Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
19" black and decker electric
I cant get the balde on i tried using a 2x4 but the axel wont stay far enough out to get the lock washer in line with the slots on the axel. so when i try to tighten it i just spin the axel please help
  • lawnlover May 30, 2008
    my problem is that the shaft and the parts inside the machine move as soon as i turn the nut so the 2 flats no longer lock the shaft. i must pull on the shaft to get the 2 flats to lock it, but i cant pull on the shaft and turn the nut at the same time. (LOL)
    Champion:
  • 313 Answers
After installing the fan next is the blade then the plastic washer and metal washer then the nut.take note the metal washer will with the shaft with 2 flat side.
Posted on May 29, 2008
My black and decker grass hog wont last about 5 minutes and the line empty?
Have you tried re assembley? take it apart and completely redo the whole line reel. i f this does not work. Contact Black and Decker online.
Jun 14, 2015 | Black & Decker Black and Decker & Grass...
THE NUT TO REMOVE THE BLADE CAME PART WAY OFF BUT NOW THE WHOLE MECHANISM...BLADE, WASHER, FAN ALL TURN...ARE LOOSE BUT THE SHAFT AND THE NUT TURN SO THERE IS NO PURCHASE TO LOOSEN FARTHER. HOW DO I HOLD...
Dependent upon the size of the shaft, a choice of suitable tools would vary. Considering this is the shaft off of an electric motor, may I suggest you wrap a rag around the area of the shaft where you can grip it and use a pair of Vise Grip locking pliars to hold it while you turn the nut. If the vise grips won't open wide enough, then use a rag with a pipe wrench locked onto the shaft to hold it.
Jan 30, 2011 | Black & Decker 19" Electric Lawnhog...
My flymo woodshark has just died whilst cutting a branch no smell or anything cant find manual is there one on line or can uhelp tried fuse in plug no help
Yes there is a manual at the black and decker website, when you get to their main page, scroll down to the bottom and click on instruction manuals, then you will put in the model no. and it will take you to the download. It is easy. take care and good luck
Sep 05, 2010 | Black & Decker 19" Electric Lawnhog...
Cannot get the blade off even following the manual's directions. Nut is slowly spinning under pressure with the square washer and blade is held in place with 2x4. Is it seized?
Try this
Apply a good dose of Liquid Wrench and tap the bolt head sharply several times
Wait 2 hours and then attempt to TIGHTEN it just a tiny bit
Remember Righty Tighty Lefty Losey
Now try to take it off If you have an 1/2" air impact wrench it will make the job much easier
Mar 31, 2010 | Black & Decker 19" Electric Lawnhog...
Black and decker electric mower
That is strange, I would maybe take it to where you bought it from and see if they will support you in it, or you can check out the tool repair forum over at eReplacementParts.com and ask a licensed mechanic to knows these mowers for some direct advice. Good luck to ya!
Mar 24, 2010 | Black & Decker 19" Electric Lawnhog...
19" black and decker electric mower just quit!
check the brush on the motor the one with the black wire usally wears first
Mar 21, 2010 | Black & Decker 19" Electric Lawnhog...
Black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
May 19, 2008 | Black & Decker 19" Electric Lawnhog...
Blade lock for mm850
Use a 2x4 at least 1-3' long. Clear the grass chute so you have unobstructed passage from the back of the mower and into the blades. Wedge the 2x4 longways in through the chute and up against the blade. The other end can be **** up against something sturdy i.e. a concrete block, a wall, etc... (in my case I used my leg). Take your wrench and crank like hell.
Apr 10, 2008 | Black & Decker 19" Electric Lawnhog...
Electric Mower not working
yes of course. this mower model mm525 has a motor not engine. if you need parts diagram see toolpartsdirect.com & look for the Black & Decker.
Jan 16, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
54 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
