Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
My Bisssil cleaner will not pick up the water from the floor. I checked all the trouble shooter helps and evewrything is OK Checked all belts they are OK. It also will not pick up water with the hand held tools, seems as though the vacuum is not working
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Oct 07, 2010
When the shampooer is moved forward to initially to spray the shampoo the plastic guard on the front drags the floor and keeps it from moving forward and shampooing. .
The one's I've used the sprayer is on the back of the suction (suction hood which is kind of clear plastic), you watch that clear part to see if it is picking up dirty water. Recall it's easier to pull it and if caught just push down on handles and that raises front of machine to clear carpet snag. I would walk backward as it sprayed and then picked up the water with dirt. If different machine you could spray moving backward, go back to same starting point go again and don't spray but just hold it near carpet so it picks up the water.
Jun 03, 2016 | Bissell ProHeat Pet Upright Deep Cleaner,...
Dirt devil turbo clean sd40060 Cyclonic vacuum. Was given it as a present. Floor tool won't spin. Checked everything! Belt, for hair through out. All ok. Why isn't it working?
You should find a large button or flap on the floor tool. This is usually spring loaded and needs to be OUT. This should then let air in to drive the turbine which drives the spinner.
Check out Vacuum Cleaners Upright Hand Stick Canister Vacuums Dirt Devil
Aug 08, 2015 | Dirt Devil Vacuums
Bissell proheat 8910 series wont pick up solution tried changing the dial settings and all and still not working
Check the drive belt and the hose - the hose may be plugged, the belt may be broken or off the pulleys.
Jul 22, 2014 | Bissell ProHeat Pet Upright Deep Cleaner,...
My Bissell powersteam powerbrush carpet cleaner wont spray water from the floor jets or the hose. Checked the belt, its doesn't look damaged, also took it apart and cleaned the floor jets, still nothing.
Check any related mechanical and/or electrical parts, including switched, levers, buttons, valves and all water-ways. Make sure all electrical connections are clean, functioning with a multi-meter, and all pieces are NOT broken or malfunctioning and clean. replace any broken or malfunctioning parts that you can't clean or repair.
Oct 15, 2013 | Bissell 1697W Powersteamer Pro Upright...
My beater bar is not going round, machine is not picking up I have checked for blockages and everything seems OK
The belt that drives the roller may have broken and reqiures replacement. You need to take the cover off underneath and remove the roller.
Mar 07, 2011 | Dyson DC07 All Floors Bagless Upright...
The hand cleaner picks up dirt but the floor cleaner does not.
A couple ideas.
1. Have you emptied your dirt?
2. Are your filters clean?
3. Is your roller brush working and if not, is your belt broken?
Hope this helps and good luck!
Mar 17, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Trouble picking up particles yet no blockage
If the belt is stretched, worn or broken then it will not pick up well. Here is a link for the instructions on how to change the belt and a link for the belt you need:
DC07 Belt Changing Instructions
Replacement belts for DC07
Nov 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My bissell carpet shampooer won't spray out water
The tubes inside the machine are probably clogged. Dismantle top hood and disconnect the three lines at the pump, open up entire top housing and inspect heater. Disconnect two tubes and heater and blow out with air compressor. That will spray all the junk, soap that has built up and your machine will be good as new. If you can't do this yourself, contact bissell and ask where your local repair center is
Aug 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
No water or solution through main unit
It is definitely the heater which is clogged. The heater is contained in the handle. Symptoms are that tools will displense cleaning fluid but main cleaner jets will not. Only the main cleaner jets use fluid which has been heated. The heater is quite easy to dismantle and clean however you will be working near mains electricity so ensure the unit is switched off and unplugged
Jan 11, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Oreck Vacuum Cleaner problem (upright)
The best solution to any Oreck vacuum problem is to replace it with another brand. You are going to continue having problems with the Oreck..Not that other brands don't have problems. But, at least with
other brands the problems don't occur as often. Belt burning up. clogs, roller brush bristle wearing down prematurely, cord breaking internally, etc.
P.S. Oreck is good at one thing. Marketing!
Aug 30, 2007 | Oreck XL2200 Bagged Upright Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
134 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
