Question about Dryers
Loud squeeking sound, probably bad bearing. How do I access the rear of the drum to do this repair?
  • 4,340 Answers
This answer is brand and model relevant, please provide much more detail, BUT most drums come out the front. Please remember to unplug the machine before doing anything.
Posted on Oct 07, 2010
What is the loud squeeking sound from my dryer?
bad bearing worn belt, bad or drum pads
Jul 05, 2014 | GE Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Ge profile dpsr473evoww has a VERY loud squeeking, it's not the belt as it's been replaced. Sounds like the rear bearing. What are the details of the rear bearing I need to purchase for this model?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 09, 2011 | Dryers
Dryer sqeaks when turn on
Where is the squeek coming from. Front or rear. There are two wheels or slides on fhe front of the drum. IF it is here they are bad. If it's in the rear, then its the drum bearing. You can take the front off to access the wheels in the front.
Jul 11, 2010 | Maytag Dryers
Our 4000 series dishwasher is making a loud strange noise while washing. It sounds like the pump. Any suggestions?
it sounds like the rear drum bearing is out,if all else works o.k. and its sounds like a jet when running its probably the lip-seal is out and the bearing is bad,remove the rear access panel and if its discolored then the seal is bad and water got into the bearing and you need to replace both
Feb 14, 2010 | Dishwashers
I have GE profile Model DPSR473EW with loud squeak when drum turns ? I also need to learn how to access the drum etc...
I have experienced two problems with "loud squeeks" with the DPSR473EW. First, if you take the top off (open door, remove two screws under top door lip releasing the top), then.., remove two small screws (inside up high - one on each side) holding the front panel/door assembly on. Pull the front panel/door assy away from the main unit - can't seperate due to some wires near the blower. On the door/front panel assy..., you will see four "teflon slides" that fit into a plastic semi-circular assy (the drum rides on those four teflon slides). Most of the time, this is where the squeeks come from - I've seen them worn thru..., and the drum riding on the plastic (just order the teflon slides - qty 4 - WE1M333). If the plastic piece that the slides fit into is worn, replace it - WE2M26 (top bearing). This should do it. If the slides look OK (so the squeek hasn't been fixed), the other place for a squeek is...., the back bearing. This bearing is basically a male rotating plastic sleeve running in a metal female hole. I have seen those wear thru the plastic bushing..., causing lots of noise. To inspect that bearing, you will need to a) remove the belt (plenty of instructions on the internet), then b)remove the drum..., then..., you can inspect that back bearing (two pieces - one piece on the back of the drum, the female piece mounted on the heater shroud.. If you need to replace that bearing, or one half of it - you can order pn WE25M40 - it will have both pieces. Good Luck
Nov 15, 2009 | GE Profile DPSR473EW Dryer
Our front loading Kenmore MODEL 41742042100.has begun sounding like a jet enjine when it is spinning,someone told me that it is probably bad bearings, is it worth having this 7yr old machine repaired or...
Hi.
I
f you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Kenmore 44042 Front Load Washer
Loud squeeking sound. Figure its the back
Well I do not know which brand you have but I have pictorials on all kinds of dryers at my website. I am guessing yours is a GE. Check out my repair PICTORIAL.
Note: Not pictured is a WE3X75 bearing that goes on the rear of the drum and fits into the center hole pictured above.
WE3X75 drum bearing.
Jul 06, 2009 | Dryers
Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
good luck.....
Mar 28, 2009 | GE WSXH208A Front Load Washer
Loud vibration
the bearing is nothing to replace once you have it.
but you have to dissemble the machine ,
take off the top and bottom access panel,
front control panel , front door assembly
now remove the drum as a unit.
you have to mark any hoses and wiring you disconnect.
its best to do it in the middle of garage,
Nov 07, 2007 | Kenmore 46462 Front Load Washer
Dryers Logo
44 people viewed this question
Top Dryers Experts
