Question about Audiofonics Car Audio & Video
When i hook up my amp my speakers wont play music? ive hooked up my rca cables up but i ont know if you hook it up to the input or output frum the cd player?
  • 48 Answers
You rca hookup, back of cd player is rca out, at the amp it is rca in, make shure you hook up blue remote wire, also make shure you have a good ground if not amp will not turn on. if you run wires make shure you run power wire down one side of car and remote and rca down the other, This will keep all motor noise out of system.
Posted on Oct 07, 2010
Sony XM-GTR4A
contact sony .... or check your head unit is recieving
Mar 29, 2014 | Sony Car Audio & Video
Hooking up the speaker to an amp, using the rca line out of the amp i have no volume control from the amp knobs, can i hook the speakers up to the amp from the speaker out ?
You should NOT under any circumstances connect an audio input lead to a speaker output jack!
The RCA jacks you are trying to take output from ore "pre fader" which would be solid "line level" and not controlled by volume controls. Tap off the INPUT to the amp... you should be using balanced lines for the interconnects. RCA jacks are unbalanced lines. You can drive several inputs from a line level output of a mixer for example using a splitter cable.
Aug 23, 2011 | Harbinger APS12 12 Powered PA Speaker
Hi. Today I bought a 3 foot audio y-cable and an RCA (Phono) Female to RCA (Phoneo) Female cable so that I could hook up these two speakers that I have that belong to a predisian sound system (boom box)...
All you need to do is get a USB based sound adapter 16/32BIT MINIMUM to plug your speakers straight into your laptop with better sound. Many laptops will have limited sound OUTPUT which places large limitations on pushing sound through your nice speakers. You already know the problem is not the speakers or new cables, therefore you know that problem has been isolated to your laptop. You may also check the volume settings in the laptop to ensure your running the highest possible BIT or volume enhacement software. Let me know if this does the trick for you.
Jan 09, 2011 | HP Audio Players & Recorders
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
Hooked up the amp, lights up, fans kick on and run fine, speakers hooked up proper, no sound? hooked up speakers to another amp and they work fine. Fuses are all good too. Thoughts?
could be bad rca cables or no output from the radio rca outputs. the sub control may be turned off on the radio (ive seen that alot at my work). if all that is fine, the amplifier may be bad. the rca cables may be plugged into the "out" section of the amp. gotta look at all the small obvious things first. good luck.
Dec 18, 2009 | AudioBahn A2300HCT Car Audio Amplifier
CAN YOU PLEASE TELL ME HOW TO CONNECT A SET OF SPEAKERS TO THE CD PLAYER PLEASE? WOULD I HAVE TO USE AN AMPLIFIER THEN TO SPEAKERS AND HOW WOULD I COME FROM THE MARANTZ CD PLAYER ? THANKS -GRAHAM
You will have to use an amplifier to power the speakers from the cd player, the output on the CD player isn't enough. You will need to hook the CD player to the amplifier using the red and white wires, on the CD hook them to the OUT and on the amp hook them to the CD or Aux or Tape in. Then select that input on the amp and enjoy the music.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Nov 05, 2009 | Marantz CDR631 CD Recorder
Bose 151 main with amp
Does your tv have stereo outputs? if yes all you have to do is run RCA red..white jacks into tv outtput then run the other ends into the amps tape or aux or cd input and your done! If you dont have outputs on tour tv you will have to but an RF converter box (about 20.00 at wal-mart) and hook that into the tv and the cables will run out of that to the stereo!
Jan 14, 2009 | Bose 901 VI Main / Stereo Speaker
Subwoofer wont play
Check your rca cables they might be loose or not connected to the amp or the radio. Sometimes those rca cable outlets get worn out by being bumped, moved, hooking up and pulling out connectors. Plug in your rca cords and wiggle them on the amp while radio is on and see if the music cuts in and out
Nov 20, 2008 | Pioneer GM-5100T Car Audio Amplifier
Can the Pyle PLCD-42
Yes there is a couple possible ways.
1. Get 2 RCA Y adapters and split your Preamp Output you will not have any type of fader control this way because you are using a single output.
2. Run one amp from the radio with a set of RCA Cables.
Hook up amp #2 using a Line converter connected to the output of your stereo which will convert you to RCA the just run a cable to the amp..
3. If one of the amps has a High Level Input Run a set of speaker wires from the stereo outputs to the High level Input.
I personally prefer the above 2 methods I find Low Level input sounds better.
Hope this gives you some Ideas and helps
Aug 31, 2008 | Pyle PLCD-42 CD Player
Factory stero to amp
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Dec 08, 2007 | Blaupunkt PCA250 Car Audio Amplifier
Car Audio & Video Logo
117 people viewed this question
Top Audiofonics Car Audio & Video Experts
xxxxxx xxx
Are you an Audiofonics Car Audio and Video Expert? Answer questions, earn points and help others
