Question about Trekstor (21202) 160 GB USB 2.0 Hard Drive
The hard drive is flashing red and blue. Is it done?
  • 358 Answers
Even though it is possible that your USB hard driveis corrupt, but
before you finally conclude, try out these few troubleshooting
steps.
First of all, it is possible that the USB port that you are using is a
USB 1.0 port, which has a lower voltage not enough to
power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a
USB 2.0 one (Just keep Checking all the ports one by one in case
you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in
an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy
a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Meanwhile, before you try out the second option, test the drive on
a friend's system, that you are sure has a very good system, with
USB 2.0 port.
If after trying out all these, the USB Drive still doesn't work, then
I'm afraid, the drive might have been bad/spoilt.
Kindly keep me posted about the problem and let me know how it
goes
Hope this helps you out.
Thank you for using Fixya
Goodluck
Posted on Oct 07, 2010
Just bought the G-Speed Q 8TB. Hooked it up and the red warning light on the bottom is flashing. Is there something wrong with the drives?
The flashing red light is indicating that it is building the RAID5 parity information. If there is an alternating amber/blue lights on one of the drives blinking back and forth with the red light it is indicating that it is building/rebuilding the RAID5.
May 15, 2011 | G-Technology 0G01792 G-SPEED Q 4TB USB 2.0...
My LG BD530 Blue Ray dvd player /usb will accept my 16GB flash drive to view movies as it has a usb plug in. It will not let me play the same movies from my Western Digital 750GB external hard drive. When...
Could very well be that the external hard drive is drawing more power than what the player can deliver - it is enough for a usb stick but not for the external drive. Now if you use an external drive that is self powered I am sure there will be no issue.
Mar 27, 2017 | Televison & Video
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Toshiba a200 flashing power light .. blue blue red red HELPPPPPPP
Remove battery and power
Remove memory in lower socket, the one on the system board and try reboot with just power cord. May have bad socket
Dec 11, 2009 | Toshiba Satellite A200-0ET00X Notebook
Fantom titanium external light turns red on connecting
Red is a failure warning but if it only hasppens with the usb plugged in it's mostly likey a failure in the IDE/SATA to USB conversion board.
Take the drive to your local PC shop, ask the techs there to pull the hard drive out of your phantom and test it in a new enclosure. If it works there, buy the enclosure, if it doesn't reply back and let me kow your Country, State and City and I can recommend a pro to look at the actual harddrive if you need files recovered from it.
Hope this helps FixYa
Sep 03, 2009 | Fantom Titanium Hard Drive
DataStation Maxi M.U. 500 Gb blinks red and blue, doesn't read
I just had this problem with both my external drives (I was using the same power cable and just alternating between them). I went and got drive B's power cable and they work fine now. Try replacing the power cable
Jul 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Red and Blue flashing light
I have the same problem. I have a 500 GB hard drive and my computer will see the hard drive but it won't let me open it. It says "g:\is not accesible incorrect function" I have a lot of data in my hard drive and I don't have it backed up anywhere else so I really need to be able to be able to open the drive.
Jun 20, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Flashing Red Light
the drive is just connecting to your pc. now if it always stayed red, you'd have a problem.
Jun 06, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Trekstor (21202) 160 GB USB 2.0 Hard Drive Logo
503 people viewed this question
Top Trekstor Computers & Internet Experts
Mohamed Ismail
Mohamed Ismail
Alun Cox
vojvodabudva
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
