Question about Williams (5009622) Ceramic Gas Wall Mounted Panel Heater
I don't think my pilot is lite. I need to know How to light the pilot
  • 59 Answers
Hi, open the front panel of the furnace, At the bottom of the furnace you will see a gas valve with a red button, or nob of some kind. Place the nob on pilot, then push in and light the gas coming out of the pilot don't let go of the button for at least 30 seconds because the sensor will not detect flame. If this dose not work you make have a bad gas valve or a bad pilot generator.
Posted on Oct 07, 2010
Not light
check to make sure that the poilet lite flame is touching the tip or top of the thermocouple.
the pilot lite needs to heat up the thermocouple so that the thermocouple opens the gas to the main gas log. a cold thermocouple shuts off the gas to the main gas log or gas burner and a hot thermocouple opens the gas to the main burner.
the pilot lite flame must be touching the thermocouple to heat it up.
pilot lite orface needs to be clear to let the pilot flame gas through with enough pressure so that the little flame can reach & touch the thermocouple. Pilot lite gas feed tube must be clear to let gas through. Use compressed air or a fine sewing needle, or even carb cleaner to clear out orface hole and gas feed line to pilot lite.
important!! WARNING:
if you use carb cleaner,make sure all the carb cleaner is dry,soaked up with paper towell or kleanex tissue and blowed out with compressed air , because carb cleaner can burn just like gasoline; so any carb cleaner must be compleatly gone before you attempt to lite the pilot lite.
May 20, 2013 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Why does pilot light turns on gas burner only to have it go out about 10 seconds later? 30 to 40 sec later repeats,without lighting. What is problem? once in awhile, it will light..not often. The burner...
Hello
Sounds like the thermocouple is going bad.The thermocouple is a thin tube that runs from the pilot lite to the gas valve.
What it does is it sences the heat from the pilot lite and keeps the gas valve open to allow the pilot to stay on.
This can be easily repaird by shutting off power and gas to your heater and removeing the thermocouple from the gas valve,then unclip or unscrew it from the pilot lite area.
Any plumbing supply store or home depot or lowes should have these.
Once you get a new one,install to gas valve and pilot lite area then turn on power and gas to heater and follow pilot lighting procedure,you may need to hold gas on for 60 seconds.
Here is a picture of the thermocouple so you know what to look for.
http://thermocatalytic.com/Thermocouple.JPG
http://homerepairgeek.com/wp-content/uploads/2010/12/furnace-thermocouple.jpg
Feb 10, 2011 | Honeywell Programmable Thermostat Heater
I lost my manual and dont know how to light my R15 gas wall heater.
if its a stnding pilot turn the gas control nobe to pilot hold down light pilot when lite hold down for 30 saconds,then relese and it should stay lite.
Jan 20, 2011 | Heating & Cooling
I think my pilot light went out, but I need to know how to locate it
Dryers do NOT use a standing pilot lite ..When the unit is turned on and heat is commanded on the gas valve opens and an igniter lite's the gas , then their is a flame sensor to see the flame from the burning gas if no flame is present it shuts the gas back off.. So if you have a no heat concern with your dryer it will be either the igniter, gas coil's or the flame sensor
Jan 03, 2011 | Dryers
I want to light the pilot but do not know how what is the red button for and do you turn on the gas to light pilot?
nope - don't turn on gas at the Range's front control panel to light the pilot lite.
but you do need to turn on the gas to the kitchen range at the plumbers black pipe valve to the Range.
To light the pilot light:
(1) depress the red button (that feeds the gas to the pilot light orifice)
(2) using lighter/match/lit rolled-up newspaper, etc, light the tiny amount of gas coming from orifice
(3) continue to hold dow red button for 1 or 1.5 minutes (this allows heat to bend the bi-metal contact)
(4) after 1-1.5 minutes with a lit pilot light, release the red button - the pilot should remain lit
(5) you're done lighting the pilot lite - turn on the oven (or broiler).
Dec 27, 2010 | Kitchen Ranges
I HAVE MODEL GP30 WALL HEATER. I CAN LITE PILOT BUT WHEN I TURN CONTROL KNOB UP PILOT GOES OUT AND DOES NOT LITE HEATER
The thermocoupler is bad.Replace it,or if you can adjust it to where the thermocoupler is in the pilot flame.You know you have to hold the knob down for about 30 seconds or a minute,don`t you?If the flame will not touch the thermocoupler,it will not stay lit.You can cut a piece of copper tubing,or steel tubing to slidde over the old thermocoupler to make contact with the pilot flame,and it will work,if the thermocoupler is not in to bad of shape.
Oct 17, 2009 | Heating & Cooling
Main burner will not light. pilot has now gone out
shut off the gas at the gas **** and gas valve. the pilot tube is held in place by a 7/16 compression nut. remove it then remove the 2 screws for the thermopile "generator". follow the pilot tube and the pilot assembly should be held in by one or two screws. usually you don't have to remove the main burners. hopefully this helps
Jun 14, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot went out and don't know how to lite it
YES YOU DO NEED MATCHES TO LIGHT THE PILOT IT IT DONT HAVE A AUTO PILOT AND IF IT DOES THEN YOU'LD HEAR IT CLICKING OR TRYING TO LIGHT IF NO CLICK THEN YES MATCHES WILL WORK TO LIGHT THE PILOT
Apr 11, 2009 | Williams 1403622 Gas Compact Heater
Laars lite 2
you will need to take pilot assembly out and replace thermal couple also check flue
May 04, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Williams (5009622) Ceramic Gas Wall Mounted Panel Heater Logo
522 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
