Question about Spidem Trevi Automatic Espresso Machine
I was given this coffee machine without a manual & need to know how if there is a self cleaning programme that should be done before dispensing the coffee? How can I get a manual for this coffee machine?
    Problem Solver:
  • 15 Answers
I cleaned my Jura Capresso with a tablet, but the message "Clean Machine/Ready" won't switch back to "Ready". Any suggestions?
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Oct 06, 2016 | Jura Capresso Impressa Coffee Makers &...
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
Yellow and red light on but nothing happening?
I have a Tassimo. The machine reads a bar code on the coffee cartridge that you put in before pressing brew button. You open the dispenser lid, place a cartridge in with the printing facing down. If you notice, the label has a bar code on it. There is a small rectangular window on the machine that you can see when you open up the dispenser lid. Make sure that the window is clean. If there is debris covering it, the machine wont be able to read the bar code and therefore will not know how to dispense for the specific cartridge you put in.
As for the manual, I found one on the Bosch website to download.
Good luck.
Jan 09, 2014 | Bosch Tassimo TAS4011GB Coffee Maker
It's telling me to self clean?? Can't find manual
Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
Sep 20, 2009 | Cuisinart DCC-1200 Coffee Maker
I have lost by cleaning manual for my dcc-1200 coffee maker. I need to clean it the light won't shut off. Thanks, Dawn Miller
Sep 07, 2009 | Cuisinart DCC-1200 Coffee Maker
Filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
Jun 22, 2009 | Black & Decker Programmable 8 Cup...
Self Clean Button
Unplug the coffeemaker for 1 hour or longer - it should reset the coffee maker and get rid of that self-clean light.
-Tha Mp3 doctor
Jan 24, 2009 | Cuisinart Coffeemakers
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Self clean feature on coffee pot
here is the link to the manual http://www.cuisinart.com/share/man/25_man.pdf page 8 - looks like you have a calcium buildup - descale overnight using vinegar/water 50% if the self clean feature is not able to deal with the problem. hope this helps :)
Mar 10, 2007 | Cuisinart DCC-1200 Coffee Maker
Spidem Trevi Automatic Espresso Machine Logo
386 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Mike
Mike
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
