    E.K.CO 1942 F.M.
    President:
  • 2,777 Answers
I believe you are correct on the old military assumption, you may want to try some firearm / scope forums to see if some old-timer has any info on the scope. Nothing among us here in particular.
Sorry I don't have more info, I have seen many many scopes and that doesn't mean much to me.
Thanks
Tim
Posted on Oct 07, 2010
  • 11,896 Answers
M19 or M32 brass telescopes made by MHR Co. in 1942. M series like m19 m20 m30 m33 and so on. I believe these were used as artillery
  • Nate Stansfield
    Nate Stansfield Oct 07, 2010
    This is the 961st scope made of the M33 model made in 1942
My land scope is showing the pictures up side down does anyone know how to fix this issue this is a brand new bushnell scope
This is an astronomical telescope-- all astronomical telescopes show upside down and or reversed images. It's completely normal.
For terrestrial viewing you must buy an "erecting prism diagonal" similar to these:
http://www.astronomics.com/main/Image_Erecting_Prisms.asp/catalog_name/Astronomics/category_name/EDNECFUVSRWS8KLNTU5E38XSE1
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info:
Jul 15, 2011 | Bushnell 675x5 EQ Reflector Telescope
Tip
Simmons 3*9 22 MAG scope
I bought one SIMMONS 3*9 MAG 22 riffle scope from USA last month in $54 and fixed it on my .22 riffle with proper instruction. When I shooted 2-3 bullets, its + sign is moved from actual target.
I made the target and + again in sync and after shooting 3-4 bullets, its + changed the position. After consulting with some mechanic, he told me the SIMMONS telescope is manufactured in China and its acuracy is not upto the mark. He was advocating me to buy bushnell scope for my riffle.
Now I am confused and not able to identify how to fix this + movement problem in my scope.
Can anyone please help me on this ????
Your reply is very much anticipated.
Thanks !!
on Aug 12, 2008 | Simmons Outdoor Blazer Matte (4 x 32mm)...
How do i use a tasco 28A
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright. 2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim. 3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading. 4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result. 5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline. 6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line. 7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle. WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments. 8. Restore the stud tension by pressing the end of the spring.
Feb 13, 2011 | Tasco Scope Guide Quickly Zeroing Rifle...
Windage fully clockwise "In" and not quite there at 100 yds.
remount the scope using millett angle lock rings that allow you to adjust for windage. bring the scope as close to hitting bulls eye as possible then use the scopes adjustments for the fine tuning. before remounting you will want to recenter the reticule.
Mar 14, 2010 | Bushnell ® Elite® 3200 3 - 9x40 mm...
I have a Leupold 3x9 VX II I'm finding that both windage and elevation adjustment screws are very difficult to turn. Is there a special tool I should be using for this or should I just be careful with a...
Leupold has a very good service policy, They'll repair it no matter what.
Send it in to them and let the experts fix it.
Here's their contact info:
1-800-LEUPOLD
Hope this helps, Mark the Gunsmith
Dec 06, 2009 | Optics
The reticle adjustment knob is turned all the way out (counter clockwise) and still hasn't moved the point of impact to the right enough.
If you have Leupold/redfield style windage adjustable baes you just need to move the windage adjustments. If you don't have these, I would recommend you take your rifle to a qualified gunsmith and have him remount and boresight your scope with this style scope base(s) which should run you about $80.00
hope this helps, Mark the Gunsmith
Oct 22, 2009 | Optics
Question about Swarovski Scopes
iv had this problem many times before,,,its more likley to be a bad set of mounts not inline with the barrel,,, if you have ran out of windage adjustment,, to get over it i use a strip of 35mm film inside the scope mount to push the scope over a bit,,, but a new set of mounts would be the best way forwards
Oct 13, 2009 | Swarovski Optik PH6-24x50 Weapon Sight
I need a scope guide instruction sheet for the Tasco 28a
Dec 14, 2008 | Tasco Scope Guide Quickly Zeroing Rifle...
Lost manual for trophy scope 3-9x40 rifle
There is no manual for elevation and windage adjustments. (at least not one that comes with your scope; all your scopes manual will say is whether its FFP or SFP (First Focal Plane or Second Focal Plane, the scale used on your scope for mil dots)(you can get this info by finding a store that sells this scope and asking a sales rep)
To adjust for elevation and windage you have to take into account the daily factors (unless your shooting in the same indoor environmental controlled shooting range each day you SNOB! jk
The formula takes alot of variables into account and is known as Exterior Ballistics
!) Environmental Factors - First thing you account for.
A) Elevation from sea level plays a large part into your environmental adjustments. Your elevation from sea level determines largely the Barometirc Pressure but it also varies slightly with Temp and Humidity (Major Factor)
B) Temperature - The temperature can affect the density of the air. The hotter it is the thinner it is and therefore less resistance and a higher bullet trajectory (Minor Factor)
C) Humidity - This again will affect the densify of the air infront of your bullet (Minor Factor)
D) Barometric Pressure - The other large factor in air density this is the base stat that the others modify
These all combined create a ratio that you apply to standard MOA (windage and elevation adjustments) to obtain the shooting information for that particular environment)
2) Bullet Factors (Listed on the Box you buy) - There are a few bullet factors to take into account.
A) Speed - the bullets feet per second can vary as much or more than 500 feet per second with the
same caliber ammunition.
B) Grain - The Grain of an ammunition is a measure fo its "Sectional Density" or weight to volume
ratio
C) Ballistic Co Efficient - This number is the measure of the bullets ability to maintain its speed
during flight. This also varies from Grain to Grain
These factors are complex and a pain for the best of shooters to determine. adding to that confusion. there are many ways to determine a bullets ballistics coefficient and each one gets a different number. In this case bullet data is best retieved from the manufactuerers box and take their word for it.
3) Lastly you account for shot factors.
A) Range - by referencing your standard elevation MOA adjustments and mutliplying by the ratio for environment the Elevation MOA is achieved.
B) Windage - Windage is done in inches per mile per hour then is multiplied by the Mph of the wind.
In order to be precise the windage is done in inches instead of MOA. it needs to be converted heres and example.
You Ballistics Cheat Sheet for the day says the windage at 900 yards is 5.2 Inches per mph of wind.
you apply the ratio for your environment .90 (all example numbers. this number would represent a shooting environment with an air density lower than standard/ the cheat sheet's known MOA adjustments). the 5.2 inches is multiplied by .9to acheive 4.68?? idk the point is you mulitply that by the wind of 10 mph to achieve a total of 46.8" of wind drift to the target.
now for the conversion to MOA. 1 MOA is eqaul to 1.047" per 100 yards. meaning for every 1 moa you adjust the bullet will move 1.047" per 100 yards (our target is 900 yards; meaning that each MOA for this target is 9*1.047" = 9.423" per MOA adjustment. so take that number and divide our total wind drift by it. ie 46.8 / 9.423 = MOA Windage Change of 4.9665... now you need to know whethere your scope is 1/4 minute clicks or 1/8 minutes (how many spaces between large numbers?) you would adjust to 5 MOA for a 1/4 minutes scope equaling 20 clicks on an 1/8th minute scope it would be 40 clicks.
This is the math of shooting. to learn how go to
WWW.shooterready.com they are an excellent sight to get the math down WITHOUT wasting ammo. Once you have the math you an transfer it to your gun. waste a few rounds checking it out and youll be hitting targets @ 1800 yards in no time
I like to take the simple way after i learned how to do the hard way
There is software tha will do the exterior calcualtions for you.
if your interested i use Sierra Infinity V6 Ballistics Software
GL
Dec 08, 2008 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Missing finder scope
i actually have the star finder and its **** honestly. but well mine is old to. so a new one might do you better. but i've attached a rifle scope to mine.
Aug 04, 2008 | Tasco Astronomical 302675 Telescope
The Simpsons Wos  Military Antique Shop and Herman Logo
103 people viewed this question
Top The Simpsons Toys Experts
Andrew Taylor
Andrew Taylor
Are you a The Simpsons Toy Expert? Answer questions, earn points and help others
