Question about Delfield 113.28 cu. ft. Commercial Freezer Meridian MFRI3S Stainless Steel
There has got to be a way to change the factory preset freezer temperature on a Delfield 6000 series MCII to operate at refrigerator tempatures. Does anyone know how I can change the factory preset temperature range to go up to ~36F? Current range restricted to -5 to 10F.
    Sergeant:
    Novelist:
  • 193 Answers
Do you mean to go up to +36 degrees? If so, it just won't work correctly. The refrigerant is the wrong one to run at 36 degrees. The pressure on the "low" side of the compressor is so low that the compressor will starve for freon if you tried to change the thermostat to "warm" it up to +36. Also the defrost cycle would have to be disabled or it would jump to 50 or 60 degrees 4 times a day. It also has the wrong cap tube for that temperature. It could be done with a very expensive condensing unit changeout. Over the years I have seen a lot of people try it and nobody that I know have been succesful at it. It may be easier to find someone who wants to trade. After all a freezer is worth more dollars than a cooler. Good luck.
Posted on Oct 07, 2010
Delfield 6000 series 404a, need running pressure in 94 degree kitchen
300-350 on high side. Way too high. Most all commercial unit are built to live in an environment of not more than about 80. Some survive 85. Above that, it's will die due to over working and heating.
Jul 14, 2016 | Delfield Freezers
What should be my pressure on a Delfield 404A refrigerator
As a general rule of thumb, pressure on low side should equal a temperature of about 17-18 degrees if the box is not hot and a high side of ambient plus 30. Again, this is a general rule of thumb that usually gets you close enough to get a unit working providing all other things are right.
May 20, 2014 | Continental Manufacturing Company...
How can i change a delfield 407-dhl from a freezer into a cooler
Refrigerators and freezers are almost identical except for more controls on a freezer. Just raise the thermostat to the temperature you need. If it won't adjust that high, you will need to replace it.
Dec 02, 2013 | Freezers
Delfield freezer evap fan is good i test it with 120v but not working in the freezer whats else could be the possible problem
Defrost limit/fan delay switch may be bad however if the coil temperature is not 25* the switch will not close.
Jun 08, 2011 | Delfield Freezer 6151XLSR Stainless steel
How do I replace the door gaskets on a Delfield Model 6051 refrigerator? I can't see how to get the plastic inner panel off to release the gaskets and there is no help in the operating manual.
from what their web site shows, all of their gaskets are some sort of push in (Dart type) or clip in on a strip. Removing the inner panel is not necessary.
http://www.delfield.com/docs/uploaded/del/Parts/dpc08.pdf
go to page 36 and it shows the construction of the their gaskets.
Aug 02, 2010 | Delfield Freezer 6151XLSR Stainless steel
Temperature display reading 32 degrees on delfield 6000 xl freezer unit. Should be set for 0. door has been opened one time this morning. Where is display box to check troubleshooting codes located on...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 16, 2010 | Delfield Freezer Series 6000XL Remote Half...
I am working on a delfield model 6176-s and the display board is showing error 4. what does that mean?
Wow, what a challenge.
I found what I think you are looking for.
First, this only applies if the controller is an MCII. Should be printed on the face of the control.
In their 1996 manual for 6000 series reach-ins, it states that the number "4" error code is "Continuous operation with overtemp condition." It also says "What to do." and lists "Check refrigeration system and control system."
Hope this is what you are looking for. Good Luck.
Jul 23, 2009 | Delfield 66.5 cu. ft. Commercial Freezer...
I would like to know the standard temperature for a freezer
The factory presets your temperatures to the MID / MID setting of 0ºF for the freezer.
Apr 22, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Delfied Freezer6000XL freezing temps are not hold
Sounds like a refrigerant restriction in the system. Recover the refrigerant, replace the filter drier and pull a deep vacuum on the system before recgarging.
Mar 21, 2009 | Delfield Freezer 6151XLSR Stainless steel
Delfield 113.28 cu. ft. Commercial Freezer Meridian MFRI3S Stainless Steel Logo
196 people viewed this question
Top Delfield Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Tom Donaldson
Level 1 Expert
Are you a Delfield Freezer Expert? Answer questions, earn points and help others
