Question about RCA HD56W58 56" HDTV
Shows 3 screens all Different colors overlapping
  • RCA Master
  • 8,457 Answers
This tv have a problems known as a convergence problems,it dead.The tv convergence board,require 2 STK convergence ICS and some or all it resistors to replaced to solved the tv convergence picture problems.The shop will,cost u $300-350 for parts and labors.
Posted on Oct 07, 2010
What is convergence IC problem
Convergence has to do with how different colors are displayed on a screen or monitor - typically the rear projection and some other types. When colors are overlapping to create unexpected combinations, or leave gaps between areas where overlapping is expected that results in a shifted red, green or blue image strip or edge - that is an indication of a convergence issue. They can look like this in severe cases:
Colors will drift, so manufacturers often include a utility to help you nudge the colors back in the right place. Most times this utility is buried in the Set Up Menu and when activated, produces a screen like this:
You will need to adjust the red, green and blue colors for each cross so that only a white cross is displayed. Keep red, green and blue fringing to a minimum. When you're done, the screen should look black and white, symmetrical and straight - like this:
Problems arise when you are no longer able to coax the utility to give you these crisp, B&W results with no red, blue or green ghosting. This is often due to a failing convergence integrated circuit ("Convergence IC"). Many times, replacing it will solve the problem, but other times it can be the result of failing components either ahead or after this IC. If you're attempting to replace this IC, please make sure the TV or monitor has been *unplugged* for 24 hours or more to allow the dangerously high voltages to dissipate.
Sep 08, 2014 | Hitachi 50VS810 50" Rear Projection HDTV
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Words are duplicated about 3 times in 3 different colors as if the colors are not overlapping each other correctly. Was working perfect, moved the TV and now weird picture.
This model uses two of the STK-392-560 CHIPS FOR CONVERGENCE. See attached photos.
Total parts cost for do it yourself on Ebay is under 25 dollars.
I can tell you how and what to do.
If the pictures which show convergence problems or what I have told you help, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 25, 2010 | Sony KP-51HW40 51" Rear Projection...
Do not have copy of owners manuals and user guides
Problem is likely with a setting at the picture source. Make sure you only have enabled the setting your TV is capable of (480i, 480p, 1080i, etc)
Apr 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
After moving tiv up some stairs the picture became double in one corner and three color strips overlapped each other. Anything on that side of the screen shows double with three strips of color, green, red...
Ur tv convergence is dead.Must know how to solders?Buy a convergence kit at Tv Repair World.com,Tvrepairkits.com to replaced the convergence ICS and all it resistors.The shop will cost u $300 parts and labors.
Nov 30, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Colors arched and overlapping
if the option for convergence is still listed under the setting section of the on screen menu, then you need a convergence power supply board. If the convergence option is missing from the menu you need the ITC222 convergence missing repair kit. You can get either one at the following link they include instructions for the repair.
http://www.tvrepairworld.com/
Jul 13, 2009 | RCA R52WM24 52" HDTV Projection Television
Distorted image and color separation and overlap
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 05, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Text/images overlap each other in 3 colors, 3D distorted picture
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 28, 2009 | Sony KP-51HW40 51" Rear Projection...
52 inch rca shows picture in 3 colors will not focus
is thr convergence adjustment option still listed in the on screen menu? Let me know and I will try to assist you.
Jan 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD56W58 56" HDTV Logo
71 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
