Question about Dell F3534 Touchpad
Well the touch pad is acting up the clickers the left and right click thingys aren't clicking for example i want to refresh my page but i can't because the right clicker dosen't work please help me!
  • 4,336 Answers
Just get a USB mouse.
Posted on Oct 07, 2010
Touch pad right click slow response
It seems like mayb your touch button beneth has come up or either needs cleaning by isopropyl alcohol.
Oct 23, 2013 | Acer Aspire Computers & Internet
Unlock cursor for acer laptop
Your laptop comes with a touch pad that acts as a mouse. Instead of connecting a mouse each time you want to use your laptop, you can use the touch pad that is integrated underneath the keyboard. This comes in handy when you are in a tight spot such as in a classroom or on an airplane. At times, you may need to unlock the laptop touch pad because someone who borrowed your laptop disabled it. It may also be locked due to a slight malfunction that you can easily fix by enabling the touch pad in your computer settings.
Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel." Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link. Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button. Click the "Apply" button and then click the "OK" button. Hope this helps.
Dec 08, 2012 | Acer Computers & Internet
The left button at the bottom of my touch pad has a problem. the click is delayed, i have got to hold the click for longer so that the click may occur
@inam_khan_10
Try the following:
1. If your computer is running on Windows, try to boot into Safe Mode (you need to press F8 continuously upon boot-up then choose Safe Mode) and check if your Touchpad left clicker. If it works ok, then a software problem is causing the Touchpad to delay like that. Try reading this guide to solve it.
2. If Step 1 above doesn't work, try to use a compressed can of air to clean the Touchpad clicker and see if same issue occurs.
If still no go, this is a sign that your Touchpad is already wearing out and it needs to be replaced.
Good luck.
Sep 05, 2011 | Computers & Internet
Hi, my left clicker on my Sony Vaio stopped working. The right clicker works as well as the scroll pad but clicking on the scroll pad doesn't work as well. I have tried rebooting, installing the mouse...
More then likely the button has worn out.The first thing I would try to check to see if its the button or not ,just plug a mouse in to the laptop and see if that works with left click if it does it just may need a new button put in.If your handy you may even be able to do it yourself.If you have any other questions just let me know.
Jun 11, 2011 | Computers & Internet
How do I do the right click function of a normal mouse on the pad mouse of an acer aspire 4741g laptop which does not have a right click button. I have tried to press and hold the Ctrl key and press the...
On your laptop, directly beneath the touch pad are two oblong buttons. They act as mouse buttons. The left one selects and the right one gives extra options.
Hope that helps.
Feb 03, 2011 | Computers & Internet
Touch pad doesn't work
Determine What's Wrong
laptop'smag-glass_10x10.gif touch pad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touch pad may be damaged by excessive use or foreign substances such as water, dirt or food items.
Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return."
Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touch pad to become unresponsive. But if any of these steps fail to remedy the problem, then the touch pad may need to be repaired or replaced.
Repairing/Replacing TouchpadA touch pad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touch pad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touch pad is deemed a necessity, such repairs are rarely worth the cost.
Attempting to replace the touch pad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop.So just attach a mouse to it so you can work easily.Please rate me if this solution works for you
Thanks......Have a great time.
Jul 28, 2010 | Computers & Internet
Touch pad working fine but left clicker doesnt
Usually the green means that the button is pressed. Check the touch-pad buttons for dust or dirt. If they're clean, then probably need to be repaired.
Aug 26, 2009 | Computers & Internet
Both my keyboard mouse buttons act as right clicks
Hi
Access BIOS settings and search for mouse / peripheral settings, you may find one to activate left and right mobo clicks.
Cheers cbacer
Aug 12, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Inspiron 6400 touchpad woes
Hi there.
Try uninstalling the touchpad drivers and utility, that will solve the problem.
Post back if you need anymore help.
Good luck and thanks for using FixYa!!
May 26, 2009 | Dell F3534 Touchpad
Computers & Internet Logo
181 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
