Question about Rheem Pool & Spa
Clean filter/skimmer service error. so my heater won't turn on. what to do?
  • 990 Answers
You have a low water pressure problem. Once you clean the baskets and filter you will need to check for plugged lines on your suction and for a clog in your impeller on your pump. If your pump basket is cracked the impeller is the place to start. Reach into the pump, with the basket out go through the hole in the back of the pump pot with some long nose pliers and feel for anything in there. If you can't pull it out with the pliers then break the pump down and see if you can clear it then and run a wire through the veins on the impeller. Then if it still has problems you may have to replace the pressure switch on the heater. This is seldom the problem, it is more of a warning to tell you of the other things that may be wrong.
Posted on Oct 07, 2010
Polaris 3900 wheels won't turn
check inside see if belts or hoses came off
Oct 20, 2012 | Polaris 3900 Sport Pool Cleaner ()
Raypak spa heater pr5 service code message
check pressure switch if no voltage both sides of switch bad switch or plugged copper line or loose wires
Oct 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Hayward h300 pool heater won't start
"LO" is simply informing you that the Heater is not sensing proper water flow through it! A Flow Problem.
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Or... Check for any OTHER reason or situations water flow may be reduced through the heater:
  • enough water in pool or spa?
  • If you have a weir gate in skimmer, is it stuck in the UP position?
  • Are any valves closed?
  • Do you have a bypass valve at the heater?
    • If open, this will reduce the amount of water going thru heater, close it to the point, LO goes away.
  • Could be debris in front of Pressure Switch, in the copper tubing
    • Unscrew and remove pressure switch, turn pump on. But first, align end of tube so that when water squirts out it will shoot out from heater and not onto electronic heater components!
  • If all above is good, you may have failed pressure switch?
  • Etc
Good Luck - hope this helped.
Sep 17, 2012 | Hayward H-series Electronic Gas Pool...
What is the use of aquarium dry/wet filters?
The aquarium wet/dry filter is designed to utilize biological, mechanical and chemical mediums, and a place to put a heater skimmer or other equipment keeping your aquarium clean and tidy.
Aug 30, 2012 | A H Fabrications Fish
The heater won't fire and I get a Service System led and a code R4
The SERVICE SYSTEM light indicates that there is insufficient
water flow to the heater. If the pump is operating, this
usually indicates that the filter and/or skimmers should be
cleaned (some filters may require backwashing). If the light
remains on after the filter/skimmers have been serviced,
the system should be checked by a qualified service technician. (from the manual))
If you clean the filters, and know the pump is pushing enough water, replace the water pressure switch, or test it first by jumping the 2 switch wires.
If this still is not the issue everything else is way to complicated to relay through an online media. It would be best to call a certified PENTAIR technician to solve this issue. As these heaters are very proprietary and their codes can mean many things, make sure you get somebody with experience on this model.
Below is a link to find a tech in your area.
http://www.pentairpartners.com/dealerlocator/dealerlocatorlist.aspx
Apr 11, 2011 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Air Flow Fault, E04 and E05 Errors, all are ingniter related?
Is it the digital user interface? Often when you are receiving multiple error codes, its the control board that is bad. This is not as common in Mini-maxes and it's an expensive fix but it might be what's wrong. Most heater problems, however, don't have anything to do with the heater. Make sure your flow is good. Clean all baskets (skimmer and pump) and backwash (D.E. or Sand filters) or clean (cartridge filter) your filter.
www.CPO2go.com
Nov 21, 2010 | Pentair Minimax NT Heater
Little to no heat where is the filter i want to see if it needs to be cleaned?
Their is no filter on the heater, your pool filter. If it is dirty your flow rate will go down and without enough flow the heater would overheat, but for a pressure switch in your heater. So if you clean your baskets, (pump and skimmer) and clean your filter this may help. Without more info this is all I can tell you.Hope this helps.
Jan 17, 2010 | Pentair Minimax NT Heater
Raypack gas pool heater displays"clean filter/strainer" when I turn it on
There is not enough system pressure to close the heaters pressure switch so the heater will not fire. Assuming your pump is on and any valves in your pipes are set correctly it means something is restricing water flow too much and needs to be cleaned to fix your flow rate and allow the heater to fire.
Start at the skimmer(s) baskets and then the pump strainer basket and finally clean your filter. If sand, backwash it. If cartridge or DE clean according to your manufacturers direction. In some cases cleaning a cartridge filter will no longer satisfy heater pressure requirements meaning you will need to replace the element.
Nov 11, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Pool & Spa Logo
120 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
