Question about Acer Aspire 5610-4648 Notebook
I HAVE A EXT. HARD DR WHEN I PLUG IT INTO MY USB PORT ALL MY FILE SHOW UP WITH THE SHORTCUT ARROW AND A CANT GET THEM OPEN WTAT THE PROBLEM WHAT GOING ON
    Guru:
  • 551 Answers
Maybe from the time you copied your files you created a shortcut. That is why it has a short cut arrows.
Just go to the root directory of your files. Then copy it. Then paste it into your external HDD.
Posted on Oct 07, 2010
I have S2 portable 640gb external hard drive. Do not open the main folder with info and gives me only shortcuts and no way to my folders
Do you think my problem is a cable wear or the device itself
and how can get access to my data
can anyone hepl me
please
May 05, 2012 | Samsung S2 Portable 640 GB USB 30 External...
My HP 625 laptop is turning all my external memory files into shortcuts and creates some weird shotcuts to...none of the shortcuts work and i can only veiw whats on my memory card or usb if i search that...
When you plug a mass storage device in a USB or other ports, the OS gives it a drive letter E,F,G, H. I ... If you insert it another time it will give it a drive letter that may be different from the previous one because some other device plugged in has that drive letter. It may also happen if you change USB port.
So if you created shortcuts that pointed to one device that had driver letter G, they are no longer be valid if when you inserted it again the OS refers to the device with another letter.
Insert a device in the same USB port. If you have to plug in many devices try to plug them in in the same order. This may save your shortcuts, but there is no guarrantee it will be so.
If you are looking for a file you know is on a device, just use the Window explorer and point to it.
Jan 27, 2012 | HEWLETT-PACKARD 625 Notebook PC
My maxtor 500gb usb hard drive is not responding when I plug to my pc, so I can't access to any of my file
hello,
-make sure that the cables from the ext hard drive is properly connected like power if there is and USB -try other USB port -try other USB devices -try other USB cable for that Maxtor -try other computer
the reason why you are doing that is to know if the USB port is broken of if the ext hard drive is not responding.
cheers.
Feb 24, 2011 | Maxtor BASICS Personal Storage 3200...
My WD My Book Essential 1TB External is not showing up on 'My Computer'. It was working perfectly in the morning, then when I rebooted my machine it no longer showed up.
disconnect your WD ext HDD. and reboot your computer. then connect again. if still not showing. go to device manager (right click my computer then properties -- click device manager). expand by clickin "Disk drives" category here it will show all the hard drives installed in your computer including your WD ext HDD . if you see yellow sign on your external drive right click and remove then go to Action menu click on Scan for hardware. it should detect and install the driver again. if still the same or maybe its not on the list of Disk drives.. try to change another USB cable .. i hope this will help
Jan 03, 2011 | Western Digital My Book Essential 1TB...
Hi! I stored files, docs, and pics, on my Verbatim Ext. Hard Drive USB 2.0 awhile back. I now want to update it. When I go to "shortcut to Verbatim" I get a Nero BackItUP Archive File page. When I...
Connect the external drive.
Open 'My Computer'.
One of the icons should be associated with the external drive.
Double-click the icon to "open" the external drive, to show the files/folders on the drive.
Oct 05, 2010 | Verbatim External, USB 2.0, 750GB...
What do I have to do to start copying file to the external hard drive. Looks like I am just getting shortcuts. The file folders have the small black arrow indicating a shortcut
Hi right click on the file you want to put on the ext. hard drive. You will see a option "send to" click that then choose the ext hard drive. This will sent the whole file and not just a shortcut. Thank you for using Fixya.com
Feb 11, 2010 | Computers & Internet
Memorex U3 traveldrive,USB 2.0 won't open Word '03 file in Vista,says, ''shortcut path does not exist.'' But shows it in there at 450 KB? Help. Thanks, Charles
try to copy the file on the hard drive and then open it and make sure the file u are mentioning is not a shortcut sometimes we even send a shortcut into the usb drive instead of the real file by mistake so check it
Jul 09, 2009 | Electronics - Others
I bought a Maxtor One Touch 3 500GB EXT HD for 10 months, i just found out it is not powering on at all yesterday, so i cant do any things and so worry about my storage files in to it, can you help me how...
Hi kennithtang,
Lets troubleshoot this together. First, lets check and make sure the power cord is plug into the wall and to the external HD, second, make sure the communications cable (most likely a USB cable) is plug into a USB port as well. If this does not work, try plugging the USB cable into another USB port on the computer or monitor. Hope this resolves the issue. If not, then hopefully, the hard drive from the external HD is extrackable. Then may need to purchase an enclosure that in compatible to a 500GB hard drive.
Hope this helps and good luck.
Jul 26, 2008 | Computers & Internet
Ext.hdd can't be detected..
When you have the drive connected,go to your control panel,open up Administrative tools,Computer Management,Disk Management.See if drive is there.If it is, right click in drive space ,assign a drive letter.
If not,scan for new hardware.
You could also look at your usb port handler in your device manager.Update your usb controller,usb handler
Jan 18, 2008 | Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
