Question about Sony Playstation 3 (PS3) Console
Ps3 is getting power and the hdmi is hooked up right, but when I turn the ps3 on nothing shows up on the tv.
  • 166 Answers
My friend too faced same kind of problem ............
his ps3 shows this error.........
if you are also facing exactly same problem
then dont worry
Go to this site and fix your problem by downloading repair guide
Click Here to Get guide
Posted on Oct 07, 2010
Can't find setting to use my ps3
Try each setting if you have it hooked up via HDMI. If nothing comes in, try turning the PS3 and TV off and disconnect the cord and reconnect it. You may also wish to use a different HDMI port. Otherwise, your HDMI cable, PS3 or TV may be faulty.
Nov 10, 2013 | Televison & Video
Cant hook up my ps3 to the tv ? tried all 3 input outlets and nothing tried hooking it up with a dvd player and still nothing ?
The ps3 has 2 output modes, hdmi and composite or component. For example if you started with composite and switched to hdmi the screen would show up black. The way to select the dif output is to press and hold the power button until you hear a second beep, this should put it on the proper output. Hope this helps and is the only thing I can think of if your tv is properly working.
Aug 23, 2011 | Audio Players & Recorders
Got a PS3 hooked upto a Samsung 40" LCD TV via
I would suggest trying a different TV, and maybe see if you still have any Component or Standard Definition Composite cables to connect the PS3 to the TV and see if it works that way. I would assume you did this when you said you reset the resolution on your PS3, but turn it off, then hold in the power button until it beeps twice in a row. (Just in case) Make sure everything is plugged in twice and your TV is on the right input. If none of that works, there may be something wrong with the graphics adapters on your PS3 in which case you will need to contact Sony about fixing it.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
I have a HDMI problem with my PS3. I have it
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
May 14, 2010 | Sony Playstation 3 (PS3) Console
Nothing shows on screen when inserting game , i hear the disc is turning but nothing shows on screen
Make sure you have the cables hooked up properly, regardless of whether your using an HDMI cable or regular A/V cables.
Best thing to do in a case like this is to do a factory reset on your PS3. Be sure that the A/V cables are being used originally and are hooked up properly.
Here is how to do the factory reset on a PS3:
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Try that, if you still don't get video and you know the cables and the TV are set to the right output then its an issue with the main board not having any output.
Apr 22, 2010 | Sony Playstation 3 (PS3) Console
I get power to my ps3 but its not sending a signal to my tv it just started i've had it hooked up the same way for almost two years with hdmi cable the green light comes on but when i try to turn it off...
try to hold down the power button for 10-15 seconds on startup.. it will automatically reset the display settings, and force your ps3 to startup in a very low resolution that all tv´s is able to show.. dunno if this helps?.....
Jan 25, 2010 | Sony Playstation 3 (PS3) Console
I have my PS3 and TV hooked up to the HDMI ports. I have programmed the unit to show them under TV and DVD respectivly. When I change the source to TV or DVD, nothing shows up on my TV as expected
Sounds like you hooked them both up to HDMI input ports. Make sure that the PS3 is connected to an HDMI input port on the AVR-1508, and that the TV is connected to an HDMI output port (not an input).
Oct 21, 2009 | Denon AVR-1508 Receiver
Ps3 no signal
you can try getting a new power cord and a/v cord or just borrowing one of your friends to try out. the problem might be your tv. have you hooked up and other videogame systems to it and you got the same problem? do you have your ps3 hooked up to hd or hdmi?
Oct 13, 2008 | Sony Playstation 3 (PS3) Console
Trying to connect playstation 3 to my tv having no success
For real try this:
Turn off the tv as well as the ps3 (to where the red ps3 light is on); Then just hold down the power button in the front for like 15 seconds or so, at least until you hear a beep. Then turn the Tv back on, and hopefully once you get the tv back on the correct hdmi input, you'll see that little message offering you to switch to optimum settings.
Hope it works. Did for me.
Feb 17, 2008 | JVC LT-37X776 37 in. LCD HDTV
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
