Question about Kitchen Ranges
Make :Tyco sanmar/Anderson Green wood Crossby Type : Pilot operated Size : 8 * 8.8 Style : 46305-888/S/NACE/SPL Sl No: 200789901 Assy No. : S8152-000-0000 Capacity : 52721.203 Kg/hr The above type 3 numbers PSV was procured from you for HPCL,Vizag.We require manuals or broucheres for the site callibration as this valves are continously passing on installation as the valve seat is in between position.Please advice us and provide required data for the site callibration.
SOURCE: Tally Data Recover
Here is a solution for your problem, simply use the inbuilt tally recovery tool as described here - http://www.megaleecher.net/Tally_Software
Posted on Jul 12, 2008
  • 67 Answers
SOURCE: Bosch HGS442UC Gas Oven won't light
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
SOURCE: Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
Posted on Nov 24, 2008
Service Dude
  • 201 Answers
SOURCE: spark plug gap size
1.3mm
Posted on Jan 03, 2009
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
On my 1994 chevy camaro,my steering column is bad.What range of years will fit?
If your talking about slack in the tilt part ,,, you can tightin it up,,, you will need a steering wheel puller and torx type sockets not sure the size ,,, once you get the steering wheel off ,horn assy out turn signal assy out,, the are 3 torx bolts that tightin it up ,,,remove bolts and use green lock tight on threads,,, reinstall and tightin ,, will never loosin agian if you use green lock tight
May 09, 2015 | 1994 Chevrolet Camaro
Can't keep the wood burning in stove. How does the buck stove take in air?
To burn properly, it needs proper combustion air and proper draft. Draft is effected by the size and height of the flue the appliance is connected to and by how much combustion air is available. The appliance flue connection should not be reduced to fit a smaller chimney size. That is, an 8" flue should not have an 8 x 6 reducer to vent it into a 6" chimney.
The wood you are burning could contribute to a poorly burning fire. To burn properly, the wood needs to have been "seasoned" for a minimum of 1 year or close to it. Two years is even better. "Green"
or freshly cut wood contains an unbelieveable amount of moisture in it and a tremendous amount of the heat is wasted just "preheating" the wood to the temperature that causes it to release gasses for ignition.
I don't know the style or model of your Buck, but all wood burning appliances should have combustion air dampers of either a sliding design, rotating round design or hinged design with handle at the bottom front of the firebox. I'm sure there are some fancy new designs that have air piped in from outside the structure.
Every wood fired stove, fireplace or furnace has its own idiosyncrasies and its up to the user to determine what's required for making it operate as designed.
Dec 06, 2014 | Buck Stove Home
Hei, need help when printing from Samsung Galaxy Tab 10.1/Polaris Office app to Samsung printer SL-M2070W: SPL error code 11-1113 position 0x0 system h6fwsim/xl_image line 398 version spl 5.73. Thanks in...
I am trying to print via wi-fi direct, and it gives me:
SPL ERROR -Please use the proper driver
POSITION 0x0
SYSTEM h6fwasim/x1_image
LINE 398
VERSION SPL 5.73.04 06-10-2014
ERROR CODE 11-1113
Any help?
Oct 10, 2013 | Office Equipment & Supplies
2010 street glide schematics
Hi Anonymous, 4 out of 5 Harley Gods give this one a thumbs up, but just to be on the safe side contact your local dealers parts department for confirmation. Good luck
May 02, 2013 | 2009 Harley Davidson FLHTCU Ultra Classic...
When I try to light the pilot, the flame light at the small hole on the outside on the pilot burner
You have a plugged pilot orifice. That small hole is basically an air intake for pilot when working properly, and when it gets a spider web or something in it, the pilot flame will burn rich (orange/yellow). When pilot orifice is plugged, that"s the next closest place for propane to escape, thus, flame . You need to either blow compressed air in to pilot tube end where flame is normally at, and hope it cleans debris out, or use a 3/8 and 5/16 wrench and disconnect pilot tube from end and remove orifice in pilot assy, and make sure small pinhole is cleared in center of orifice. Be careful when removing tube, as it is aluminum and can crack very easily, especially if older. The best thing to do would be to stop at RV store and get a new pilot tube and thermocouple assy, and install new. Not very expensive, and troubles should be over for years to come with regular servicing. New assy, comes with new orifice etc.
Sep 13, 2012 | RTO Atwood Water Heater - 6 Gal LP
I need to know what size/type of jigsaw blade to purchase for my SKIL 4230 Model# F012423000.
The size and type will depend on your needs when cutting. Fortunately, this model can use both T- and U-shank blades.
My personal preference if for the T style as i find they hold better.
use this picture and info as a guide. When you go to hardware store look for a combo set for metal and wood.
metalworking will have fine teeth, woodworking will have larger teeth.
Hope this helps
Thanks
Please rate FIXYA
May 20, 2011 | Garden
What size fuses do i need
YOU CAN USUALLY GO WITH THE GREEN ONE 30.
May 02, 2009 | SPL Dynamics XL2-820 SPL Car Audio...
Kitchen Ranges Logo
69 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
