Question about Crossfire VR1000D Car Audio Amplifier
Power light stays on.
When i have my remote wire up the power stay on. It used to turn off with the radio. need help. also amp has a yellow knob inside the amp. any one know what that is for.
  • lilbone44 Jun 20, 2008
    it's a crossfire vr1000d
    fix the remote problem just need to know about that yellow knob inside the amp.
To be honest I have no idea what that yellow knob is. Whatever you do DON'T TOUCH IT! Call Crossfire at (562) 906-0800.
Posted on Jun 20, 2008
  • 109 Answers
What kind of amp is it? Your question is very vague and doesn't include enough information to make a good judgement on what the problem is.
Posted on Jun 19, 2008
I have a 2005 ford escape I put a kill switch to turn off my amp and my radio but now that I want to take it off the radio wont come one unless I have the kill switch wires connected any suggestions
Look this is a very very simple fix. You have what is called a remote wire coming from the radio is usually the red and or the yellow wire what's happened is your remote wire which allows memory to stay on the radio is ran to your switch. You must eliminate your hot wire to your switch and run a hot wire off of your factory plug in to the remote wire on your radio. This will fix this issue.
May 22, 2015 | 2005 Ford Escape
Boss car amplifier stays on with remote wire removed?
sounds to me like your acc. wire is hooked to consistent power instead of power with ignition on only and off with key off. or radio on or off .
May 03, 2017 | Car Audio & Video
Remote wire doesnt turn off amps. and when driving stereo shuts off and comes back on, or puting truck into drive,reverse,or park,the radio shuts down. not all power the lights stay on and amps stay on i...
it sounds like you either used the wrong wire to connect the ground or the wrong wire to connect to the remote power.
for ground it should go to a clean paint free spot on the body of the car - try using a screw that is already attached to the cars chassis or a metal frame point
for the remote turn on wire try attaching it to the wire for you stereo ( it should be switched properly)
if it is doing what you are saying one of these 2 options should work
good luck!!
if you need more help write back and give me as many specific details as you can
Mar 27, 2011 | Eclipse 5506
Stereo wiring harness need to the colors and what they do? for a 1997 mercury mountaineer
cannot find 97 but found 98. Do these match?
1998 Mercury Mountaineer Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Light Green
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6? x 8?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): Dark Green/Orange
Right Front Speaker Negative Wire (-): White/Light Green
Car Audio Rear Speakers Size: 6? x 8?
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 16, 2010 | 1997 Mercury Mountaineer
My amp stay on when the car cuts off. the only way it turns off it i take the fuse out the power line or if i disconnect the remote wire. I have check the remote wire behind the head unit it everything is...
connect the red wire of the amp to a car battery (+). the black to a car metal and the remote cable to the blue wire in radio. when you turn on the radio the amp turn of--when you turn off the radio the amp turn off.
Apr 26, 2010 | Lanzar Vibe 1200D Car Audio Amplifier
My 4 channel amp keeps going into protect mode when i power on,its not a imminet light,but it blinks once then dies out,plz help
Remove all speaker inputs and outs and just have your 12volt battery, ground and radio remote connected and power up the amp. If it turns red instantly, then the amp is shorted/blown. If it stays green, then install your speaker inputs and outs one at a time. make sure your amp is on while your doing this. if the amp goes into protect mode, take note of which wire it was for it's most likely shorted. Fix that shorted wire and the unit should stay on.
Apr 13, 2010 | Car Audio & Video
Stays on
check to see if the remote wire has 12 volts when you turn the vehicle off. if so that is whats causing it to stay on. check your radio or where ever the remote signal is coming from. if the remote wire does not have 12 volts when the car is off, then there is something wrong with the turn on portion of the amp and needs to be repaired or replaced. good luck
Dec 29, 2009 | Power Acoustik GOTHIC OV2-520 Car Audio...
My amp is not working! i have a live from battery and a good earth,but still nothing,does it need to be earthed to back of head unit?
Do you have the remote turn-on lead hooked up?
There should be 3 wires on the power side of the amplifier.
Ground - to the car chassis
Power - to the car battery
Remote - to the remote turn on lead from the head unit. (this emits a 12V signal to a relay inside the amplifier for it to turn on when the radio does)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2009 | Car Audio & Video
Amp and subs turn off when i go from tuner to cd or ipod
you need to use a "blue with white" wire as remote to turn on the amplifiers.
Mar 23, 2009 | Kenwood KDC-MP638U Car CD/ MP3 Player
I recently installed a amp to my sound system I have a pioneer deck when hooking it up everything works but when I turn it off the car theamp light stays on I check everything I think it is my remote wire.
You are correct!
If you have a volt meter or a test light you can use it to see if you have some voltage on the remote terminal on the amp.
If you do not have either of those items, just disconnect the remote wire and see if the light goes out.
If the light goes out, you have voltage coming from your radio that is keeping the amp turned on, that is normally a problem with the radio. The remote output of the radio may have a shorted transistor in the circuit.
If the light stays on, you have a problem with the amp. It is rare to have an internal electrical problem with an amplifier and the amp still works normal. That is not to say it can not happen, there may be a component that is shorted in the turn-on circuit of the amp that is isolated to the turn on cicuit only, and it keeps the amp on all the time.
This will become a big problem soon if not repaired. If the amp is staying turned on even when the car is off you will drain your car battery rather quickly. Most amplifiers will draw between 1 amp and 2 amps of current with no signal applied, this is called the idle current.
Find out which unit is causing your problem and take it to be repaired, it is most likely an electrical problem that will need good electrical troubleshooting skills to locate.
If you need any more help with this feel free to ask, with the model number of the unit at fault I can even find you some likely suspects to be checked.
Don't forget to give me a "FixYa" if this information turns out to be helpful.
Jun 19, 2008 | Car Audio & Video
Crossfire VR1000D Car Audio Amplifier Logo
Top Crossfire Car Audio & Video Experts
xxxxxx xxx
Rommel Balcita
Are you a Crossfire Car Audio and Video Expert? Answer questions, earn points and help others
