Question about Jenn-Air Pro-Style JFC2089H French Door Refrigerator
Slightly different model looks the same JFC2087HRS French Door. Refigerator section stops cooling and a 24 hour defrost gets it going again. Problem is I had it fixed for this about a month after I got it, has happened another 3 times and this time only 6 weeks after the last time. Fridge is 2 years old this week.
  • ramona126 Oct 07, 2010
    Thanks dodgeapplian, I will try that. Better than unplugging it every 6 weeks and moving all the food to the cheap garage fridge (quite thankful I have an extra one).
    President:
  • 1,891 Answers
After that many repairs you we can say that it has a defrost problem. the freezer will not defrost it self if off for 24 hr . but if the coil is defrosted then we know that we have a complete defrost . now I would replace the derfost terminator and if the problem came back replace the adapitive defrost control .. now with your history if either has not been replaced the replace both of them and your done . this should correct problem .. mm .. hope this helps .. ****
Posted on Oct 07, 2010
Testimonial: "Wow, that was quick!"
  • dennis dodge Oct 07, 2010
    wow so was your feed back . if you need parts info get back with me . some terminators are sold only with with the heater . but you can repl the the part by temp rating and much less money .mm mm
Jenn Air French/with freezer in bottom Model #JFC2087HRS, top part isn't cooling. Freezer is fine.
You may have a defrost problem check the freezer inside at the back and see if there is frost build up if so you need to check the DTS and element to see if they are good.Let me know and I will guide you through it.
Sep 18, 2011 | Jenn-Air JFC2087HRS Side by Side...
Refigerator not getting cold freezer seems to be freezing
Its defrost problem.---------- The unit is not defrosting on time.--------. First try manual defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. -------------
If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site.-------------
This will help.Thanks.Helpmech.
Jul 21, 2011 | Whirlpool Refrigerators
My bottom freezer gets cold but the top part (fridge) does not. Why? I have an older first addition style
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
May 19, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer door was accidentally left open for about one hour. Now the refrigerator and freezer are not cooling.
If the freezer or fridge door remains open for one hour or few more hours by mistake, then to again get to its proper cooling cycle, it requires approx another 24 hours.And in that also, dont open the refrigerators doors for few hours.If you open, close it quickly.Once it cooling cycle again gets set, then you can use it like you use regularly.But approx it takes 24 hours to get proper cooling.-------- ------------------ But if its already more then 24 hours and there is very low cooling, then it can be internal defrost cycle issue.You will have to do manual reset procedure.The manual reset procedure is as follows:-------- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check,it will get set to its cooling cycle and work as normal.------------- This should help.Thanks.Helpmech.
May 04, 2011 | Refrigerators
Frig stopped working but freezer is good? Help... I am handy.
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 24, 2011 | Maytag MFD2561HE Bottom Freezer French...
Refigerator has no cold air freezer works good
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 21, 2010 | Amana AFI2538A Bottom Freezer French Door...
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Jenn-Air Pro-Style JFC2089H French Door Refrigerator Logo
93 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
