Question about ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard
I need a driver for pci ide controller of psd2-vm motherboard
  • 91 Answers
Here is the link to the drivers page. Select your operating system and then download the drivers.
http://uk.asus.com/product.aspx?P_ID=napibCwKrjGDncvA&content=download
Posted on Oct 07, 2010
  • Phillip Thorne
    Phillip Thorne Oct 08, 2010
    If you feel I have helped resolve your problem please kindly rate my answer by clicking one of the four thumbs in the top right of this post. The thumb ratings are as follows and are designed to improve the level of service provided by fixya.com.
    1 Thumb- "Not Helpful"
    The solution was not helpful at all.
    2 Thumbs- "Somewhat Helpful"
    The solution was related to the Asker's problem, but was not helpful.
    3 Thumbs- "Helpful"
    The solution was helpful to the Asker.
    4 Thumbs- "Very Helpful"
    The solution solved the Asker's problem.
  • ASUS Master
  • 32,281 Answers
Normal 0
You can download the drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
Need sm bus controller and ethernet driver for a7n8x-vm motherboard
Go to the Asus site:
http://support.asus.com/download/Download.aspx?SLanguage=en-us
Choose :
"Motherboard"
"Socket A (465)"
"A7N8X-VM"
in the dropdowns.
Enter your OS
Choose the "IDE" driver, that is actually an "all-in-one" chipset driver that should get you taken care of.
Feb 15, 2011 | ASUS A7N8X-VM Motherboard
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
SiS PCI IDE controller (ASUS P5SD2-VM) Audio devici on hight definition on audio bus) VGA Controller(compatible) SoftV92 Data Fax modem SiS Accelerated Grafic
Download the drivers here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5SD2VM/#download
The files needs to be unziped before installation
Good luck
Jun 09, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Pci simple communications controller
your computer need to install the drivers for modem. because the simple communication controller name is used for the modem
Apr 14, 2009 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
PCI IDE slot does not detect hard drive
Check if power cable to the HDD is connected properly or not.If it is connected then check the jumper settings on HDD.
Thanks
Mar 12, 2009 | ASUS P5GD1-VM Motherboard
Wer can i find pci communications controller driver? my board is
Go to Computer Property Click Tab for Device Manager You will find pci communications controller...
Feb 01, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Hi tried that... sound card is connected and vm-ware tools is also installed... its surely a problem with the windows 2003 server. because the error sound is played through the macbook speakers but not any...
see heres the thing when using VM-Ware, VM-Ware doesnt use drivers for your physical hardware, because it emulates the hardware that is seen in the hardware information of your system preferences.
So installing even drivers for the "emulated" hardware will not work, as VM-Ware uses its own drivers for the hardware, which are included with the VM-Ware Tools, if that doesnt seem to work, you may want to contact VM-Ware support, as they may have a better solutiuon.
Aug 29, 2008 | Intel Motherboard
Printer Driver and Manual for a Canon MultiPass C3000
yedya gandichya driver cd sambhalta yet nahi tar printer kashala gandit ghalayla ghetlas
Jan 03, 2007 | Canon MultiPASS C3000 All-In-One InkJet...
ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard Logo
354 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
