Question about Cobra 18 WX ST II 40-Channels Base CB Radio
When I key the mike, the cb goes to channel 9 automatically
    Guru:
  • 773 Answers
It has automatic channel 19/9. make sure its off. Other then that, if it is off, and its going to 9, then there is probably something wrong with it. That's the worst radio cobra ever made. I don't know why they still make it.
Posted on Oct 07, 2010
  • steven arnold Jun 02, 2013
    how do i turn it off
Its a cobra 25ltd when i key the mike sometimes it hangs keyed up and does it with defferent mikes so the mike is not my problem.
take some electrical spray cleaner and lightly spray the inside of the radio where the mic plugs in. could also be a keying diode.
Jan 04, 2013 | Cobra 25 LTD 40-channel Classic CB Radio...
I can't change off of channel 9
look for the channel 9 switch--it automatically takes to 9.
Oct 28, 2012 | Maxon HCB-30A CB Radio
3300 240-Channels Base CB Radio: intermitant when key mike /works for a bit then st...
sounds like you have a bad soilder joint on the board. If it quits and you hit the case and it starts again is a sure way to find out.
May 07, 2010 | Connex 3300 240-Channels Base CB Radio
My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
May 01, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Have a galaxy dx959 and it makes a humming sound through the speaker only when the mike is keyed and goes away when the power is turned down. all items are stock including mike any input?
Sounds like you are getting some feedback from somewhere. I would check inside the mic connector for a shorted, loose, or twisted wire then check inside the mic itself for same, if you can, try a different mic that is wired for your radio, my bet is there is some stray RF floating around somewhere.
Hope this helps,
Mojorisin
Jun 18, 2009 | Uniden PRO510XL 40-Channels Base CB Radio
Cobra 29 when you key the mike the channel lights, tran/rec light
I had a similar problem with another brand radio. My power supply I was running it on was not rated high enough in the amp category. Are you running on a power supply or battery?
Apr 20, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Uniden 520xl makes humming noise when mike is keyed
if you have a power mic , you might have it turned up to high. next make sure you have a good ground on your antenna. if that is ok and you still have the same problem have the swr checked. this should fix the fm radio noise.
Apr 10, 2009 | Uniden PRO510XL 40-Channels Base CB Radio
Trying to hookup echo board
take it to the cb shop it requires some soldering skills and time
Dec 05, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Ch 9
Hi larry, That is a normal ch 9 default on electronic channel changers. Small midlands/cobras also do that. Try taking the red/hot power wire loose and attaching it to a power source that is hot all the time. That way there will be power going to the radio with the key shut off and it should retain the last channel you were on.
Hope this is what you were looking for, let us know,, Mechanic
Feb 21, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Lost channels in a galaxy 66v cb radio
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
Aug 15, 2007 | Galaxy Radios DX-66V Base CB Radio
Cobra 18 WX ST II 40-Channels Base CB Radio Logo
130 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
