Question about Kodak EasyShare SV811 (8858946) Digital Picture Frame
I can't get the picture frame to even turn on. The green indicator light on the plug is lit, but nothing happens when I flip the power switch or use the remote. It's been a while since I had new pictures on it, so it hasn't even been plugged in for a few months. Now, it won't turn on! Nothing comes on the screen.
leepania
  • 1099 Answers
SOURCE: the kodak easy share digital picture frame won't show my pictures
Pls. check if there is any reaction when pressing the buttons onto the frame.
Check the batt within the remote.
Reset the frame.
If all fails:
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 15, 2009
  • 8 Answers
SOURCE: Kodak EasyShare EX1011 Digital Picture Frame
Probably a loose cable or a problem with the circuits
Posted on Oct 23, 2009
leepania
  • 1099 Answers
SOURCE: my picture frames power goes off after about an
It sounds to me that your adapter might be faulty. Your adapter is covered under the same warranty as the frame and can be replaced within 7-10 days.
In order to arrange an exchange for your faulty adapter: Contact KODAK:
Posted on Dec 11, 2009
benj888
  • 47 Answers
SOURCE: I'm trying to transfer pictures from my computer to the picture f
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Posted on Jan 05, 2010
  • 7 Answers
SOURCE: my kodak ev1011 pic frame stopped working
You may try the online troubleshooting guide at www.kodak.com/go/itg and if it does not resolve the issue at the end of the guide you can fill out a form to send the frame for repair and also just an FYI the frame is warranty for one year and you must a copy of your receipt before sending the frame.
Posted on Jan 08, 2010
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
I have a makita hm 1810 hammer green light stays on hit switch light goes off
As stated in the manual:
The green power-ON indicator lamp lights up when the tool is plugged to the mains. If the indicator lamp is lit but the tool does not start even if the tool is switched ON, the carbon brushes may be worn out, or the motor or the switch may be defective. If the indicator lamp does not light up, the mains cord or the indicator lamp may be defective.
Aug 25, 2012 | Makita HM1810 Electric Demolition Hammers
Makita HR3000c green light comes when trigger depressed but doesnt work
From the owner's manual: Indicator lamp The green power-ON indicator lamp lights up when the tool is switched ON. If the indicator lamp is lit but the tool does not start, the carbon brushes may be worn out, or the electric circuit or the motor may be defective. If the indicator lamp does not light up and the tool does not start, the ON/OFF switch or the mains cord may be defective.
The easiest to check is the brushes. Most newer tools have brushes with a spring loaded pin in them so when they wear down the pin pops and stops the motor so you don't wear the armature. Even without the pin the wire from the contact to the brush is short so the spring doesn't contact and ruin the armature. If the brushes are OK, you'll have to check the switch for continuity.
Aug 24, 2012 | Makita Drills
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
No power to my desktop computer HP A1330N and no green light in the back of the power supply
You replaced power supply and your made sure you plugged everything back into the motherboard snuggly and in it's proper place? If so it might be your motherboard is bad.
Make sure you have the new power supply turned on. Sometimes there's a O/I switch on the back of the power supply. Flip it and try to boot and see what happens. You might have another bad power supply.
If so your motherboard might be burning them out.
Try removing the power cord for 30 seconds and press and hold the power button. After 30 seconds put the power cord back in and press the power button to see what happens.
Do your fans work when you press the power button? Do you hear any fans running?
Mar 23, 2012 | Computers & Internet
My Gateway M-6847 will not turn on. When I press the power button the wireless light and power button light just flashes quickly. Also the battery light in front stays lit while plugged in.
Hi
silly question sorry
but have you charged the battery or plugged the power cord into plug and switched on to try to charge the battery for a couple of hrs without using the laptop
Jun 23, 2011 | Gateway M-6847 Notebook PC
No power
Try to remove your battery and plug in your AC adapter
If its working:
You need to replace your battery
If its not working:
Try to check if the LED indicator is lit
If the LED indicator is not lighted. Replace your AC adapter
Thanks. Cheers!
Apr 20, 2010 | Acer Aspire One AOD150-1920 Netbook
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
Toshiba Satellite 1135-S125 front LED indicators gone weird
Hi The strange operation of those LED's is most probably an error mode indicator. If a laptop fails to power on corectly it will use those LED's, lighting in a specific pattern to signal the error. That's an example. In your case something was damaged in some way because the error code indicator is still acting like there is an error. You may try to reset the BIOS to factory defaults (small chances that this will work) and leave the laptop unpowered for about 1 day. If the problem is still there you will need to have it fixed in a service center. By comparing the LED lighting pattern with information from the Toshiba service catalogs they will be able to tell you what kind of error had happen for wich the LED's to light in this manner. Sorry for my bad english, I live in a non-english speaking country. Good luck and don't forget to rate any answer received from this site.
Mar 05, 2007 | Toshiba Satellite 1135-S125 Notebook
Kodak EasyShare SV811 (8858946) Digital Picture Frame Logo
367 people viewed this question
Top Kodak Photography Experts
Michael Galve
Michael Galve
Bill Eager
micky dee
Are you a Kodak Photography Expert? Answer questions, earn points and help others
