Question about EA Sports Madden NFL 08 for Windows
When I try to exit the game, it freezes so I have to use task manager to close the program every time. I use window 7
    Master:
  • 473 Answers
Issue with Memory Temp ... Check Temp Memory setup ..Try to change your virtual memory then try to clean your hard drive and defrag it ....that help
Posted on Oct 07, 2010
When i close something from taskbar what comand do i use
Did you mean task manager?
From task manager Right Click on "end task"
from Taskbar rught click on the program and click close
Tony
Jul 21, 2014 | Microsoft Windows 7 Ultimate for PC
Tip
How to force quit uncooperative programs on a PC.
Have you ever encountered annoyingly slow or freezing programs that will not quit when you try to close a window? There is a simple keystroke you can use to quit the programs:Ctrl+Alt+Del. This enables you to access the Task Manager. Task Manager keeps track of all the computers processes as well as the CPU usage and physical memory and can be used to monitor and quit unnecessary programs that can slow or freeze your computer.You simply hold all three buttons (in sequence) and you will be redirected to a different screen that gives you options. Look for Task Manager. (note: If you have Windows XP, Task Manager will pop up as a window). There are 6 tabs (Applications, Processes, Services, Performance, Networks and Users). We will only cover the Applications tab.Once you are in Task Manager, click on the applications tab, if it is not already showing. You will see the titles of programs you are using, if any, and its status (running or not responding). If a program is not responding simply highlight it, by clicking on it and clicking on the button at the bottom labeled "End Task".This should force quit the program(s).
on Sep 08, 2010 | Computers & Internet
How do I get out of program?
Try exiting normally using the X button on top right hand of screen. If this does not work Type and Hold: CTRL + ALT + DEL on your keyboard at the same time.
If running Windows 8 or 7 select Task Manager. Any other OS will likely pull up task manager automatically. Select the offending program from the list of open programs and close it.
Depending on how locked up the program is this may take a moment. If after a full minute or two this still fails, you may need to use the same option to pull up task manager and reset the PC.
Apr 28, 2014 | Computers & Internet
Computer wont turn on
There is a possibility that your computer may have been too hot which was why it froze. You can also try reinstalling your gpu driver as well as try to close down applications in the background because if you have too many things opened in the background at once it can slow things down.
How to close down applications with task manager
How to close program using Task Manager
Jul 13, 2017 | Dell Latitude D630 Notebook
Random Freezes in Black ops (PC). I have had this for a while and asked many questions, but they didnt fix it.
Here is one good way to fixblack ops freezing problem:
> Fix and Clean Windows Registry with RegInOut: The Registryin Windows is that component which stores all the information about the programrunning on your system. Sometimes the games create registry keys which getcorrupted and cause severe lags during the gameplay.
++ Set Higher Priority to the Game
1. Press Ctrl + Alt + Delete keys at the same time.
2. The Task Manager will open.
3. Click Processes tab to explore all the processes running in thebackground.
4. Right click the process blackopsmp.exe, and select Set Priority ->High.
5. Confirm your action when prompted.
6. Close the Task Manager.
++End/ Set Lower Priority to Steam Process
1. Close the game, and press Ctrl + Alt + Delete keys at the same time.
4. Right click the process Steam.exe, and select End Process toterminate it. If you do not wish to terminate it, then set a lower priority toit, by right clicking it, selecting Set Priority -> Low.
++Install latest patches
++Close Unnecessary Programs when playing game.
May 10, 2011 | Video Game Consoles & Games
My internet windows i was using froze and i cant exit out how do i close them
ALT + F4......to exit. if this not working then ALT+CTRL+DEL....then end task
Dec 05, 2010 | Computers & Internet
Adobe photoshop 7 either stops working and closes or causes my computer to freeze up completly
There are many reasons why a computer may freeze or completely crash. The most common reason is an overload in the memory. Computers have a set amount of memory to work with (this is their RAM, or "Random Access Memory"). If you attempt to do more with the computer than it's capable of handling at one time, it may "crash" in an attempt to save itself. Generally, the cause of this is generally that too many programs are running at once for the computer to handle. If you are not using a program, close it. Conflicts between programs are other well-known reasons for crashes. Programs such as virus detectors are notorious for conflicting with other applications and utilities. If you notice that crashes are occurring while the same two programs are running, try to avoid running these two programs at the same time.
What Can I Do?
  1. Take Notes
    Your first step should be to pay attention to what was happening at the time of the freeze or crash. Try to isolate the program that may be causing problems (this can help prevent a further, more damaging, crash). Is there a history of problems with a particular program (or combination of programs) on your computer? Were too many programs running at once? Was it a particular task you were trying to do? See if you can form a hypothesis about the cause. By understanding what may have caused it this time, you can attempt to avoid future, similar occurrences.
  2. Try to End the Program
    Windows provides a "Task Manager" that lists all current programs in operation. In Windows 9x & ME, this menu is brought up by pressing Ctrl + Alt + Delete at the same time. In Windows 2000, after pressing Ctrl + Alt + Delete, click the "Task List" button. In this menu, you can attempt to individually close programs that are causing problems. If programs are unresponsive, Windows will attempt to notify you of this in the Task Manager.
    If you are able to effectively close the program causing problems, save your work in all other open programs, and reboot your computer. This will help to prevent further crashes, and give your system a clean slate to work from again.
  3. Reboot
    If you are not able to effectively close the program in question, you have several options. Please note that any changes in unsaved documents WILL be lost in a system reboot. With the Task Manager open, try pressing Ctrl + Alt + Delete once more. Windows will attempt to reboot itself.
    If the Task Manager does not respond, you still have a few options. Check your computer's tower to see if there is a "Reset" button (it will be in the general area of the normal "Power" button, and should be slightly smaller than it). Press the "Reset" button, and your computer should reboot.
    If you are unable to find the "Reset" button or do not have one, there is one final option to pursue. Find the "Power" button on your computer's tower. Press and hold this button. You will need to hold it for a few seconds (sometimes up to ten full seconds). At some point, your computer should shut down completely. If nothing happens, keep holding the button. Do not press and let go without giving the computer a fair chance to shut down.
Sep 07, 2009 | Adobe Photoshop 7.0 for PC
Tried switching to neighborhood 2 and the screen freezes. Can't even quit the game without using task manager. Have to uninstall and reinstall to play.
You should go to The Sims website, they have technical support and a lot of user created sites with chat rooms. Also there are downloads for each expansion pack from The Sims. It is also a good idea to play the Sims with your internet connection offline, and any backdround programs turned off.
May 20, 2009 | EA - Electronic Arts Sims: Complete...
EA Sports Madden NFL 08 for Windows Logo
145 people viewed this question
Top EA Sports Video Game Consoles & Games Experts
James Wishart
param99
Level 1 Expert
Tony
Are you an EA Sports Video Game Console and Game Expert? Answer questions, earn points and help others
