Question about Cisco WRT320N Wireless Kit
Im trying to set up my cisco wrt320n wirless router and i don't have the cd or book and its giving me problems
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then go to LAN settings change ip as you want then save settings and resatrt router. You can also enable DHCP on it with specific ip range. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Oct 07, 2010
How to block url on wrt320n
not sure that router has that feature built in. you may want to get some parental control software to install on a computer to block sites.
Aug 12, 2014 | Cisco WRT320N Wireless Kit
How to connect 2 cisco linksys E100
You can easily connect two linksys router for internet access.......here is simple example .....connect two linksys router for internet access
Sep 04, 2012 | Linksys Cisco WRT320N Wireless Kit
Accessing my router
The default username : password for any new Linksys or Cisco routers are admin : admin .
If your router is set-up by somebody else. Better ask your system administrator about it.
Hope this helps.
Jul 20, 2012 | Linksys WRT320N Wireless Router
I have a Linksys WRT320N wireless router connecting my PC and 3 netbooks. 3 netbooks stuck "acquiring network address" after establishing wi-fi protected set up for my BlackBerry Torch. How do I...
If your 3 notebooks were already configured with router and then you used WPS to connect your blackberry, then it must have changed the wireless settings of the router, due to which the router and the 3 notebooks are not able to communicate now and due to that, the notebooks are showing acquring network address as they are not able to get an IP address of the router.
Solution: You need to open the interface of the router and check the new wireless settings and then put those wireless settings into your 3 notebooks. You may use this link for detailed instructions, or you may also chat with the technician available for chat on that website. Check or Change WirelessPassword
Jul 10, 2011 | Linksys Computers & Internet
Trying to set up without disc
Hi.
You can download the disc image directly from the website:
http://www.linksysbycisco.com/EU/en/support/WRT320N/download
Scroll down to the download area and find installation cd image and click download.
Burn this image using your burning software and you will have the installation disk just like the original one!
Feb 22, 2011 | Cisco WRT320N Wireless Kit
My linksys e-2000 wireless router fell off of the network and im not able to connect wirlessly.can u help me?
Try resetting the router and unplugging the whole unit wait 30 seconds then power it all up and reopen your wireless finder on your electronic unit. It should find the router by itself...
Feb 08, 2011 | Cisco Linksys E2000 Advanced WirelessN...
The wireless on my new router is not working but the wired is.My wireless can connect to the signal but it stills says no internet access. it was working earlier today but not now. I have a Linksys WRT320N...
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Make sure that the DHCP server on the router is enabled
Click Here for step by step solution
May 10, 2010 | Cisco WRT320N Wireless Kit
I have a Linksys by cisco Model# WRT320N I cant remember password I need to reset password how do I do this?
To reset your router to default settings and start over from the beginning, (if you are willing to do that) find the "Reset" button on the back of the router and press and hold it for 10 seconds.
Then, unplug the router and plug it back in again.
The router is now back to factory defaults and the username and password should be : admin
Dec 25, 2009 | Linksys WRT320N Wireless Kit
Unable to connect 2 routers need help!
Do you have any funky subnets for your Cisco router? Do not connect the wireless router to your network yet, as it may have the same IP address as your other router.
Basically the easiest way to do this is to set a dedicated IP for the 2Wire router on the Cisoo router. Then make them stay on the same subnet, but give an IP range for your Cisco router, like 1-50 or something. If you give the 2Wire router IP .51 for instance, then give the Wifi users on the 2Wire IP range from .52-75 or something.
Make the 2Wire router only use wifi and not serve DHCP addresses. Then you setup the 2Wire router to get its info from the Cisco router.
I searched and there is no howto out there for doing this with a Cisco router. However, here is one I used to setup a similar scenario with a Netgear router. It worked. If you are able to translate a bit, it might work for you:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16778323,235,239&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2Fn101236.asp&answer_id=6056802#__highlight
Here is another article:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16777285,246,260&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101496.asp&answer_id=6056800#__highlight
Let me know if you are able to work through this. You need to give the 2wire router a static IP and you need to NOT use it for wired connections, and not use it to serve DHCP settings.
Jan 21, 2009 | 2wire 2700HG-B Router (2700HGB)
Cisco WRT320N Wireless Kit Logo
167 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
