Back to:
Tags:
Vacuums
Generic problem for all Vacuums
Rainbow 2e Overheats... its the Electric Motor...
posted by JohnWest on May 29, 2008
I have a Rainbow 2e with what seems to be a common ailment. Has anyone a solution?
The little fan that presses on above the electric motor (that cools the motor) is pressed onto a 1/4 OD splined shaft thing... Its a horrible design... Perhaps you'd heard of this?
I am ready to Attach it with PC7 while held 1/8" above the sealing surface.... Hoping its balanced well enough to stay put.
Have you heard of anyone with a different approach?
Thanks!
John Westerdale
Comment by JohnWest, posted on Jun 02, 2008
RedDevil6,
Yup. Thats what I did.... a 7mm socket or somesuch..
the conical compression surface on the ID of the fan fatigued and split off. Dang!
But... I managed to find some washers that fit REALLY close on the shaft, and did the PC7 thing. A one way trip, but, hey... its working.
If it does require additional service, I will be the one with the dremel, so am not too concerned. Any idea where I might find a spare, if the dark day comes sooner than later?
Thanks!
John W.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 01, 2008
FixYa! (100)
reddevil6
Rank:Guru Guru
Rating: 88%, 1194 votes
It is pressed on, that is why you have a splined shaft. If you use a socket or nut driver, you can knock it ino place with a hammer. But don't hit too hard. you don't want to damage the end.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Rainbow 2e Overheats... its the Electric Motor cooler fan......:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Vacuums
how do i replace my rear wheels on my kirby g6...i was...
Bissell 9500 ProHeat 2X CleanShot Upright...
unit fails to release any cleaning detergent
Vacuums
my windsor s12 vacuum light says the bag is full but it is...
Bissell 3102-0 EasyVac Upright Vacuum
There are two wheels on my bissell. One of them broke off...
Eureka Altima Upright Vacuum Model 2996AVS...
We have checked for clogs and cleaned all the filters, but...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
