Question about Behringer EUROPOWER EP2500 Amplifier
My EP2500 died, the capacitors are swollen on the top in the power supply.
    Genius:
  • 1,175 Answers
Find a tech that can fix tvs or guitar amps or stereos. Have them replace the swollen caps.....With no power , these amps will loose all high voltage in a day at the most.
The "Capacitor plague" has affects millions of products. Yours is one
Posted on Dec 16, 2014
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Behringer Expert
  • 232 Answers
A QSC RMX 2450 is very close in design of this amp...since Ari copied it, that schematic is pretty close. :)
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
Unless you are a qualified audio service technician, you should refer repair of this unit to an authorized Behringer service depot. The capacitors you refer to can store lethal amounts of electrical charge. Also, Behringer service manuals and schematics are notoriously difficult to get.
Posted on Oct 07, 2010
Turn on t.v...sound comes on....picture gradually comes on after a period of 20 minutes.
Check for swollen Capacitors on the power supply. Be careful disconnect the TV. Bad capacitors swell up and they are supposed to be flat on the top. The capacitors store current and when they are bad the current is not stored. They can also be checked with a multi meter. but be careful to short them out after having disconnected the power supply. you can do that with a piece of insulated wire or with a screw driver then removing one leg from the pc board. They measure in uf Microfarads. the bad ones will usually be open. And probably swollen on the top.
Oct 19, 2017 | Garden
My EZ27 fails to power up. Checked fuses - all ok. A capacitor on power supply board looks suspect - is this a common problem?
hi is the, capacitor swollen on the top, but they also don't have to be swollen to be faulty, try some heat on the capacitors with an hairdryer see if the tv comes on, thanks
shaun
Feb 20, 2017 | Televison & Video
Pinoeer power won't come on. gets power for 10 seconds then dies
replace the power supply board or look at the old power supply board to see if you have any capacitors with swollen tops replace the bad capacitors with new ones.
Mar 02, 2013 | Pioneer Televison & Video
50 inch lg won't power on
The problem could be just a few bad capacitors on the Power Supply, there could be a bad capacitor on the Y board if its bad it needs to be replaced with the buffers together
If you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on top.
The ones you are looking for are located almost center bottom of the power board,Usually I can see them clearly with the back on simply shining a light into the back through the holes
If otherwise you have to change the whole power supply board Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
I hope this will help in solving the problem...
Sep 05, 2011 | LG Televison & Video
Power on difficulties.
Either the power supply has an issue , or you have a bad buffer board and Ysus scan board or both.red light indicating may mean power supply , 7 blinks the buffers and y board.
It could be just a few bad capacitors on the Power Supply, there could be a bad capacitor on the Y board if its bad it needs to be replaced with the buffers together
With the back removed you will see a few circuit boards the upper one (ac cord runs to it through a small board) is the power supply, it has a lot of capacitors on it (cylindrical standing straight up soldered in and marked on the sides with the positive/negative sides and uf and Volts values)
Philips uses 2200uf or 3300uf at 35Volts rating capacitors, they cost about $1-$2 each
The power board and back unscrew with a torx bit and screwdriver size 10 and 15 , if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
You can replace the whole power supply, .
If there is a blinking red light on the TV count the blinks,if it still blinks after replacing the swollen cap this would indicate a bad buffer board ,
check the capacitors by looking for the swollen tops .
I hope that will helpout.....
May 18, 2011 | Philips 50PFP5332D 50 in. Plasma...
I have a phillips lcd hdtv. When I turn it on the light blinks 6 times. I'm sure its the power supply board, my question is how do i repair the power supply board without replacing it? I have a power...
look ON THE POWER SUPPLY FOR SWOLLEN CAPASITORS. usually 2 RIGHT BY HEAT SINK. VALUE VARIES... REPLACE ANY SWOLLEN CAPASITORS AND SHOULD SOLVE PROBLEM
Feb 17, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Takes to long for it to turn on. Think the switch is going bad.
I believe your problem is going to be defective filter capacitors in power supply. Classic symptom of taking longer and longer to come on. Will get progressively worse over time then wont come on at all. No need to replace the whole power supply board. Most knowledgeable repair shops will replace the swollen capacitors or you can try yourself if you are familiar with electronics.
The defective capacitors will usually swell up out the top making them easy to spot
Oct 17, 2010 | Samsung LA40A450 40 in. LCD TV
Lg tv takes a long time to turn on. Flat panel 32" LCD 3 years old
Power supply board have those parts call capacitors are dying,have leakages gases capacitors parts.Take the tv aparts.The power supply board,that the board,where the power a/c cord plug into it.U know basic electronic,have all the tools?know basic soldering?Searches the power supply board for those dying capacitors,that have leakages of gases going to dead capacitors.These dying capacitors on the power supply board alway bulges up on it tops or puffing up on it tops.These dying capacitors,must be replaced.The tv power will power up as normal and faster.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 04, 2010 | LG 32LG30 32 in. LCD HDTV
Power supply problem in Behringer pmp 3000 mixer
Just try to resolder all component parts in power supply section,maybe there is a loose connection or cold solder joints that causing of abnormal voltage or missing voltage.Also check the resistor for cange value causing the voltage trap.Check also all electrolytic capacitor for leak. Hope it may help you;;
Jun 08, 2009 | Behringer EUROPOWER EP2500 Amplifier
Dead monitor,,,,,,,,,,,,,,,,,,,lcd viewsonic
If the power supply is not wqrking then it is the invertor unit that has dies.
Replace the monitor is the best advice- If it that recent out of warranty may be worth contacting 'viewsonic to see if they will discount you one.
Jul 19, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Behringer EUROPOWER EP2500 Amplifier Logo
565 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
