Question about Ruud Central System Air Conditioner
Replace contactor I have an ruud air conditioner model no UAMB-048JAZ . relpace contactor with a new part protech contactor part no 42-25101-01. Is this the correct part number? on top of the contactor the L1 L2 T1 7 T3 loction is not the same as the old contactor, when installind new cantactor wich wire go to L1 Lt ect. on new part
  • HOTINKWD Jul 17, 2008
    replacing honeywell R8243A WITH FASCO 1H140A, WHERE SHOULD THE L1 AND T1 GO?
  • 828 Answers
On single phase your incoming power lines go to L-1 & L-2, the lines to the compressor go to T-1 & T-2. With A/C current it does not matter which one goes to which side as long as the line goes to the L side and the compressor power lines go to the T side. As long as the coil voltage is correct any contactor will replace the original.
Posted on May 29, 2008
  • Kenneth Blanchard
    Kenneth Blanchard Apr 23, 2014
    What about the capaciator common lead ? Which terminal it goes to. The orignal has a seperate terminal, the 42-25101-01 does not
Uamb-048jaz ruud a/c stopped working what should i check
is outside fan running tells you if contactor is made if so change capacitors on compressor. if not running check transformer,& thermostat.
Sep 01, 2013 | Ruud Heating & Cooling
Ac blower motor attic
that is a model number for the outside condensing unit. to find the motor size for the inside unit, you will need the model off of the inside unit, gas furnace or electric air handler.
Aug 15, 2013 | Ruud UAKA048 Air Conditioner
Need a part number for contactor on ruud UAMB-024JAZ
what supplier do you have ? SQUARE D. +SIEMENS+TELEMECANIQUE?
God bless you
Jul 21, 2013 | Heating & Cooling
I have a Ruud AC Model UAMBO48JAZ That has started to have a hum when it is running it is cooling and has been checked for freon. Could it be the capacitor?
More than likely, it is the hum of the coil in the contactor. Generally, residential uses 24 volts to energize the coil built into the contactor which pulls in a set of contacts (hence the name contactor) to send 220 volts to power the compressor & condenser fan motor. Contactors are relatively inexpensive... so if the noise bothers you, replace it or have it replaced. Put your mind @ ease, the humming noise will do no damage.
Jul 27, 2012 | Ruud UAMB Air Conditioner
Our ruud air conditioner will not go on no fan zero checked the breakers etc, what do i do?
Hello, if the outside unit is not running start at the outside disconnect box and verify if you are getting 240 volts, if you are continue to the contactor coil, check for 24 volts at the contactor coil if there is 24 volts and the contactor does not energize then it must be replaced. If you do not have 24 volts then the low voltage ( thermostat) wiring must be checked out for a short circuit, loose wiring, or the thermostat might be bad. Also, you can check for 24 volts at tjebcontrol board between the r and c terminal if no 24 volts then you have a bad transformer.
Apr 28, 2011 | Ruud UAMB Air Conditioner
service once a year clean dirt and hose the coil out make sure power to outdoor unit is off also make sure you keep a new air filter change about every 2 months you should also have a tech test you pressures this could cause poor cooling also need to clean inside coil also a service tech will probaly need to do this good luck
Aug 30, 2009 | Ruud UAMB Air Conditioner
The outside fan motor (OFM) will not turn off.
it sounds like your fan connector is on the same side of the contactor where your high voltage enters you should have 3 wires 1 wire for each pole of the contactor and 1 wire off the capacitor does the compressor run all the time too? try turning the power switch off on your indoor air handler / gas furnace if the power goes off the fan goes off then it could be low voltage wiring
Jun 30, 2009 | Ruud UAMB Air Conditioner
Condenser is buzzing so there is power, but the
The buzzing sound is from the contactor and only means you have low voltage at the unit,Check and make sure you have 240 volts at the unit and post back.
Jun 27, 2009 | Ruud UAMB Air Conditioner
Ruud Heat Pump
Check to see if there's low voltage reaching the contactor's coil. If there is. and it doesn't close (pull in), then it's defective and should be replaced. Cut the power and check ohms to be certain.
Aug 09, 2008 | Ruud UAMB Air Conditioner
Ruud Central System Air Conditioner Logo
1,428 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
